Don't compile example peripheral/uart for custom board NRF52811 VS Code
I receive error
Compiling file: main.c
../../../main.c: In function 'main':
../../../main.c:150:11: error: unsigned conversion from 'int' to 'enum <anonymous>' changes value from '30924800' to '0' [-Werror=overflow]
  150 |           NRF_UART_BAUDRATE_115200
cc1.exe: all warnings being treated as errors
I have custom board with nrf52811
#include "nrf_gpio.h"
#define LEDS_NUMBER    1
#define LED_START      4
#define LED_1          4
#define LEDS_ACTIVE_STATE 1
#define LEDS_INV_MASK  LEDS_MASK
#define LEDS_LIST { LED_1 }
#define BSP_LED_0      LED_1
#define BUTTONS_NUMBER 4
#define BUTTON_START   16
#define BUTTON_1       16
#define BUTTON_PULL    NRF_GPIO_PIN_PULLUP
#define BUTTONS_ACTIVE_STATE 0
#define BUTTONS_LIST { BUTTON_1 }
#define BSP_BUTTON_0   BUTTON_1
#define RX_PIN_NUMBER  18
#define TX_PIN_NUMBER  20
#define CTS_PIN_NUMBER 7
#define RTS_PIN_NUMBER 5
#define HWFC           false
my defines in .vscode/c_cpp_properties.json
"defines": [
                "_DEBUG",
                "BOARD_CUSTOM_NRF52811",
                "BSP_DEFINES_ONLY",
                "CONFIG_GPIO_AS_PINRESET",
                "FLOAT_ABI_SOFT",
                "NRF52811_XXAA",
                "UART_PRESENT"
and my custom MakeFile
PROJECT_NAME     := uart_BOARD_myCustom
TARGETS          := nrf52811_xxaa
OUTPUT_DIRECTORY := _build
SDK_ROOT := ../../../../../..
PROJ_DIR := ../../..
$(OUTPUT_DIRECTORY)/nrf528111_xxaa.out: \
  LINKER_SCRIPT  := uart_gcc_nrf52.ld
# Source files common to all targets
SRC_FILES += \
  $(SDK_ROOT)/modules/nrfx/mdk/gcc_startup_nrf52811.S \
  $(SDK_ROOT)/components/libraries/log/src/nrf_log_frontend.c \
  $(SDK_ROOT)/components/libraries/log/src/nrf_log_str_formatter.c \
  $(SDK_ROOT)/components/boards/boards.c \
  $(SDK_ROOT)/components/libraries/util/app_error.c \
  $(SDK_ROOT)/components/libraries/util/app_error_handler_gcc.c \
  $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
  $(SDK_ROOT)/components/libraries/fifo/app_fifo.c \
  $(SDK_ROOT)/components/libraries/uart/app_uart_fifo.c \
  $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
  $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
  $(SDK_ROOT)/components/libraries/atomic/nrf_atomic.c \
  $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
  $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
  $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
  $(SDK_ROOT)/components/libraries/memobj/nrf_memobj.c \
  $(SDK_ROOT)/components/libraries/ringbuf/nrf_ringbuf.c \
  $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
  $(SDK_ROOT)/components/libraries/uart/retarget.c \
  $(SDK_ROOT)/integration/nrfx/legacy/nrf_drv_uart.c \
  $(SDK_ROOT)/modules/nrfx/soc/nrfx_atomic.c \
  $(SDK_ROOT)/modules/nrfx/drivers/src/prs/nrfx_prs.c \
  $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uart.c \
  $(SDK_ROOT)/modules/nrfx/drivers/src/nrfx_uarte.c \
  $(PROJ_DIR)/main.c \
  $(SDK_ROOT)/modules/nrfx/mdk/system_nrf52811.c \
# Include folders common to all targets
INC_FOLDERS += \
  $(SDK_ROOT)/components \
  $(SDK_ROOT)/modules/nrfx/mdk \
  $(PROJ_DIR) \
  $(SDK_ROOT)/components/libraries/fifo \
  $(SDK_ROOT)/components/libraries/strerror \
  $(SDK_ROOT)/components/toolchain/cmsis/include \
  $(SDK_ROOT)/components/libraries/util \
  ../config \
  $(SDK_ROOT)/components/libraries/balloc \
  $(SDK_ROOT)/components/libraries/ringbuf \
  $(SDK_ROOT)/modules/nrfx/hal \
  $(SDK_ROOT)/components/libraries/bsp \
  $(SDK_ROOT)/components/libraries/uart \
  $(SDK_ROOT)/components/libraries/log \
  $(SDK_ROOT)/modules/nrfx \
  $(SDK_ROOT)/components/libraries/experimental_section_vars \
  $(SDK_ROOT)/integration/nrfx/legacy \
  $(SDK_ROOT)/components/libraries/delay \
  $(SDK_ROOT)/integration/nrfx \
  $(SDK_ROOT)/components/drivers_nrf/nrf_soc_nosd \
  $(SDK_ROOT)/components/libraries/atomic \
  $(SDK_ROOT)/components/boards \
  $(SDK_ROOT)/components/libraries/memobj \
  $(SDK_ROOT)/modules/nrfx/drivers/include \
  $(SDK_ROOT)/external/fprintf \
