Hi all,
I am working on a SDK 15.2 project, and my problem is the following :
I had Legacy Connection Pairing with Passkey, and I am upgrading to Secure Connection Passkey with Bonding.
In normal case, it works correctly. I wanted to test Bonding in limit cases, and more precisely when peers number limit is reached.
Here is my test initial configuration : using pm_peer_new() API, I create peers at device initialization, until returned code is NRF_ERROR_STORAGE_FULL.
Then with pm_next_peer_id_get called multiple times, I count my peers number. After some tests, I observe than this peers number limit can be 86, 87 or 88.
Let's say here the peers number limit is 87, so peers ID from 0 to 86.
After that, I connect a new device ( Android phone ) to my product with NRF Connect, and a new peer ID is created by Peer Manager, 87, and I see on logs than peer ID 0 is deleted.
I can then disconnect and bond correctly.
After that, I connect with another device ( Iphone ) and I can see that this time, Peer ID 87 is deleted and peer ID 0 is created ! Bonding works correctly.
When I will try again to connect with my Android phone, it will of course not work. So I remove bonding info in NRF Connect, and I can pair, and it will delete Peer ID 0 and create Peer ID 87 !
etc...
It doesn't seem to be a normal behavior ! In my head, when Iphone connects to my product, peer ID 1 should be deleted !
I wanted to see if this problem was corrected on last SDK, SDK 17.1.0, so I used a DK, examples\ble_peripheral\ble_app_gls example on last SDK, with my modifications, but same problem is observed.
Do you have an idea on how to resolve this problem ?
Here is code added to gls example in main.c :
static sensorsim_cfg_t m_battery_sim_cfg; /**< Battery Level sensor simulator configuration. */ static sensorsim_state_t m_battery_sim_state; /**< Battery Level sensor simulator state. */ // Variables used to test peer creation static const uint16_t peer_max_number = 300; static bool peer_to_create = false; static bool peer_creation_stop= false; static bool peers_to_count = false; static uint16_t peer_id_cpt = 0; static void advertising_start(bool erase_bonds); static void a_peers_delete( void ); static void a_peer_count( void ); static void a_peer_start_creation( void );
ret_code_t ret;
ret = pm_peers_delete();
printf( "Peers delete ret: %d\n", ret );
ret_code_t ret;
uint32_t peer_number;
pm_peer_id_t peer_list[ peer_max_number ];
pm_peer_data_bonding_t peer_data[peer_max_number];
uint16_t peer_cpt = 0;
memset( peer_list, 0x00, sizeof(pm_peer_id_t) * peer_max_number );
do
peer_list[peer_cpt] = pm_next_peer_id_get( ( ( peer_cpt == 0 )? PM_PEER_ID_INVALID : peer_list[peer_cpt - 1 ] ) );
if( peer_list[peer_cpt] != PM_PEER_ID_INVALID )
//printf( " Peer n°%d\n", peer_list[peer_cpt] );
ret = pm_peer_data_bonding_load( peer_list[peer_cpt], &peer_data[peer_cpt] );
peer_cpt++;
}while( peer_list[ peer_cpt - 1 ] != PM_PEER_ID_INVALID );
NRF_LOG_INFO( "Peers number : %d", (peer_cpt == 0) ? 0 : peer_cpt-1 );
//printf( "Peers number 2 : %d\n", pm_peer_count );
ret_code_t ret;
static pm_peer_id_t peer_id = 0;
pm_peer_data_bonding_t new_peer_data;
pm_store_token_t token;
memset( &new_peer_data, 0x00, sizeof( new_peer_data ) );
new_peer_data.own_role = 0x01;
for( uint8_t i = 0; i < BLE_GAP_ADDR_LEN; i++ )
new_peer_data.peer_ble_id.id_addr_info.addr[i] = peer_id_cpt;
ret = pm_peer_new( &peer_id, &new_peer_data, &token );
if( ret != NRF_SUCCESS )
peer_creation_stop = true;
NRF_LOG_INFO( "Peers created Ret : %d", ret );
a_peer_count();
//printf( "Token value : %s\n", pm_event_str[token] );
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
peer_manager_init();
//a_peers_delete();
//a_peer_count();
a_peer_start_creation();
// Start execution.
