Hello there,
I tried combining the GNSS simple sample code to my edited version of the MQTT simple sample code and I am unable to build anything. I am getting this error.
( I have configured prj.conf and kconfig files for gnss as well)
* Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <stdio.h>
#include <zephyr/drivers/uart.h>
#include <string.h>
#include <zephyr/random/rand32.h>
#include <zephyr/net/mqtt.h>
#include <zephyr/net/socket.h>
// frome here: these are modules used for gnss
#include <stdlib.h>
#include <math.h>
#include <nrf_modem_gnss.h>
#include <date_time.h>
// to here: end
#if defined(CONFIG_NRF_MODEM_LIB)
#include <nrf_modem_at.h>
#endif /* CONFIG_NRF_MODEM_LIB */
#include <modem/lte_lc.h>
#if defined(CONFIG_MODEM_KEY_MGMT)
#include <modem/modem_key_mgmt.h>
#if defined(CONFIG_LWM2M_CARRIER)
#include <lwm2m_carrier.h>
#include <dk_buttons_and_leds.h>
#include "certificates.h"
// Start: All of the code below this line is in relation to the GNSS code
#define PI 3.14159265358979323846
#define EARTH_RADIUS_METERS (6371.0 * 1000.0)
#if !defined(CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE) || defined(CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST)
static struct k_work_q gnss_work_q;
#define GNSS_WORKQ_THREAD_STACK_SIZE 2304
#define GNSS_WORKQ_THREAD_PRIORITY 5
K_THREAD_STACK_DEFINE(gnss_workq_stack_area, GNSS_WORKQ_THREAD_STACK_SIZE);
#endif /* !CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE || CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST */
#include "assistance.h"
static struct nrf_modem_gnss_agps_data_frame last_agps;
static struct k_work agps_data_get_work;
static volatile bool requesting_assistance;
#endif /* !CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE */
#if defined(CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST)
static struct k_work_delayable ttff_test_got_fix_work;
static struct k_work_delayable ttff_test_prepare_work;
static struct k_work ttff_test_start_work;
static uint32_t time_to_fix;
static const char update_indicator[] = {'\\', '|', '/', '-'};
static struct nrf_modem_gnss_pvt_data_frame last_pvt;
static uint64_t fix_timestamp;
static uint32_t time_blocked;
/* Reference position. */
static bool ref_used;
static double ref_latitude;
static double ref_longitude;
K_MSGQ_DEFINE(nmea_queue, sizeof(struct nrf_modem_gnss_nmea_data_frame *), 10, 4);
static K_SEM_DEFINE(pvt_data_sem, 0, 1);
static K_SEM_DEFINE(time_sem, 0, 1);
static struct k_poll_event events[2] = {
K_POLL_EVENT_STATIC_INITIALIZER(K_POLL_TYPE_SEM_AVAILABLE,
K_POLL_MODE_NOTIFY_ONLY,
&pvt_data_sem, 0),
K_POLL_EVENT_STATIC_INITIALIZER(K_POLL_TYPE_MSGQ_DATA_AVAILABLE,
&nmea_queue, 0),
BUILD_ASSERT(IS_ENABLED(CONFIG_LTE_NETWORK_MODE_LTE_M_GPS) ||
IS_ENABLED(CONFIG_LTE_NETWORK_MODE_NBIOT_GPS) ||
IS_ENABLED(CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS),
"CONFIG_LTE_NETWORK_MODE_LTE_M_GPS, "
"CONFIG_LTE_NETWORK_MODE_NBIOT_GPS or "
"CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS must be enabled");
BUILD_ASSERT((sizeof(CONFIG_GNSS_SAMPLE_REFERENCE_LATITUDE) == 1 &&
sizeof(CONFIG_GNSS_SAMPLE_REFERENCE_LONGITUDE) == 1) ||
(sizeof(CONFIG_GNSS_SAMPLE_REFERENCE_LATITUDE) > 1 &&
sizeof(CONFIG_GNSS_SAMPLE_REFERENCE_LONGITUDE) > 1),
"CONFIG_GNSS_SAMPLE_REFERENCE_LATITUDE and "
"CONFIG_GNSS_SAMPLE_REFERENCE_LONGITUDE must be both either set or empty");
/* Returns the distance between two coordinates in meters. The distance is calculated using the
* haversine formula.
static double distance_calculate(double lat1, double lon1,
double lat2, double lon2)
double d_lat_rad = (lat2 - lat1) * PI / 180.0;
double d_lon_rad = (lon2 - lon1) * PI / 180.0;
double lat1_rad = lat1 * PI / 180.0;
double lat2_rad = lat2 * PI / 180.0;
double a = pow(sin(d_lat_rad / 2), 2) +
pow(sin(d_lon_rad / 2), 2) *
cos(lat1_rad) * cos(lat2_rad);
double c = 2 * asin(sqrt(a));
return EARTH_RADIUS_METERS * c;
static void print_distance_from_reference(struct nrf_modem_gnss_pvt_data_frame *pvt_data)
if (!ref_used)
return;
double distance = distance_calculate(pvt_data->latitude, pvt_data->longitude,
ref_latitude, ref_longitude);
if (IS_ENABLED(CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST))
LOG_INF("Distance from reference: %.01f", distance);
printf("\nDistance from reference: %.01f\n", distance);
static void gnss_event_handler(int event)
int retval;
struct nrf_modem_gnss_nmea_data_frame *nmea_data;
switch (event)
case NRF_MODEM_GNSS_EVT_PVT:
retval = nrf_modem_gnss_read(&last_pvt, sizeof(last_pvt), NRF_MODEM_GNSS_DATA_PVT);
if (retval == 0)
k_sem_give(&pvt_data_sem);
case NRF_MODEM_GNSS_EVT_FIX:
/* Time to fix is calculated here, but it's printed from a delayed work to avoid
* messing up the NMEA output.
