Hi there.
I am currently learning mqtt_simple from the nrf sdk example. So, I was trying to create a hex file that build using nrf9160, because I can't build it on thingy91, I got error.
Here it the error when I build it for thingy91. (Sorry I can't paste it in code section on the editor, so I just paste it below).
FAILED: zephyr/zephyr.elf zephyr/zephyr.map zephyr/zephyr.hex zephyr/zephyr.bin zephyr/zephyr.meta zephyr/zephyr.lst zephyr/zephyr.stat
cmd.exe /C "cd . && C:\src\nrf\toolchains\v2.1.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj -o zephyr\zephyr.elf -Wl,-T zephyr/linker.cmd -Wl,-Map=C:/nrf/example/mqtt_simple/build_thingy91/mcuboot/zephyr/zephyr_final.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/src/nrf/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v8-m.main/nofp" -LC:/nrf/example/mqtt_simple/build_thingy91/mcuboot/zephyr -lgcc -Wl,--print-memory-usage zephyr/arch/common/libisr_tables.a -no-pie -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn C:/src/nrf/v2.1.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc310_platform_0.9.15.a && cmd.exe /C "cd /D C:\nrf\example\mqtt_simple\build_thingy91\mcuboot\zephyr && C:\src\nrf\toolchains\v2.1.0\opt\bin\cmake.exe -E copy zephyr_final.map zephyr.map && C:\src\nrf\toolchains\v2.1.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objcopy.exe --gap-fill 0xff --output-target=ihex --remove-section=.comment --remove-section=COMMON --remove-section=.eh_frame zephyr.elf zephyr.hex && C:\src\nrf\toolchains\v2.1.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objcopy.exe --gap-fill 0xff --output-target=binary --remove-section=.comment --remove-section=COMMON --remove-section=.eh_frame zephyr.elf zephyr.bin && C:\src\nrf\toolchains\v2.1.0\opt\bin\python.exe C:/src/nrf/v2.1.0/zephyr/scripts/zephyr_module.py --zephyr-base C:/src/nrf/v2.1.0/zephyr --meta-out zephyr.meta && C:\src\nrf\toolchains\v2.1.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objdump.exe -d -S zephyr.elf > zephyr.lst && C:\src\nrf\toolchains\v2.1.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-readelf.exe -e zephyr.elf > zephyr.stat""
Memory region Used Size Region Size %age Used
FLASH: 40140 B 48 KB 81.67%
SRAM: 27008 B 211736 B 12.76%
IDT_LIST: 0 GB 2 KB 0.00%
File "C:/src/nrf/v2.1.0/zephyr/scripts/zephyr_module.py", line 553, in <module>
main()
File "C:/src/nrf/v2.1.0/zephyr/scripts/zephyr_module.py", line 545, in main
meta = process_meta(args.zephyr_base, west_proj, modules,
File "C:/src/nrf/v2.1.0/zephyr/scripts/zephyr_module.py", line 319, in process_meta
if project.sha(MANIFEST_REV_BRANCH) != revision:
File "c:\src\nrf\toolchains\v2.1.0\opt\bin\Lib\site-packages\west\manifest.py", line 861, in sha
cp = self.git(f'rev-parse {rev}^{{commit}}', capture_stdout=True,
File "c:\src\nrf\toolchains\v2.1.0\opt\bin\Lib\site-packages\west\manifest.py", line 845, in git
raise subprocess.CalledProcessError(popen.returncode, cmd_list,
subprocess.CalledProcessError: Command '['rev-parse', 'manifest-rev^{commit}']' returned non-zero exit status 128.
[61/298] Generating ../../tfm/CMakeCache.txt
-- The C compiler identification is GNU 10.3.0
-- Found assembler: C:/src/nrf/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Found Python3: C:/src/nrf/toolchains/v2.1.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
-- Found Python3: C:/src/nrf/toolchains/v2.1.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/src/nrf/v2.1.0/zephyr/.cache
-- Configuring done
-- Generating done
-- Build files have been written to: C:/nrf/example/mqtt_simple/build_thingy91/tfm
[66/298] No configure step for 'tfm'
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
cmd.exe /C "cd /D C:\nrf\example\mqtt_simple\build_thingy91\mcuboot && C:\src\nrf\toolchains\v2.1.0\opt\bin\cmake.exe --build . --"
FATAL ERROR: command exited with status 1: 'c:\src\nrf\toolchains\v2.1.0\opt\bin\cmake.EXE' --build 'c:\nrf\example\mqtt_simple\build_thingy91'
So I am planning to build it only for chip, but when I check it, it just give me this error.
Anybody has solution for this or what should I change in project configuration files? Thank you.
