Hi:
i use the application note nA34's python file (dtm.py) to perform DTM PER test among 2 nRf52840 DK.
and in the LE_Test_Setup command ( the only set command which upper tester can send to DUT for setting some parameters),
control bit 0x09 & parameters ( 8bits) can be used to set transmitter to the specified or nearest transmit power level: -127 to 20 dBm.
Question 1:
is it ok to set nRF52840's Tx power to this range -127~+20dBm? ( i am trying to find the Rx sensitivity, so i have to adjust the. tx power)
Question 2:
and how to read the receiver Rx power by The UART command?
i didn't use the dtm.c to perform this test because i am not familiar with C, but i think they're doing the same thing?
thank you!!!