time_to_fix = (k_uptime_get() - fix_timestamp) / 1000;
k_work_schedule_for_queue(&gnss_work_q, &ttff_test_got_fix_work, K_MSEC(100));
k_work_schedule_for_queue(&gnss_work_q, &ttff_test_prepare_work,
K_SECONDS(CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST_INTERVAL));
#endif /* CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST */
case NRF_MODEM_GNSS_EVT_NMEA:
nmea_data = k_malloc(sizeof(struct nrf_modem_gnss_nmea_data_frame));
if (nmea_data == NULL)
LOG_ERR("Failed to allocate memory for NMEA");
retval = nrf_modem_gnss_read(nmea_data,
sizeof(struct nrf_modem_gnss_nmea_data_frame),
NRF_MODEM_GNSS_DATA_NMEA);
if (retval == 0)
retval = k_msgq_put(&nmea_queue, &nmea_data, K_NO_WAIT);
if (retval != 0)
k_free(nmea_data);
case NRF_MODEM_GNSS_EVT_AGPS_REQ:
retval = nrf_modem_gnss_read(&last_agps,
sizeof(last_agps),
NRF_MODEM_GNSS_DATA_AGPS_REQ);
if (retval == 0)
k_work_submit_to_queue(&gnss_work_q, &agps_data_get_work);
#if defined(CONFIG_GNSS_SAMPLE_LTE_ON_DEMAND)
K_SEM_DEFINE(lte_ready, 0, 1);
static void lte_lc_event_handler(const struct lte_lc_evt *const evt)
switch (evt->type)
case LTE_LC_EVT_NW_REG_STATUS:
if ((evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME) ||
(evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_ROAMING))
LOG_INF("Connected to LTE network");
k_sem_give(<e_ready);
void lte_connect(void)
int err;
LOG_INF("Connecting to LTE network");
err = lte_lc_func_mode_set(LTE_LC_FUNC_MODE_ACTIVATE_LTE);
if (err)
LOG_ERR("Failed to activate LTE, error: %d", err);
return;
k_sem_take(<e_ready, K_FOREVER);
/* Wait for a while, because with IPv4v6 PDN the IPv6 activation takes a bit more time. */
k_sleep(K_SECONDS(1));
void lte_disconnect(void)
int err;
err = lte_lc_func_mode_set(LTE_LC_FUNC_MODE_DEACTIVATE_LTE);
if (err)
LOG_ERR("Failed to deactivate LTE, error: %d", err);
return;
LOG_INF("LTE disconnected");
#endif /* CONFIG_GNSS_SAMPLE_LTE_ON_DEMAND */
static void agps_data_get_work_fn(struct k_work *item)
ARG_UNUSED(item);
int err;
#if defined(CONFIG_GNSS_SAMPLE_ASSISTANCE_SUPL)
/* SUPL doesn't usually provide satellite real time integrity information. If GNSS asks
* only for satellite integrity, the request should be ignored.
if (last_agps.sv_mask_ephe == 0 &&
last_agps.sv_mask_alm == 0 &&
last_agps.data_flags == NRF_MODEM_GNSS_AGPS_INTEGRITY_REQUEST)
LOG_INF("Ignoring assistance request for only satellite integrity");
return;
#endif /* CONFIG_GNSS_SAMPLE_ASSISTANCE_SUPL */
#if defined(CONFIG_GNSS_SAMPLE_ASSISTANCE_MINIMAL)
/* With minimal assistance, the request should be ignored if no GPS time or position
* is requested.
