GFX Library print fucnction
Hollo
Im using the GFX example,  want to print string and to clear the screen , i use screen_clear(); function,  this is default function gfx example
this is the loop
can be so fast?
do i need to implement a buffer?
or whats is the problem?
thanks a regards
  • Hello karl
    thanks for you reply
    I could print fast the image and text . i saw other example  with nrf51
    st7735 with nrf51 this link is for image print
    Controlling ST7789 LCD with NRF52 DK this post to text fast
    I adapted it into my code, it works
    thank you for you support
  • Thank you for sharing the solution you found - I am happy to read that you've now got it working as you had intended! :)
    Please do not hesitate to open another ticket if you should encounter any issues or questions in the future.
    Karl
