quick question..Which, if any, Nordic device has NFC that can be read and write without additional NFC ICs?
I've got an NRF52840 dev kit but apparently it only supports type 2 NFC tag that is write only.
Many thanks
Duncan
Many thanks
Duncan
Hi Duncan
Any nRF device with NFC should support both type 2 and type 4, where type 4 supports both read and write.
What we can not do is have one nRF device read another, since we can't generate the NFC field, only respond to other devices that does.
The following nRF Connect SDK example shows how you can implement a writeable NDEF message using the type 4 library:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/nfc/writable_ndef_msg/README.html
Best regards
Torbjørn
Hi Torbjørn,
thank you for your reply.
Can I just confirm that you are saying that the Nrf device is unable to act as the poller device? I'm looking to implement the same sort of functionality that a smart phone would have, being able to read a tag. Many thanks
Duncan
Hi Duncan
That is correct. The nRF device can not poll other tags. For that you would need to use an external NFC solution.
Best regards
Torbjørn
