Data transfer failure using NUS service.
I test data transmission through NUS service as follows.
void data_tx_test(void)
	char		ble_tx_buffer[BLE_NUS_MAX_DATA_LEN];
	sprintf(ble_tx_buffer, "1. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
	data_tx_handler(ble_tx_buffer);
	sprintf(ble_tx_buffer, "2. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
	sprintf(ble_tx_buffer, "3. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
	sprintf(ble_tx_buffer, "4. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
	sprintf(ble_tx_buffer, "5. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
	sprintf(ble_tx_buffer, "6. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
void data_tx_handler(char const *ble_tx_buff)
	uint8_t	tx_buffer[BLE_NUS_MAX_DATA_LEN] = {0,};
    static uint8_t index = 0;
    uint32_t err_code;
	memcpy(tx_buffer, ble_tx_buff, BLE_NUS_MAX_DATA_LEN);
	for(uint8_t i = 0; i < BLE_NUS_MAX_DATA_LEN; i++){
		if(tx_buffer[i] == '\r'){
			index = i;
	index++;
	NRF_LOG_INFO("index = %d\r\n", index);
    do
        err_code = ble_nus_data_send(&m_nus, tx_buffer, &length, m_conn_handle);
			printf("OK!!! [%x]\r\n", err_code);
        } else {
			printf("ERR!!! [%x]\r\n", err_code);
    } while (err_code == NRF_ERROR_RESOURCES);
	index = 0;
If data is transmitted 6 times in succession, the system crashes. No logs appear.
However, the system does not die and operates normally when data is transmitted three times in a row.
//	sprintf(ble_tx_buffer, "4. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
//	data_tx_handler(ble_tx_buffer);
//	sprintf(ble_tx_buffer, "5. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
//	sprintf(ble_tx_buffer, "6. The TCA8418 is a keypad scan device with integrated ESD protection. It can operate from 1.65 V to 3.6 V and has 18 general purpose inputs/outputs (GPIO) that can be used to support up to 80 keys via the I2C interface.\r\n");
I need to implement a function that sends data 6 times in succession. Please tell me how to solve this problem.
Best Regards,
SunBae Yim.