if (!(last_agps.data_flags & NRF_MODEM_GNSS_AGPS_SYS_TIME_AND_SV_TOW_REQUEST) &&
!(last_agps.data_flags & NRF_MODEM_GNSS_AGPS_POSITION_REQUEST))
LOG_INF("Ignoring assistance request because no GPS time or position is requested");
return;
#endif /* CONFIG_GNSS_SAMPLE_ASSISTANCE_MINIMAL */
requesting_assistance = true;
LOG_INF("Assistance data needed, ephe 0x%08x, alm 0x%08x, flags 0x%02x",
last_agps.sv_mask_ephe,
last_agps.sv_mask_alm,
last_agps.data_flags);
lte_connect();
err = assistance_request(&last_agps);
if (err)
LOG_ERR("Failed to request assistance data");
lte_disconnect();
requesting_assistance = false;
static void ttff_test_got_fix_work_fn(struct k_work *item)
LOG_INF("Time to fix: %u", time_to_fix);
if (time_blocked > 0)
LOG_INF("Time GNSS was blocked by LTE: %u", time_blocked);
print_distance_from_reference(&last_pvt);
LOG_INF("Sleeping for %u seconds", CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST_INTERVAL);
static int ttff_test_force_cold_start(void)
int err;
uint32_t delete_mask;
LOG_INF("Deleting GNSS data");
/* Delete everything else except the TCXO offset. */
delete_mask = NRF_MODEM_GNSS_DELETE_EPHEMERIDES |
NRF_MODEM_GNSS_DELETE_ALMANACS |
NRF_MODEM_GNSS_DELETE_IONO_CORRECTION_DATA |
NRF_MODEM_GNSS_DELETE_LAST_GOOD_FIX |
NRF_MODEM_GNSS_DELETE_GPS_TOW |
NRF_MODEM_GNSS_DELETE_GPS_WEEK |
NRF_MODEM_GNSS_DELETE_UTC_DATA |
NRF_MODEM_GNSS_DELETE_GPS_TOW_PRECISION;
/* With minimal assistance, we want to keep the factory almanac. */
if (IS_ENABLED(CONFIG_GNSS_SAMPLE_ASSISTANCE_MINIMAL))
delete_mask &= ~NRF_MODEM_GNSS_DELETE_ALMANACS;
err = nrf_modem_gnss_nv_data_delete(delete_mask);
if (err)
LOG_ERR("Failed to delete GNSS data");
return -1;
return 0;
static void ttff_test_prepare_work_fn(struct k_work *item)
/* Make sure GNSS is stopped before next start. */
nrf_modem_gnss_stop();
if (IS_ENABLED(CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST_COLD_START))
if (ttff_test_force_cold_start() != 0)
return;
/* All A-GPS data is always requested before GNSS is started. */
last_agps.sv_mask_ephe = 0xffffffff;
last_agps.sv_mask_alm = 0xffffffff;
NRF_MODEM_GNSS_AGPS_GPS_UTC_REQUEST |
NRF_MODEM_GNSS_AGPS_KLOBUCHAR_REQUEST |
NRF_MODEM_GNSS_AGPS_SYS_TIME_AND_SV_TOW_REQUEST |
NRF_MODEM_GNSS_AGPS_POSITION_REQUEST |
NRF_MODEM_GNSS_AGPS_INTEGRITY_REQUEST;
/* Start and stop GNSS to trigger possible A-GPS data request. If new A-GPS
* data is needed it is fetched before GNSS is started.
nrf_modem_gnss_start();
k_work_submit_to_queue(&gnss_work_q, &ttff_test_start_work);
static void ttff_test_start_work_fn(struct k_work *item)
LOG_INF("Starting GNSS");
if (nrf_modem_gnss_start() != 0)
LOG_ERR("Failed to start GNSS");
return;
fix_timestamp = k_uptime_get();
time_blocked = 0;
static void date_time_evt_handler(const struct date_time_evt *evt)
k_sem_give(&time_sem);
static int modem_init(void)
if (IS_ENABLED(CONFIG_DATE_TIME))
date_time_register_handler(date_time_evt_handler);
if (lte_lc_init() != 0)
LOG_ERR("Failed to initialize LTE link controller");
return -1;
lte_lc_register_handler(lte_lc_event_handler);
#elif !defined(CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE)
lte_lc_psm_req(true);
if (lte_lc_connect() != 0)
LOG_ERR("Failed to connect to LTE network");
return -1;
LOG_INF("Waiting for current time");
/* Wait for an event from the Date Time library. */
k_sem_take(&time_sem, K_MINUTES(10));
if (!date_time_is_valid())
LOG_WRN("Failed to get current time, continuing anyway");
return 0;
static int sample_init(void)
int err = 0;
struct k_work_queue_config cfg = {
.name = "gnss_work_q",
.no_yield = false};
k_work_queue_start(
&gnss_work_q,
K_THREAD_STACK_SIZEOF(gnss_workq_stack_area),
GNSS_WORKQ_THREAD_PRIORITY,
&cfg);
k_work_init(&agps_data_get_work, agps_data_get_work_fn);
err = assistance_init(&gnss_work_q);
k_work_init_delayable(&ttff_test_got_fix_work, ttff_test_got_fix_work_fn);
k_work_init_delayable(&ttff_test_prepare_work, ttff_test_prepare_work_fn);
k_work_init(&ttff_test_start_work, ttff_test_start_work_fn);
return err;
static int gnss_init_and_start(void)
#if defined(CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE) || defined(CONFIG_GNSS_SAMPLE_LTE_ON_DEMAND)
/* Enable GNSS. */