NRF_LOG_INFO("Glucose example started.");
application_timers_start();
advertising_start(/*erase_bonds*/false);
// Enter main loop.
for (;;)
idle_state_handle();
if( ( peer_to_create ) && !peer_creation_stop )
peer_id_cpt++;
if( peers_to_count )
a_peer_count();
NRF_LOG_PROCESS();
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
ret_code_t err_code;
pm_handler_on_pm_evt(p_evt);
pm_handler_disconnect_on_sec_failure(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
case PM_EVT_CONN_SEC_SUCCEEDED:
pm_conn_sec_status_t conn_sec_status;
// Check if the link is authenticated (meaning at least MITM).
err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
if (conn_sec_status.mitm_protected)
NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
// The peer did not use MITM, disconnect.
NRF_LOG_INFO("Collector did not use MITM, disconnecting");
err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
err_code = sd_ble_gap_disconnect(m_conn_handle,
} break;
case PM_EVT_CONN_SEC_FAILED:
NRF_LOG_INFO("PM_EVT_PEERS_DELETE_SUCCEEDED");
advertising_start(false);
peers_to_count = true;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Accept pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
NRF_LOG_INFO("PM_EVT_STORAGE_FULL");
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
peer_to_create = true;
* Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_gls_main main.c
* @ingroup ble_sdk_app_gls
* @brief Glucose Meter service Sample Application
* This file contains the source code for a sample application using the Glucose Meter service
* (and also Battery and Device Information services). This application uses the
* @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_dis.h"
#include "ble_bas.h"
#include "ble_gls.h"
#include "ble_racp.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME "Nordic_Glucose" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define MODEL_NUMBER "nRF51" /**< Model Number string. Will be passed to Device Information Service. */
#define MANUFACTURER_ID 0x55AA55AA55 /**< DUMMY Manufacturer ID. Will be passed to Device Information Service. You shall use the ID for your Company*/
#define ORG_UNIQUE_ID 0xEEBBEE /**< DUMMY Organisation Unique ID. Will be passed to Device Information Service. You shall use the Organisation Unique ID relevant for your Company */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL 40 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(10000) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81 /**< Minimum battery level as returned by the simulated measurement function. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum battery level as returned by the simulated measurement function. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Value by which the battery level is incremented/decremented for each call to the simulated measurement function. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(10, UNIT_1_25_MS) /**< Minimum acceptable connection interval (10 ms). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Maximum acceptable connection interval (100 ms) */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAM_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define LESC_DEBUG_MODE 0 /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 1 /**< Man In The Middle protection required (applicable when display module is detected). */
#define SEC_PARAM_LESC 1 /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY /**< Display I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define PASSKEY_TXT "Passkey:" /**< Message to be displayed together with the pass-key. */
#define PASSKEY_TXT_LENGTH 8 /**< Length of message to be displayed together with the pass-key. */
#define PASSKEY_LENGTH 6 /**< Length of pass-key received by the stack for display. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_BAS_DEF(m_bas); /**< Structure used to identify the battery service. */
BLE_GLS_DEF(m_gls); /**< Structure used to identify the glucose service. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id); /**< Battery timer. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
NRF_SDH_BLE_PERIPHERAL_LINK_COUNT,
NRF_BLE_GQ_QUEUE_SIZE);
static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_GLUCOSE_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
p_evt->conn_handle,
} break;
} break;
/**@brief Function for handling Service errors.
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
* in Battery Service.
static void battery_level_update(void)
uint8_t battery_level;
battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
battery_level_update();
/**@brief Function for updating glucose measurement and updating glucose characteristic in Glucose.
Service.
static void read_glucose_measurement(void)
ble_gls_rec_t rec;
uint32_t err_code;
static int16_t s_mantissa = 550;
static int16_t s_exponent = -3;
static uint8_t s_secs = 5;
// simulate the reading of a glucose measurement.
rec.meas.flags = BLE_GLS_MEAS_FLAG_TIME_OFFSET |
BLE_GLS_MEAS_FLAG_CONC_TYPE_LOC |
BLE_GLS_MEAS_FLAG_UNITS_MOL_L;
rec.meas.base_time.year = 2012;
rec.meas.base_time.month = 1;
rec.meas.base_time.day = 1;
rec.meas.base_time.hours = 12;
rec.meas.base_time.minutes = 30;
rec.meas.base_time.seconds = s_secs;
rec.meas.glucose_concentration.exponent = s_exponent;
rec.meas.glucose_concentration.mantissa = s_mantissa;
rec.meas.time_offset = 0;
rec.meas.type = BLE_GLS_MEAS_TYPE_CAP_BLOOD;
rec.meas.sample_location = BLE_GLS_MEAS_LOC_FINGER;
rec.meas.sensor_status_annunciation = 0;
// change values for next read.
s_mantissa += 23;
if (s_mantissa > 939)
s_mantissa -= 434;
s_secs += 3;
if (s_secs > 59)
s_secs = 0;
err_code = ble_gls_glucose_new_meas(&m_gls, &rec);
if (err_code != NRF_SUCCESS)
// Do nothing.
