nrf52840 Radio Co-Processor with STM32L486 host processor
I have the next system perfectly working:
  • nRF52840 working as NCP to get OpenThread protocol.
  • STM32L486 as a host with a FreeRTOS
  • The communication between both is via UART working with SPINEL
I want to implement multiprotocol support (OpenThread + BLE). I have discovered your nRF Connect SDK v2.1.2 but I have the next problems/questions:
1º) The only sample to implement NCP is with Zephyr?
2º) Is this sample what i have to implement to support multiprotocol?
3º) Which BLE sample can I use to support multiprotocol?
4º) Is spinel implemented in any sample of the previously listed?
Thanks
    See Multiprotocol support.
    I think so as well, yes. Our Thread: Co-processor sample only supports RCP.
    Our Thread Coap Client and CLI samples support multi-protocol alongside Bluetooth Low Energy. I would start there.
    See the previous answer.
    I have not tested it, but from the Thread: Co-processors prj.conf:
    CONFIG_LOG_BACKEND_SPINEL=y
    So I am inclined to think that spinel is used here.
    Sigurd Hellesvik
  • Hi Sigurd!
    Anyway I need an option with NCP and these don't support it, right?
    In the hypothetical case of being able to implement RCP, if I want to implement CLI sample... Do I need a linux host to stablish a command line communication with the co-processor?
    What option do Nordic offer to me if I need an NCP co-processor and my host is a microcontroller?
    That is right, but you can use the multiprotocol-configurations from either of these to add multiprotocol to the Zephyr NCP sample.
    I built and flashed a nRF52840DK with the Zephyr NCP sample.
    I were able to control this using spinel-cli.py on a linux PC. But since it uses spinel, I would guess the microcontroller host would also be able to control it.
    I did not do the merge though, you will have to that yourself.
    See the above answer for my suggestion to do NCP.
    Another solution is to use the nRF52840 not as a co-processor, but as a fully functional microcontroller with OpenThread support. It has a Arm cortex-M4 core and a good selection of peripherals after all.
    Then you can use an interface of your choosing (SPI/I2C/UART) to communicate between the STM32 and nRF52840.
    I do not understand this question.
    Can you elaborate a bit?
    Sigurd Hellesvik