if (lte_lc_func_mode_set(LTE_LC_FUNC_MODE_ACTIVATE_GNSS) != 0)
LOG_ERR("Failed to activate GNSS functional mode");
return -1;
#endif /* CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE || CONFIG_GNSS_SAMPLE_LTE_ON_DEMAND */
/* Configure GNSS. */
if (nrf_modem_gnss_event_handler_set(gnss_event_handler) != 0)
LOG_ERR("Failed to set GNSS event handler");
return -1;
/* Enable all supported NMEA messages. */
uint16_t nmea_mask = NRF_MODEM_GNSS_NMEA_RMC_MASK |
NRF_MODEM_GNSS_NMEA_GGA_MASK |
NRF_MODEM_GNSS_NMEA_GLL_MASK |
NRF_MODEM_GNSS_NMEA_GSA_MASK |
NRF_MODEM_GNSS_NMEA_GSV_MASK;
if (nrf_modem_gnss_nmea_mask_set(nmea_mask) != 0)
LOG_ERR("Failed to set GNSS NMEA mask");
return -1;
/* This use case flag should always be set. */
uint8_t use_case = NRF_MODEM_GNSS_USE_CASE_MULTIPLE_HOT_START;
if (IS_ENABLED(CONFIG_GNSS_SAMPLE_MODE_PERIODIC) &&
!IS_ENABLED(CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE))
/* Disable GNSS scheduled downloads when assistance is used. */
use_case |= NRF_MODEM_GNSS_USE_CASE_SCHED_DOWNLOAD_DISABLE;
if (IS_ENABLED(CONFIG_GNSS_SAMPLE_LOW_ACCURACY))
use_case |= NRF_MODEM_GNSS_USE_CASE_LOW_ACCURACY;
if (nrf_modem_gnss_use_case_set(use_case) != 0)
LOG_WRN("Failed to set GNSS use case");
#if defined(CONFIG_NRF_CLOUD_AGPS_ELEVATION_MASK)
if (nrf_modem_gnss_elevation_threshold_set(CONFIG_NRF_CLOUD_AGPS_ELEVATION_MASK) != 0)
LOG_ERR("Failed to set elevation threshold");
return -1;
LOG_DBG("Set elevation threshold to %u", CONFIG_NRF_CLOUD_AGPS_ELEVATION_MASK);
#if defined(CONFIG_GNSS_SAMPLE_MODE_CONTINUOUS)
/* Default to no power saving. */
uint8_t power_mode = NRF_MODEM_GNSS_PSM_DISABLED;
#if defined(GNSS_SAMPLE_POWER_SAVING_MODERATE)
power_mode = NRF_MODEM_GNSS_PSM_DUTY_CYCLING_PERFORMANCE;
#elif defined(GNSS_SAMPLE_POWER_SAVING_HIGH)
power_mode = NRF_MODEM_GNSS_PSM_DUTY_CYCLING_POWER;
if (nrf_modem_gnss_power_mode_set(power_mode) != 0)
LOG_ERR("Failed to set GNSS power saving mode");
return -1;
#endif /* CONFIG_GNSS_SAMPLE_MODE_CONTINUOUS */
/* Default to continuous tracking. */
uint16_t fix_retry = 0;
uint16_t fix_interval = 1;
#if defined(CONFIG_GNSS_SAMPLE_MODE_PERIODIC)
fix_retry = CONFIG_GNSS_SAMPLE_PERIODIC_TIMEOUT;
fix_interval = CONFIG_GNSS_SAMPLE_PERIODIC_INTERVAL;
#elif defined(CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST)
/* Single fix for TTFF test mode. */
fix_retry = 0;
fix_interval = 0;
if (nrf_modem_gnss_fix_retry_set(fix_retry) != 0)
LOG_ERR("Failed to set GNSS fix retry");
return -1;
if (nrf_modem_gnss_fix_interval_set(fix_interval) != 0)
LOG_ERR("Failed to set GNSS fix interval");
return -1;
k_work_schedule_for_queue(&gnss_work_q, &ttff_test_prepare_work, K_NO_WAIT);
#else /* !CONFIG_GNSS_SAMPLE_MODE_TTFF_TEST */
return -1;
return 0;
static bool output_paused(void)
#if defined(CONFIG_GNSS_SAMPLE_ASSISTANCE_NONE) || defined(CONFIG_GNSS_SAMPLE_LOG_LEVEL_OFF)
return false;
#else
return (requesting_assistance || assistance_is_active()) ? true : false;
static void print_satellite_stats(struct nrf_modem_gnss_pvt_data_frame *pvt_data)
uint8_t tracked = 0;
uint8_t in_fix = 0;
uint8_t unhealthy = 0;
for (int i = 0; i < NRF_MODEM_GNSS_MAX_SATELLITES; ++i)
if (pvt_data->sv[i].sv > 0)
tracked++;
if (pvt_data->sv[i].flags & NRF_MODEM_GNSS_SV_FLAG_USED_IN_FIX)
in_fix++;
if (pvt_data->sv[i].flags & NRF_MODEM_GNSS_SV_FLAG_UNHEALTHY)
unhealthy++;
printf("Tracking: %2d Using: %2d Unhealthy: %d\n", tracked, in_fix, unhealthy);
static void print_fix_data(struct nrf_modem_gnss_pvt_data_frame *pvt_data)
printf("Latitude: %.06f\n", pvt_data->latitude);
printf("Longitude: %.06f\n", pvt_data->longitude);
printf("Altitude: %.01f m\n", pvt_data->altitude);
printf("Accuracy: %.01f m\n", pvt_data->accuracy);
printf("Speed: %.01f m/s\n", pvt_data->speed);
printf("Speed accuracy: %.01f m/s\n", pvt_data->speed_accuracy);
printf("Heading: %.01f deg\n", pvt_data->heading);
printf("Date: %04u-%02u-%02u\n",
pvt_data->datetime.year,
pvt_data->datetime.month,
pvt_data->datetime.day);
printf("Time (UTC): %02u:%02u:%02u.%03u\n",
pvt_data->datetime.hour,
pvt_data->datetime.minute,
pvt_data->datetime.seconds,
pvt_data->datetime.ms);
printf("PDOP: %.01f\n", pvt_data->pdop);
printf("HDOP: %.01f\n", pvt_data->hdop);
