BLE Just Works on nrf52832 and NRF Connect
Hi, I am working on something that requires me to use Just Works on nrf52832 custom board. Here is the work sccenario. under normal conditions, my module has a bonding PIN and the user is supposed to enter the PIN on his application to get data. My NRF module is a peripheral and i have enabled following in the prj.conf.
CONFIG_BT_NUS_SECURITY_ENABLED
CONFIG_BT_FIXED_PASSKEY
I have registered the necessary callbacks too.
What I now need to implement is a functionality which allows user to bond without a PIN temporarily after a button press. I assume BLE Just Works is what I need for this purpose. But I am open to any other suggestions or new perspectives to get this done.Thanks in advance.
  • Hi, just wanted to provide an update here. I was working on this and I almost got what I wanted. By making the following changes, I could pair the DK with the nrf connect android application without problems
    /*<in prj.conf>*/
    CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
    /*<in main.c>*/
    static struct bt_conn_auth_cb conn_auth_callbacks = {
    	.passkey_display=NULL,
    	.passkey_confirm=NULL,
    	.cancel = auth_cancel,
    	.pairing_confirm=NULL,
    And for the fixed passkey use case, the following changes were made
    /*in prj.conf*/
    CONFIG_BT_FIXED_PASSKEY=y
    CONFIG_BT_SMP=y
    /*<in main.c>*/
    	.passkey_display = auth_passkey_display,
    unsigned int passkey = 123456;
    bt_passkey_set(passkey);
    The changes seem to do what I want (ALMOST. there are some issue described below) but I am not sure if these are the right methods. especially to get the Just Works working. Please advise me on that.
    As part of debugging, I went through the smp.c (C:\ncs\v2.1.0\zephyr\subsys\bluetooth\host\smp.c) and that is where I found the CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE configuration option inside the function update_keys_check( ).However, there are some issues here regarding the keys->flags in this function.
    1) When I reflash the device and load the program with the first set of attached changes, I get it all working fine with these logs. Please note that the keys->flags is 0 here.
    *** Booting Zephyr OS build v3.1.99-ncs1  ***
    ## starting mainStarting Nordic UART service example
    Bluetooth initializedConnected 66:53:DE:E0:64:51 (random)
    keys->flags is 0 and smp->flags is 536879924
    Pairing completed: 68:4A:E9:DC:F3:BC (public), bonded: 1
    2) next i reflash the device and load program with second set of attached changes and it works as I expected. Note that the keys->flags is 16.
    keys->flags is 16 and smp->flags is 536879932
    3) If i reflash and load program with the first set of attached changes, it does NOT work as I expected it to (without passkey. it fails on its own). Note that the keys-> flags is now 17.
    Bluetooth initializedConnected 68:4A:E9:DC:F3:BC (public)
    keys->flags is 17 and smp->flags is 536879924
    Pairing failed conn: 68:4A:E9:DC:F3:BC (public), reason 4Disconnected: 68:4A:E9:DC:F3:BC (public) (reason 19)
    What I do not understand is that test case 1 and 3 are the same yet has different values for the keys->flags and I believe this is the reason why I cannot get it correctly working in the third case. Since in the function update_keys_check(), these flags are checked against some conditions.
    I reflash using the Visual studio NRF extension. I erae bonding information in the application too.I believe erasing is part of the visual studio NRF extension and so, I expect the keys->flags to be set to 0 and then updated when a new connection comes to play. But I believe, the values are somehow overwritten. I am not sure if I am in the right direction here.
    NCS version : 2.1.0
    i am sorry for such long message. Can you please take a look at this for me ? Any help would be appreciated. Thanks in advance.
  • Hi Midhunjac,
    To sum up what you described:
    - You have two binary images. One image supports Just work and the other image supports fixed passkey.
    - When you flash the Fixed passkey to replace the Just work (step 2) it worked fine, you can make new bonding
    - When you flash the Just work back to replace the Fixed passkey it didn't work.
    Please be aware that CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y only allow replacement of unauthorized (Just Work) bonding. So you can't replace bonding automatically if the bonding was done with Passkey.
    You would need to clear the bond either by erasing the chip or by the application itself. To make sure you have erased the chip, please use nrfjprog (or nRF Connect for desktop) and erase the chip. In VS Code you need to click the one with 2 arrows on the right hand side not the icon next to the "Flash" text.
    Could you explain what you are trying to achieve ? I thought you want to have a button to allow new bond without passkey. This means one single image can handle Just Work and Passkey depends on the state of the button?
    Do  you still have an issue with my example ?
  • Hi, you are right about my final goal. I want a button press event to allow both Just Work and passkey states. But it does not work. The example that you provided also did not yield any success. The button press events are registered but it does not allow the Just Work method. The two separate images were just part of debugging, to get a better clarity.
    But the summary you derived is not quite right. I will make myself clear.
    • First I flash the Just Works image. It works fine. (No passkey,just bonded fine) (log 1)
    • Next i flashed the Fixed passkey image. It works fine too.(Prompted to enter passkey. If passkey is right, bonded) (log 2)
    • Finally, flash the Just Works image again. This time it does not work as it worked in the first iteration.(log 3)
    As for the extension in VS code, I had been using the icon next to "flash". Maybe that explains my observation in the above three iterations. I will give the icon you mentioned a try and see if the situation changes.
    Can you please elaborate on this ? Or can you point me to a document which explains what this is and its application? This seems to do what I want but somehow it feels like this is not the right way to implement Just Works.
    Also, what is the correct way to get Just Works working ?My characteristics do not require any encryption at all yet Just Works does not seem to work. Thank you for the help.
  • Hi again,
    You can read about the CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE here. For any KConfig configuration you can search there.
    Basically when you enable this option, it allow a device that you already bonded can make another bond. Just like what you did in Step 2 and 3.
    However this option only allow overwriting when the previous bond is UNAUTHORIZED (Just work) At step 3 , the previous bond as Passkey so it not allowed to overwrite the bond without erasing it first.
    Please try to test my example again and list how you tested it and what you observed.
    My suggestion is:
    - First use nRF Connect to connect and bond, you should see a passkey appear and you need to press button 1 on the board to confirm the pass key (numeric comparison)
    - Disconnect
    - Press button 3 to erase bond
    - Press button 4 to change mode
    - Use nRF Connect to connect, then bond. You will see a pop up asking to pair, but no passkey, you don't have to press anything on the DK , only on the phone. This is Just work pairing.
    If you still have issue please try to capture the sniffer trace. You don't need to install the Sniffer API, just need to follow what in the documentation.
    Thank you for the help. It works now as you described above.. Maybe i was using the wrong button for flashing the device in the VS code. There needs to be a few changes though. As I said, my module has a static passkey and the user should enter that passkey to bond. Not the other way round as it is in your example.
    The way I understand, for the module to work like that, we need to set CONFIG_BT_FIXED_PASSKEY and CONFIG_BT_SMP to 'y'. right ?
    But if we do that, is there some way I can switch mode to Just Works during run time as I think that these configuration options blocks the working of Just Works ? I am aware that they are build configurations and may not be modifiable during runtime but is there any chance of achieving this ? Thanks again for helping me through this.