  $(SDK_ROOT)/components/libraries/log/src \
# Libraries common to all targets
LIB_FILES += \
# Optimization flags
OPT = -O3 -g3
# Uncomment the line below to enable link time optimization
#OPT += -flto
# C flags common to all targets
CFLAGS += $(OPT)
CFLAGS += -DBOARD_CUSTOM_NRF52811
CFLAGS += -DBSP_DEFINES_ONLY
CFLAGS += -DCONFIG_GPIO_AS_PINRESET
CFLAGS += -DFLOAT_ABI_SOFT
CFLAGS += -DNRF52811_XXAA
CFLAGS += -mcpu=cortex-m4
CFLAGS += -mthumb -mabi=aapcs
CFLAGS += -Wall -Werror
CFLAGS += -mfloat-abi=soft
# keep every function in a separate section, this allows linker to discard unused ones
CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
CFLAGS += -fno-builtin -fshort-enums
# C++ flags common to all targets
CXXFLAGS += $(OPT)
# Assembler flags common to all targets
ASMFLAGS += -g3
ASMFLAGS += -mcpu=cortex-m4
ASMFLAGS += -mthumb -mabi=aapcs
ASMFLAGS += -mfloat-abi=soft
ASMFLAGS += -DBOARD_CUSTOM_NRF52811
ASMFLAGS += -DBSP_DEFINES_ONLY
ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
ASMFLAGS += -DDEVELOP_IN_NRF52811
ASMFLAGS += -DFLOAT_ABI_SOFT
ASMFLAGS += -DNRF52811_XXAA
# Linker flags
LDFLAGS += $(OPT)
LDFLAGS += -mthumb -mabi=aapcs -L$(SDK_ROOT)/modules/nrfx/mdk -T$(LINKER_SCRIPT)
LDFLAGS += -mcpu=cortex-m4
# let linker dump unused sections
LDFLAGS += -Wl,--gc-sections
# use newlib in nano version
LDFLAGS += --specs=nano.specs
nrf52811_xxaa: CFLAGS += -D__HEAP_SIZE=2048
nrf52811_xxaa: CFLAGS += -D__STACK_SIZE=2048
nrf52811_xxaa: ASMFLAGS += -D__HEAP_SIZE=2048
nrf52811_xxaa: ASMFLAGS += -D__STACK_SIZE=2048
# Add standard libraries at the very end of the linker input, after all objects
# that may need symbols provided by these libraries.
LIB_FILES += -lc -lnosys -lm
.PHONY: default help
# Default target - first one defined
default: nrf52811_xxaa
# Print all targets that can be built
help:
	@echo following targets are available:
	@echo		nrf52811_xxaa
	@echo		sdk_config - starting external tool for editing sdk_config.h
	@echo		flash      - flashing binary
TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
include $(TEMPLATE_PATH)/Makefile.common
$(foreach target, $(TARGETS), $(call define_target, $(target)))
.PHONY: flash erase
# Flash the program
flash: default
	@echo Flashing: $(OUTPUT_DIRECTORY)/nrf52811_xxaa.hex
	nrfjprog -f nrf52 --program $(OUTPUT_DIRECTORY)/nrf52811_xxaa.hex --sectorerase
	nrfjprog -f nrf52 --reset
erase:
	nrfjprog -f nrf52 --eraseall
SDK_CONFIG_FILE := ../config/sdk_config.h
CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
sdk_config:
	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
I use nRF5_SDK_17.1.0_ddde560 , ARM GCC arm-none-eabi 10.3.1, make from chocolate  on windows
I tested my board, apps with example peripheral/blinky - it work correctly
But I don't know how to solve this problem
Thanks
  • I updated my makefile
    CFLAGS += $(OPT)
    CXXFLAGS += $(OPT)
    ASMFLAGS += -g3
    # Linker flags
    LDFLAGS += $(OPT)
    And now I received these errors:
    c:/program files (x86)/gnu arm embedded toolchain/10 2021.10/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: _build/nrf52811_xxaa/nrfx_uarte.c.o: in function `UARTE0_UART0_IRQHandler':
    D:\Nordic\nRF5_SDK_17.1.0_ddde560\examples\peripheral\uart\my_custom_board_nrf52811\blank\armgcc/../../../../../../modules/nrfx/drivers/src/nrfx_uarte.c:676: multiple definition of `UARTE0_UART0_IRQHandler'; _build/nrf52811_xxaa/nrfx_uart.c.o:D:\Nordic\nRF5_SDK_17.1.0_ddde560\examples\peripheral\uart\my_custom_board_nrf52811\blank\armgcc/../../../../../../modules/nrfx/drivers/src/nrfx_uart.c:649: first defined here
    collect2.exe: error: ld returned 1 exit status
    make: *** [../../../../../../components/toolchain/gcc/Makefile.common:294: _build/nrf52811_xxaa.out] Error 1
    PS D:\Nordic\nRF5_SDK_17.1.0_ddde560\examples\peripheral\uart\my_custom_board_nrf52811\blank\armgcc>
    But I tried this code on NRF52832 and it was workedm but on NRF52811 still don't work.
  • I added flag in MakeFile
    CFLAGS += -UART_PRESENT
    And useed right file sdk_config.h from PCA10056e