printf("VDOP: %.01f\n", pvt_data->vdop);
printf("TDOP: %.01f\n", pvt_data->tdop);
// STOP: this is the end of the GNSS code functions that I have transferred
LOG_MODULE_REGISTER(mqtt_simple, CONFIG_MQTT_SIMPLE_LOG_LEVEL);
/* Buffers for MQTT client. */
static uint8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static uint8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static uint8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
/* The mqtt client struct */
static struct mqtt_client client;
/* MQTT Broker details. */
static struct sockaddr_storage broker;
/* File descriptor */
static struct pollfd fds;
#if defined(CONFIG_MQTT_LIB_TLS) // Not being called
static int certificates_provision(void)
int err = 0;
LOG_INF("Provisioning certificates");
#if defined(CONFIG_NRF_MODEM_LIB) && defined(CONFIG_MODEM_KEY_MGMT)
err = modem_key_mgmt_write(CONFIG_MQTT_TLS_SEC_TAG,
MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,
CA_CERTIFICATE,
strlen(CA_CERTIFICATE));
if (err)
LOG_ERR("Failed to provision CA certificate: %d", err);
return err;
#elif defined(CONFIG_BOARD_QEMU_X86) && defined(CONFIG_NET_SOCKETS_SOCKOPT_TLS)
err = tls_credential_add(CONFIG_MQTT_TLS_SEC_TAG,
TLS_CREDENTIAL_CA_CERTIFICATE,
CA_CERTIFICATE,
sizeof(CA_CERTIFICATE));
if (err)
LOG_ERR("Failed to register CA certificate: %d", err);
return err;
return err;
#endif /* defined(CONFIG_MQTT_LIB_TLS) */
K_SEM_DEFINE(carrier_registered, 0, 1);
int lwm2m_carrier_event_handler(const lwm2m_carrier_event_t *event)
switch (event->type)
case LWM2M_CARRIER_EVENT_BSDLIB_INIT:
LOG_INF("LWM2M_CARRIER_EVENT_BSDLIB_INIT");
case LWM2M_CARRIER_EVENT_CONNECTING:
LOG_INF("LWM2M_CARRIER_EVENT_CONNECTING");
case LWM2M_CARRIER_EVENT_CONNECTED:
LOG_INF("LWM2M_CARRIER_EVENT_CONNECTED");
case LWM2M_CARRIER_EVENT_DISCONNECTING:
LOG_INF("LWM2M_CARRIER_EVENT_DISCONNECTING");
case LWM2M_CARRIER_EVENT_DISCONNECTED:
LOG_INF("LWM2M_CARRIER_EVENT_DISCONNECTED");
case LWM2M_CARRIER_EVENT_BOOTSTRAPPED:
LOG_INF("LWM2M_CARRIER_EVENT_BOOTSTRAPPED");
case LWM2M_CARRIER_EVENT_REGISTERED:
LOG_INF("LWM2M_CARRIER_EVENT_REGISTERED");
k_sem_give(&carrier_registered);
case LWM2M_CARRIER_EVENT_DEFERRED:
LOG_INF("LWM2M_CARRIER_EVENT_DEFERRED");
case LWM2M_CARRIER_EVENT_FOTA_START:
LOG_INF("LWM2M_CARRIER_EVENT_FOTA_START");
case LWM2M_CARRIER_EVENT_REBOOT:
LOG_INF("LWM2M_CARRIER_EVENT_REBOOT");
case LWM2M_CARRIER_EVENT_ERROR:
LOG_ERR("LWM2M_CARRIER_EVENT_ERROR: code %d, value %d",
((lwm2m_carrier_event_error_t *)event->data)->code,
((lwm2m_carrier_event_error_t *)event->data)->value);
LOG_WRN("Unhandled LWM2M_CARRIER_EVENT: %d", event->type);
return 0;
#endif /* defined(CONFIG_LWM2M_CARRIER) */
/**@brief Function to print strings without null-termination
static void data_print(uint8_t *prefix, uint8_t *data, size_t len)
char buf[len + 1];
memcpy(buf, data, len);
buf[len] = 0;
LOG_INF("%s%s", (char *)prefix, (char *)buf);
/**@brief Function to publish data on the configured topic
static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
struct mqtt_publish_param param;
param.message.topic.qos = qos;
param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
param.message.payload.data = data;
param.message.payload.len = len;
param.message_id = sys_rand32_get();
param.dup_flag = 0;
param.retain_flag = 0;
data_print("Publishing: ", data, len);
LOG_INF("to topic: %s len: %u",
CONFIG_MQTT_PUB_TOPIC,
(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
return mqtt_publish(c, ¶m);
/**@brief Function to subscribe to the configured topic
static int subscribe(void)
struct mqtt_topic subscribe_topic = {
.topic = {
.utf8 = CONFIG_MQTT_SUB_TOPIC,
.size = strlen(CONFIG_MQTT_SUB_TOPIC)},
.qos = MQTT_QOS_1_AT_LEAST_ONCE};
const struct mqtt_subscription_list subscription_list = {
.list = &subscribe_topic,
.list_count = 1,
.message_id = 1234};
LOG_INF("Subscribing to: %s len %u", CONFIG_MQTT_SUB_TOPIC,
(unsigned int)strlen(CONFIG_MQTT_SUB_TOPIC));
return mqtt_subscribe(&client, &subscription_list);
/**@brief Function to read the published payload.
static int publish_get_payload(struct mqtt_client *c, size_t length)
int ret;
int err = 0;
/* Return an error if the payload is larger than the payload buffer.