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
err_code = app_timer_init();
// Create timers.
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_GLUCOSE_METER);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* @details Initialize the Glucose, Battery and Device Information services.
ble_gls_init_t gls_init;
ble_dis_init_t dis_init;
ble_bas_init_t bas_init;
// Initialize Glucose Service - sample selection of feature bits.
memset(&gls_init, 0, sizeof(gls_init));
gls_init.evt_handler = NULL;
gls_init.p_gatt_queue = &m_ble_gatt_queue;
gls_init.error_handler = service_error_handler;
gls_init.feature = 0;
gls_init.feature |= BLE_GLS_FEATURE_LOW_BATT;
gls_init.feature |= BLE_GLS_FEATURE_TEMP_HIGH_LOW;
gls_init.feature |= BLE_GLS_FEATURE_GENERAL_FAULT;
gls_init.is_context_supported = false;
// Here the sec level for the Glucose Service can be changed/increased.
gls_init.gl_meas_cccd_wr_sec = SEC_JUST_WORKS;
gls_init.gl_feature_rd_sec = SEC_JUST_WORKS;
gls_init.racp_cccd_wr_sec = SEC_JUST_WORKS;
gls_init.racp_wr_sec = SEC_JUST_WORKS;
err_code = ble_gls_init(&m_gls, &gls_init);
// Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
bas_init.bl_rd_sec = SEC_OPEN;
bas_init.bl_cccd_wr_sec = SEC_OPEN;
bas_init.bl_report_rd_sec = SEC_OPEN;
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
ble_srv_ascii_to_utf8(&dis_init.serial_num_str, MODEL_NUMBER);
ble_dis_sys_id_t system_id;
system_id.manufacturer_id = MANUFACTURER_ID;
system_id.organizationally_unique_id = ORG_UNIQUE_ID;
dis_init.p_sys_id = &system_id;
dis_init.dis_char_rd_sec = SEC_OPEN;
err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
m_battery_sim_cfg.start_at_max = true;
sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
// Start application timers.
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameter events.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail configuration parameter, but instead we use the
* event handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAM_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
ret_code_t err_code;;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising");
break; // BLE_ADV_EVT_FAST
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
break; // BLE_ADV_EVT_IDLE
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
pm_handler_secure_on_connection(p_ble_evt);
NRF_LOG_INFO("Disconnected");
// Check if the last connected peer had not used MITM, if so, delete its bond information.
if (m_peer_to_be_deleted != PM_PEER_ID_INVALID)
err_code = pm_peer_delete(m_peer_to_be_deleted);
NRF_LOG_DEBUG("Collector's bond deleted");
} break;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
// Start Security Request timer.
} break;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
case BLE_GAP_EVT_PASSKEY_DISPLAY:
char passkey[PASSKEY_LENGTH + 1];
memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, PASSKEY_LENGTH);
passkey[PASSKEY_LENGTH] = 0;
NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
} break;
case BLE_GAP_EVT_AUTH_KEY_REQUEST:
NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
case BLE_GAP_EVT_AUTH_STATUS:
NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
p_ble_evt->evt.gap_evt.params.auth_status.bonded,
p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
*((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
* @param[in] event Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_WHITELIST_OFF
case BSP_EVENT_KEY_1:
read_glucose_measurement();
break; // BSP_EVENT_KEY_1
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
err_code = nrf_ble_lesc_request_handler();
nrf_pwr_mgmt_run();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
ret_code_t ret;
ret_code_t ret;
do
//printf( " Peer nďż˝%d\n", peer_list[peer_cpt] );
peer_cpt++;
ret_code_t ret;
a_peer_count();
bool erase_bonds;
// Initialize.
log_init();
timers_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
conn_params_init();
//a_peers_delete();
//a_peer_count();
// Start execution.
// Enter main loop.
for (;;)
peer_id_cpt++;
a_peer_count();
NRF_LOG_PROCESS();
