is install code set by zb_secur_ic_set is record in flash
I would have some information about install code and  zb_secur_ic_set function.
Is the function "zb_secur_ic_set" shall be called only once and the install code is record in flash or it's needed to call this function at each startup, and so, an other mecasime shall be implement to record the install code in flash ?
thanks
best regards,
Jean-Philippe