* Note: To allow new messages, we have to read the payload before returning.
if (length > sizeof(payload_buf))
err = -EMSGSIZE;
/* Truncate payload until it fits in the payload buffer. */
while (length > sizeof(payload_buf))
ret = mqtt_read_publish_payload_blocking(
c, payload_buf, (length - sizeof(payload_buf)));
if (ret == 0)
return -EIO;
else if (ret < 0)
return ret;
length -= ret;
ret = mqtt_readall_publish_payload(c, payload_buf, length);
if (ret)
return ret;
return err;
/**@brief MQTT client event handler
void mqtt_evt_handler(struct mqtt_client *const c,
const struct mqtt_evt *evt)
int err;
switch (evt->type)
case MQTT_EVT_CONNACK:
if (evt->result != 0)
LOG_ERR("MQTT connect failed: %d", evt->result);
LOG_INF("MQTT client connected");
subscribe();
case MQTT_EVT_DISCONNECT:
LOG_INF("MQTT client disconnected: %d", evt->result);
case MQTT_EVT_PUBLISH:
const struct mqtt_publish_param *p = &evt->param.publish;
LOG_INF("MQTT PUBLISH result=%d len=%d",
evt->result, p->message.payload.len);
err = publish_get_payload(c, p->message.payload.len);
if (p->message.topic.qos == MQTT_QOS_1_AT_LEAST_ONCE)
const struct mqtt_puback_param ack = {
.message_id = p->message_id};
/* Send acknowledgment. */
mqtt_publish_qos1_ack(&client, &ack);
if (err >= 0)
data_print("Received: ", payload_buf,
/* Echo back received data */ // Commented this out because it kept echoing back recieved data
// data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
// payload_buf, p->message.payload.len);
else if (err == -EMSGSIZE)
LOG_ERR("Received payload (%d bytes) is larger than the payload buffer "
"size (%d bytes).",
p->message.payload.len, sizeof(payload_buf));
LOG_ERR("publish_get_payload failed: %d", err);
LOG_INF("Disconnecting MQTT client...");
err = mqtt_disconnect(c);
if (err)
LOG_ERR("Could not disconnect: %d", err);
case MQTT_EVT_PUBACK:
LOG_ERR("MQTT PUBACK error: %d", evt->result);
LOG_INF("PUBACK packet id: %u", evt->param.puback.message_id);
case MQTT_EVT_SUBACK:
LOG_ERR("MQTT SUBACK error: %d", evt->result);
LOG_INF("SUBACK packet id: %u", evt->param.suback.message_id);
case MQTT_EVT_PINGRESP:
LOG_ERR("MQTT PINGRESP error: %d", evt->result);
LOG_INF("Unhandled MQTT event type: %d", evt->type);
/**@brief Resolves the configured hostname and
* initializes the MQTT broker structure
static int broker_init(void)
int err;
struct addrinfo *result;
struct addrinfo *addr;
struct addrinfo hints = {
.ai_family = AF_INET,
.ai_socktype = SOCK_STREAM};
err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result); // to change CONFIG_MQTT_BROKER_HOSTNAME go to kconfig
if (err)
LOG_ERR("getaddrinfo failed: %d", err);
return -ECHILD;
addr = result;
/* Look for address of the broker. */
while (addr != NULL)
/* IPv4 Address. */
if (addr->ai_addrlen == sizeof(struct sockaddr_in))
struct sockaddr_in *broker4 =
((struct sockaddr_in *)&broker);
char ipv4_addr[NET_IPV4_ADDR_LEN];
broker4->sin_addr.s_addr =
((struct sockaddr_in *)addr->ai_addr)
->sin_addr.s_addr;
broker4->sin_family = AF_INET;
broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
inet_ntop(AF_INET, &broker4->sin_addr.s_addr,
ipv4_addr, sizeof(ipv4_addr));
LOG_INF("IPv4 Address found %s", ipv4_addr);
LOG_ERR("ai_addrlen = %u should be %u or %u",
(unsigned int)addr->ai_addrlen,
(unsigned int)sizeof(struct sockaddr_in),
(unsigned int)sizeof(struct sockaddr_in6));
addr = addr->ai_next;
/* Free the address. */
freeaddrinfo(result);
return err;
#define IMEI_LEN 15
#define CGSN_RESPONSE_LENGTH (IMEI_LEN + 6 + 1) /* Add 6 for \r\nOK\r\n and 1 for \0 */
#define CLIENT_ID_LEN sizeof("nrf-") + IMEI_LEN
#else
#define RANDOM_LEN 10
