hi, I have posted a detailed problem using Eclipse on Vidar's tutorial. Any help is appreciated. See following link: devzone.nordicsemi.com/.../ Thanks!
There is another way to work with Eclipse GCC here. The blog also shows you how to use with other jtag tool than j-link.
Can you try what Vidar suggests here: Link?
Hi, please try to use the debug launcher to load image to target. Configurations of the debug launcher can be seen from the screenshots attached with the tutorial.
Hi Vidar, I found that the launcher pointed to a wrong folder. Now I have another problem, where the J-Link return with error code 1 and reports that it has an error on final launch sequance Thanks
Hi, I found that I pointed the the debugger to a different folder than the right one. Now I face another issue, where J-Link is not synchronized with c code... devzone.nordicsemi.com/.../
I have managed to externally flash & connect to target using J-Flash util, so the physical tool-chain works fine. I appreciate every comment. Regards,
