CONFIG_NFCT_PINS_AS_GPIOS=y doesn't work
I'm using an ISP2053 (nrf5340) chip on a custom board and debugging using the nrf5340dk. I'd like to use P0.02, P0.03 as part of an SPI bus.
I set up a simple experiment where I set `CONFIG_NFCT_PINS_AS_GPIOS=y` in my prj.conf and some code to toggle various pins that I can read on my board. P0.02 and P0.03 are always 0V and other pins toggle between 0V and 3V.
I believe the NFCPINS UICR register (0x00FF8028) should read 0xFFFFFFFE but using nrfjprog I can see that the register reads 0xFFFFFFFF:
nrfjprog --memrd 0x00FF8028
0x00FF8028: FFFFFFFF |....|
After I flash the code using nrfconnect vscode, I can set the register to 0xFFFFFFFE:
nrfjprog --memwr 0x00FF8028 --val 0xFFFFFFFE
Parsing parameters.
Writing.
0x00FF8028: FFFFFFFE |....|
Now the NFC GPIO pins toggle on and off like the other pins.
Is this intended? It seems like CONFIG_NFCT_PINS_AS_GPIOS=y doesn't change the register value. I can see in Guiconfig, the `NFCT pins as GPIO` option is selected. Other options in prj.conf work.
I'd prefer not have to run `nrfjprog --memwr 0x00FF8028 --val 0xFFFFFFFE` when flashing. How do I diagnose the problem further?
I'm using ncs v2.1.1.
  • Im using a nrf52840 , Segger with the nrf SDK.
    How do I use the NFC pins as GPIO ? There must be a simple solution to this.
    Ive added #define CONFIG_NFCT_PINS_AS_GPIOS 1 to the sdk_config.h and also I added the CONFIG_NFCT_PINS_AS_GPIOS here
    When I check the nrfjprog --memrd 0x10001000 --n 512, Im getting all F's
  • Found something important not covered in any of the tickets I've seen on this:
    1. CONFIG_NFCT_PINS_AS_GPIOS=y is required
    2. Power cycling the board (as opposed to simply resetting it after a firmware update) was necessary to change the NFC pin state.
    It's not clear to me if there's a different route to making the NFC peripheral transition modes without requiring a power cycle, but this was sufficient to correct the issue.
    To Nico7's question, SYS_INIT is a macro from include/zephyr/init.h that allows initialization code to run before main.  It's important to know where it's being used in modules since an error in a SYS_INIT registered function can be hard to debug otherwise.