#define CLIENT_ID_LEN sizeof(CONFIG_BOARD) + 1 + RANDOM_LEN
#endif /* defined(CONFIG_NRF_MODEM_LIB) */
/* Function to get the client id */
static const uint8_t *client_id_get(void)
static uint8_t client_id[MAX(sizeof(CONFIG_MQTT_CLIENT_ID),
CLIENT_ID_LEN)];
if (strlen(CONFIG_MQTT_CLIENT_ID) > 0)
snprintf(client_id, sizeof(client_id), "%s",
CONFIG_MQTT_CLIENT_ID);
goto exit;
char imei_buf[CGSN_RESPONSE_LENGTH + 1];
int err;
err = nrf_modem_at_cmd(imei_buf, sizeof(imei_buf), "AT+CGSN");
if (err)
LOG_ERR("Failed to obtain IMEI, error: %d", err);
goto exit;
imei_buf[IMEI_LEN] = '\0';
snprintf(client_id, sizeof(client_id), "nrf-%.*s", IMEI_LEN, imei_buf);
#else
uint32_t id = sys_rand32_get();
snprintf(client_id, sizeof(client_id), "%s-%010u", CONFIG_BOARD, id);
#endif /* !defined(NRF_CLOUD_CLIENT_ID) */
exit:
LOG_DBG("client_id = %s", (char *)client_id);
return client_id;
/**@brief Initialize the MQTT client structure
static int client_init(struct mqtt_client *client)
int err;
mqtt_client_init(client);
err = broker_init();
if (err)
LOG_ERR("Failed to initialize broker connection");
return err;
/* MQTT client configuration */
client->broker = &broker;
client->evt_cb = mqtt_evt_handler;
client->client_id.utf8 = client_id_get();
client->client_id.size = strlen(client->client_id.utf8);
client->password = NULL;
client->user_name = NULL;
client->protocol_version = MQTT_VERSION_3_1_1;
/* MQTT buffers configuration */
client->rx_buf = rx_buffer;
client->rx_buf_size = sizeof(rx_buffer);
client->tx_buf = tx_buffer;
client->tx_buf_size = sizeof(tx_buffer);
/* MQTT transport configuration */
struct mqtt_sec_config *tls_cfg = &(client->transport).tls.config;
static sec_tag_t sec_tag_list[] = {CONFIG_MQTT_TLS_SEC_TAG};
LOG_INF("TLS enabled");
client->transport.type = MQTT_TRANSPORT_SECURE;
tls_cfg->peer_verify = CONFIG_MQTT_TLS_PEER_VERIFY;
tls_cfg->cipher_count = 0;
tls_cfg->cipher_list = NULL;
tls_cfg->sec_tag_count = ARRAY_SIZE(sec_tag_list);
tls_cfg->sec_tag_list = sec_tag_list;
tls_cfg->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
tls_cfg->session_cache = IS_ENABLED(CONFIG_MQTT_TLS_SESSION_CACHING) ? TLS_SESSION_CACHE_ENABLED : TLS_SESSION_CACHE_DISABLED;
#else
/* TLS session caching is not supported by the Zephyr network stack */
tls_cfg->session_cache = TLS_SESSION_CACHE_DISABLED;
#else
client->transport.type = MQTT_TRANSPORT_NON_SECURE;
return err;
/**@brief Initialize the file descriptor structure used by poll.
static int fds_init(struct mqtt_client *c)
if (c->transport.type == MQTT_TRANSPORT_NON_SECURE)
fds.fd = c->transport.tcp.sock;
fds.fd = c->transport.tls.sock;
#else
return -ENOTSUP;
fds.events = POLLIN;
return 0;
#if defined(CONFIG_DK_LIBRARY)
static void button_handler(uint32_t button_states, uint32_t has_changed)
if (has_changed & button_states &
BIT(CONFIG_BUTTON_EVENT_BTN_NUM - 1))
int ret;
ret = data_publish(&client,
CONFIG_BUTTON_EVENT_PUBLISH_MSG,
sizeof(CONFIG_BUTTON_EVENT_PUBLISH_MSG) - 1);
if (ret)
LOG_ERR("Publish failed: %d", ret);
/**@brief Configures modem to provide LTE link. Blocks until link is
* successfully established.
static int modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
/* Turn off LTE power saving features for a more responsive demo. Also,
* request power saving features before network registration. Some
* networks rejects timer updates after the device has registered to the
* LTE network.
LOG_INF("Disabling PSM and eDRX");
lte_lc_psm_req(false);
lte_lc_edrx_req(false);
if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT))
/* Do nothing, modem is already turned on
* and connected.
/* Wait for the LWM2M_CARRIER to configure the modem and
* start the connection.
