I have an application and I am using a nrf52833, as soon as i flash my application I am getting a hardfault prior to the main call.
As in below snap:
I do not know what to make of this, kindly suggest.
As in below snap:
Hello Susheel Nuguru,
I was able to debug this further,
Have you made any changes to the pm_static.yaml fil
The below is the static file which works for me:
app:
address: 0xc200
end_address: 0x7e000
region: flash_primary
external_flash:
address: 0x0
end_address: 0x100000
region: external_flash
mcuboot:
address: 0x0
end_address: 0xc000
placement:
before:
- mcuboot_primary
mcuboot_pad:
address: 0xc000
end_address: 0xc200
placement:
before:
- mcuboot_primary_app
mcuboot_primary:
address: 0xc000
orig_span: &id001
- app
- mcuboot_pad
span: *id001
mcuboot_primary_app:
address: 0xc200
orig_span: &id002
- app
span: *id002
mcuboot_secondary:
address: 0x0
device: IS25
end_address: 0x72000
settings_storage:
address: 0x7e000
end_address: 0x80000
placement:
before:
- end
sram_primary:
address: 0x20000000
end_address: 0x20020000
region: sram_primary
I needed to increase memory allocation for mcuboot, as my mcuboot image increased, so I modified the above static file into below, which is causing hardfault:
app:
address: 0x10200
end_address: 0x70000
external_flash:
address: 0x0
mcuboot:
address: 0x0
placement:
before:
- mcuboot_primary
mcuboot_pad:
address: 0x10000
end_address: 0x10200
placement:
before:
mcuboot_primary:
address: 0x10000
orig_span: &id001
- app
- mcuboot_pad
span: *id001
address: 0x10200
orig_span: &id002
- app
span: *id002
mcuboot_secondary:
address: 0x0
device: IS25
end_address: 0x60000
settings_storage:
address: 0x70000
placement:
before:
- end
sram_primary:
address: 0x20000000
Can you suggest now why the modified pm_static.yml file is causing hardfault..?
Ubaid
Ubaid_M said:I needed to increase memory allocation for mcuboot, as my mcuboot image increased, so I modified the above static file into below, which is causing hardfault:
I will request my colleague to help me with this question as to why increasing the mcuboot image size causes the hardfault. Please bare with us for some time while he gets time to respond.
You are using pm_static.yml for all partitions.
The whole point of the partition manager is that you should not have to deal with that yourself. You can only use pm_static.yml to increase the mcuboot partition
(The way my colleague does it is basically build without pm_static.yml, and then copy the part I want (mcuboot) from build/partitions.yml. Then change the size of the things I need. Do not need to know the syntax that way)
another trick is to use below
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
to use external flash, instead of doing this manually.
Can you please try to use the below project and see how the partitions are made based on the given config of the external flash.
mcuboot_smp_feat_external_flash_and_bigger_mcuboot.zip
For me the partitions looks like this
Thanks Susheel Nuguru,
I think I solved it.
Will mark the solution
One last thing, how and where did you get this representation of device memory as in snap you attached:
