Hi:
I want to use hello_world example OTA nrf9160.
Reference application_update example.
How to use application_update?And How to modify hello_world into a file that can be used for OTA?
NCS:V2.1.2
Hi:
NCS:V2.1.2
Thanks for sharing! Can you test with other samples as well, just to verify that they are working as intended?
Also, when building the project, do you get any warnings or similar?
Hi:
Test hello_world example.It is OK.
Build application_update eample.
Can you please try with another sample from the nrf samples that are designed for nRF9160 e.g. Asset Tracker v2? This to verify the functionality.
Thanks
Hi:
use asset_tracker_v2.But build error.
Could you please provide full log output from the build? Please copy and paste to a txt file and upload here.
If you are not able to build any other sample, we need to find the root cause.
