I want to store some values to flash. What is the best method to store data to flash?
I'm trying to get pstorage working but i have no luck, so i'm wondering if there are any other ways...
my code for pstorage:
static void example_cb_handler(pstorage_handle_t * handle,
uint8_t op_code,
uint32_t result,
uint8_t * p_data,
uint32_t data_len)
if(handle->block_id == pstorage_wait_handle) { pstorage_wait_flag = 0; } //If we are waiting for this callback, clear the wait flag.
switch(op_code)
case PSTORAGE_LOAD_OP_CODE:
if (result == NRF_SUCCESS)
LOG_DEBUG("LOAD");
LOG_DEBUG("LOAD error");
case PSTORAGE_STORE_OP_CODE:
LOG_DEBUG("STORE");
LOG_DEBUG("STORE error");
case PSTORAGE_UPDATE_OP_CODE:
case PSTORAGE_CLEAR_OP_CODE:
case PSTORAGE_ERROR_OP_CODE:
pstorage_module_param_t param;
pstorage_handle_t handle;
pstorage_handle_t block_0_handle;
uint8_t dest_data[5];
static uint8_t block0[4] __attribute__((aligned(4)));
static void pstorage_init_register(void)
uint32_t error_code;
if(pstorage_init()!=NRF_SUCCESS)
LOG_DEBUG("PSTORAGE INIT NI USPEL");
param.block_size = 16; //Select block size of 16 bytes
param.block_count = 1; //Select 10 blocks, total of 160 bytes
param.cb = example_cb_handler; //Set the pstorage callback handler
if((error_code=pstorage_register(¶m, &handle))!=NRF_SUCCESS)
LOG_DEBUG("PSTORAGE REGISTER NI USPEL. ERROR_CODE: %x",error_code);
LOG_DEBUG("PSTORAGE INIT IN REGISTER USPEL");
static void pstorage_store_data(uint8_t* source_data, int i)
pstorage_block_identifier_get(&handle, 0, &block_0_handle);
pstorage_clear(&block_0_handle, 16);
if(error_code!=NRF_SUCCESS)
LOG_DEBUG("IDENTETY ERROR CODE store: %x",error_code);
error_code=pstorage_store(&block_0_handle, source_data, 4, 0);
LOG_DEBUG("PSTORAGE LOAD ERROR CODE: %x",error_code);
LOG_DEBUG("ERROR CODE %x",error_code);
static void pstorage_read_data(void)
error_code=pstorage_block_identifier_get(&handle, 0, &block_0_handle);
LOG_DEBUG("IDENTETY ERROR CODE read: %x",error_code);
error_code=pstorage_load(dest_data, &block_0_handle, 4, 0);
LOG_DEBUG("DEST_DATA: %x",*dest_data);
The example_cb_handler only seems to get called when i call pstorage_read (and even then, the returned values are only 0xFF). If i call pstorage_store, the example_cb_handler doesn't get called.
What could cause this problem?
regards.
