How to create customized software to program boards via bluetooth on nRF Connect
Hi, I'd like to add that "BLE capabilities for nRF Connect" to my customized software in the dongle, is there an example code or a template which I can add to my customized code such that it can do that? Because when I tried using the dfu sample codes that come with the SDK 17.1.0, I was stilled asked to program the device to something else.
  • Hello
    Can you please explain more clearly exactly what you want your program to do?
    It's not really clear to me what you mean by this.
    Einar
  • Hi Einar,
    I've that quote from this post:  Example for Performing OTA DFU from NRF52840 Dongle to NRF52 peripheral ?
    What I'd like to do is to use the dongle to transfer data via Bluetooth from my peripheral device to the computer (meaning I have my customized software on the dongle) while also using it to upgrade my firmware on the peripheral device when it needs upgrading. Because currently if I need to use the dongle to upgrade the firmware on the peripheral device, I need to reprogram the dongle with a special firmware from Nordic, and then put my own firmware back in afterwards. I would like to use just one firmware to do both. If that's possible.
  • Hi
    It seems to me that Hung already provided an answer on how to approach your problem in the post you linked.
    Is there anything specific in his reply that was unclear?
    -Einar
  • I tried following the instructions, I was not able to successfully build or even open the codes in Visual Studio 2022 without errors. Is there a version that works with Keil? I tried using the ble connectivity code, I got this message from the log: "Received status with code 0 PKT_SEND_MAX_RETRIES_REACHED, message: 'No response from device. Tried to send packet 6 times.'" and when I pressed the reset button, I would be able to connect, but still be asked to reprogram the dongle firmware, which example can I use as a reference to build my code on such that I won't need to reprogram the dongle? I basically just want the source code of the file that gets downloaded to the dongle after the prompt "Device must be programmed, do you want to proceed?"
  • Hi
    You would have to share these errors for me to be able to help with that.
    Keil is not supported.
    I would need more details on how you tried to use it to understand the context here.
    I assume it is nRF Connect for Desktop you are using that is asking you to reprogram the dongle?
    The whole point is that if you want to not reprogram your dongle you will have to write your own program that does the same things that nRF Connect for Desktop does in addition to anything else you want your program to do.
    Then you should look at Hung's answer in the thread you linked.
