CONFIG_MCUMGR_SMP_UART disables CONFIG_UART_0_ASYNC
Hello everyone.
I'm using the nRF Connect SDK v1.6.1 (it's an old project) on a nRF5340. Our project is based on the central_bas sample.
I want to use MCUBoot to update the application in the field.
I added the necessary configs to the prj.conf of both our central_bas project as well as the MCUBoot project.
Now whenever I add "CONFIG_MCUMGR_SMP_UART=y" to the prj.conf of the central_bas project, it sets CONFIG_UART_0_ASYNC (everything applies to UART_1 as well) to false (or "n") and won't let me change it. Adding "CONFIG_UART_0_ASYNC=y" in the prj.conf does not change anything and I can't change it via "Configure nRF Connect SDK Project..." in Segger Embedded Studio as it is greyed out there.
Without "CONFIG_UART_0_ASYNC" our UART init fails during startup of our application.
What causes "CONFIG_MCUMGR_SMP_UART" to disable and lock "CONFIG_UART_0_ASYNC"?
Alex
prj.conf of central_bas:
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
# was before CONFIG_HEAP_MEM_POOL_SIZE=1024
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT_BAS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_PRIVACY=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_DK_LIBRARY=y
### START added from peripheral_UART example ###
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_NRFX_UARTE1=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is not printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
### END added from peripheral_UART example ###
# Enable nordic security backend and PSA APIs
CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
CONFIG_NORDIC_SECURITY_BACKEND=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=8192
### Added MCUBoot as first-stage bootloader ###
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMAGE_VERSION="1.3.0+1"	# maj.min.rev+build
#CONFIG_BOOT_SIGNATURE_KEY_FILE="privMCUBoot.pem"
#CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT=y	# available in NCS v2.0.0 and above
# Enable mcumgr.
CONFIG_MCUMGR=y
# Enable most core commands.
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
# Enable the serial mcumgr transport.
CONFIG_UART_MCUMGR_ON_DEV_NAME="UART_0"
#CONFIG_UART_0_ASYNC=y
#CONFIG_UART_1_ASYNC=y
# Some command handlers require a large stack. Important for mcumgr, would otherwise timeout
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
### "UART_0" is the default value, other values like "UARTE_0" or "UART_1" prohibit output
#CONFIG_UART_CONSOLE_ON_DEV_NAME="UART_0"
### Fixed necessary project config ###
#CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
#CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
#CONFIG_SOC_LFXO_CAP_EXTERNAL=y
#CONFIG_SOC_HFXO_CAP_EXTERNAL=y
#CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=n
#CONFIG_NRFX_CLOCK=y
### End of necessary project config ###
prj.conf of MCUBoot:
#CONFIG_CONSOLE_HANDLER=y
#CONFIG_SYSTEM_CLOCK_DISABLE=y
#CONFIG_SYS_POWER_MANAGEMENT=n
CONFIG_PM=n
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
CONFIG_BOOT_ENCRYPT_RSA=n
CONFIG_BOOT_ENCRYPT_EC256=n
CONFIG_BOOT_ENCRYPT_X25519=n
CONFIG_BOOT_UPGRADE_ONLY=n
CONFIG_BOOT_BOOTSTRAP=n
### mbedTLS has its own heap
# CONFIG_HEAP_MEM_POOL_SIZE is not set
### We never want Zephyr's copy of tinycrypt.  If tinycrypt is needed,
### MCUboot has its own copy in tree.
# CONFIG_TINYCRYPT is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
# CONFIG_TINYCRYPT_SHA256 is not set
CONFIG_FLASH=y
CONFIG_FPROTECT=y
### Various Zephyr boards enable features that we don't want.
# CONFIG_BT is not set
# CONFIG_BT_CTLR is not set
# CONFIG_I2C is not set
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
### Ensure Zephyr logging changes don't use more resources
CONFIG_LOG_DEFAULT_LEVEL=0
### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
CONFIG_CBPRINTF_NANO=y
### Added for compatibility with our central_bas ###
CONFIG_BOOT_DIRECT_XIP=y
### Should be "y" per default, CONFIG_SERIAL=n disables the output from MCUBoot
#CONFIG_SERIAL=y
Devicetree overlay of central_bas:
&uart0
{         tx-pin = < 0x1c >;         rx-pin = < 0x1a >;         rts-pin = < 0x1e >;         cts-pin = < 0x1f >; }
&uart1
{      status = "okay";      current-speed = < 0x1c200 >;     tx-pin = < 0x22 >;     rx-pin = < 0x0d >;  }
&i2c1
{     sda-pin = < 0x16 >;     scl-pin = < 0x17 >;     status = "disabled"; }
&pwm0
{     ch0-pin = < 0x10 >; }
&qspi
{    io-pins = < 0xf >;     status = "disabled"; }
  leds {
          compatible = "gpio-leds";
          led0: led_0
{                   gpios = < &gpio0 0x13 0x1 >;                   label = "Green LED 0";           }
          led1: led_1
{                   gpios = < &gpio0 0x15 0x1 >;                   label = "Green LED 1";           }
          led2: led_2
{                   gpios = < &gpio1 0x08 0x1 >;                   label = "Green LED 2";           }
          led3: led_3
{                   gpios = < &gpio1 0x06 0x1 >;                   label = "Green LED 3";           }
          led4: led_4
{                   gpios = < &gpio1 0x04 0x1 >;                   label = "Green LED 4";           }
  aliases
{           led0 = &led0;           led1 = &led1;           led2 = &led2;           led3 = &led3;           led4 = &led4;           pwm-led0 = &pwm_led0;           sw0 = &button0;           sw1 = &button1;           sw2 = &button2;           sw3 = &button3;           bootloader-led0 = &led0;    }
Devicetree overlay of MCUBoot:
	chosen {
		zephyr,code-partition = &boot_partition;
&uart0
&uart1
&i2c1
&pwm0
&qspi
  leds {
          led0: led_0
          led1: led_1
          led2: led_2
          led3: led_3
          led4: led_4
  aliases