LOG_INF("Waitng for carrier registration...");
k_sem_take(&carrier_registered, K_FOREVER);
LOG_INF("Registered!");
#else /* defined(CONFIG_LWM2M_CARRIER) */
int err;
LOG_INF("LTE Link Connecting...");
err = lte_lc_init_and_connect();
if (err)
LOG_INF("Failed to establish LTE connection: %d", err);
return err;
LOG_INF("LTE Link Connected!");
#endif /* defined(CONFIG_LTE_LINK_CONTROL) */
return 0;
////////////// it all starts here /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
int err;
uint32_t connect_attempt = 0;
// start: GNSS stuff////////////////////////////////////////////////////
uint8_t cnt = 0;
/* Initialize reference coordinates (if used). */
if (sizeof(CONFIG_GNSS_SAMPLE_REFERENCE_LATITUDE) > 1 &&
ref_used = true;
ref_latitude = atof(CONFIG_GNSS_SAMPLE_REFERENCE_LATITUDE);
ref_longitude = atof(CONFIG_GNSS_SAMPLE_REFERENCE_LONGITUDE);
if (modem_init() != 0)
LOG_ERR("Failed to initialize modem");
return -1;
if (sample_init() != 0)
LOG_ERR("Failed to initialize sample");
return -1;
if (gnss_init_and_start() != 0)
LOG_ERR("Failed to initialize and start GNSS");
return -1;
// end: GNSS stuff//////////////////////////////////////////////////////
LOG_INF("The MQTT and GNSS code is starting.");
err = certificates_provision();
if (err != 0)
LOG_ERR("Failed to provision certificates");
return;
do
err = modem_configure();
if (err)
LOG_INF("Retrying in %d seconds",
CONFIG_LTE_CONNECT_RETRY_DELAY_S);
k_sleep(K_SECONDS(CONFIG_LTE_CONNECT_RETRY_DELAY_S));
} while (err);
err = client_init(&client);
if (err != 0)
LOG_ERR("client_init: %d", err);
return;
dk_buttons_init(button_handler);
do_connect:
if (connect_attempt++ > 0)
LOG_INF("Reconnecting in %d seconds...",
CONFIG_MQTT_RECONNECT_DELAY_S);
k_sleep(K_SECONDS(CONFIG_MQTT_RECONNECT_DELAY_S));
err = mqtt_connect(&client);
if (err != 0)
LOG_ERR("mqtt_connect %d", err);
goto do_connect;
err = fds_init(&client);
if (err != 0)
LOG_ERR("fds_init: %d", err);
return;
while (1)
// start: GNSS stuff////////////////////////////////////////////////////////////
while ((((uint32_t)(k_uptime_get()) / 1000) % 10) == 0)
printf("timer: %d\n", (int)(k_uptime_get()) / 1000);
(void)k_poll(events, 2, K_FOREVER);
if (events[0].state == K_POLL_STATE_SEM_AVAILABLE &&
k_sem_take(events[0].sem, K_NO_WAIT) == 0)
/* New PVT data available */
/* TTFF test mode. */
/* Calculate the time GNSS has been blocked by LTE. */
if (last_pvt.flags & NRF_MODEM_GNSS_PVT_FLAG_DEADLINE_MISSED)
time_blocked++;
else if (IS_ENABLED(CONFIG_GNSS_SAMPLE_NMEA_ONLY))
/* NMEA-only output mode. */
if (output_paused())
goto handle_nmea;
if (last_pvt.flags & NRF_MODEM_GNSS_PVT_FLAG_FIX_VALID)
/* PVT and NMEA output mode. */
goto handle_nmea;
printf("\033[1;1H");
printf("\033[2J");
print_satellite_stats(&last_pvt);
printf("GNSS operation blocked by LTE\n");
NRF_MODEM_GNSS_PVT_FLAG_NOT_ENOUGH_WINDOW_TIME)
printf("Insufficient GNSS time windows\n");
if (last_pvt.flags & NRF_MODEM_GNSS_PVT_FLAG_SLEEP_BETWEEN_PVT)
printf("Sleep period(s) between PVT notifications\n");
printf("-----------------------------------\n");
print_fix_data(&last_pvt);
printf("Seconds since last fix: %d\n",
(uint32_t)((k_uptime_get() - fix_timestamp) / 1000));
printf("fix_timestamp: %d \n", ((uint32_t)(k_uptime_get()) / 1000) % 10);
cnt++;
printf("Searching [%c]\n", update_indicator[cnt % 4]);
printf("\nNMEA strings:\n\n");
handle_nmea:
if (events[1].state == K_POLL_STATE_MSGQ_DATA_AVAILABLE &&
k_msgq_get(events[1].msgq, &nmea_data, K_NO_WAIT) == 0)
/* New NMEA data available */
if (!output_paused())
printf("%s", nmea_data->nmea_str);
k_free(nmea_data);
events[0].state = K_POLL_STATE_NOT_READY;
events[1].state = K_POLL_STATE_NOT_READY;
err = poll(&fds, 1, mqtt_keepalive_time_left(&client));
if (err < 0)
LOG_ERR("poll: %d", errno);
err = mqtt_live(&client);
if ((err != 0) && (err != -EAGAIN))
LOG_ERR("ERROR: mqtt_live: %d", err);
if ((fds.revents & POLLIN) == POLLIN)
err = mqtt_input(&client);
if (err != 0)
LOG_ERR("mqtt_input: %d", err);
if ((fds.revents & POLLERR) == POLLERR)
LOG_ERR("POLLERR");
if ((fds.revents & POLLNVAL) == POLLNVAL)
LOG_ERR("POLLNVAL");
err = mqtt_disconnect(&client);
if (err)
LOG_ERR("Could not disconnect MQTT client: %d", err);
goto do_connect;
