ERROR 1[NRF_ERROR_SVC_HANDLER_MISSING] of UART in nRF52833 DK
I'm using  PCA10100, and developing my project on examples\ble_peripheral\ble_app_uart(SDK 17.1.0)
I connect P0.08_8 and P0.06 with other sensor module's uart, when PCA101001 connected with mobile app, I will  read the imformation of the sensor module.
Strangely, sometimes when I reset the sensor module(the sensor module will output many imformation), RTT viewer print ERROR 1[NRF_ERROR_SVC_HANDLER_MISSING] which at APP_UART_COMMUNICATION_ERROR handle.
And I print the p_event->data.error_communication, the result is 1. What's that mean? I have changed the RX_BUFF_SIZE and TX_BUFF_SIZE to 1024.
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "m_nus_app.h"
#include "m_config.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Anytrek_123"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                1024                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                1024                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
//        uint32_t err_code;
				NRF_LOG_INFO("Received data from APP.");
//				NRF_LOG_HEXDUMP_INFO(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
				for(int i=0;i<p_evt->params.rx_data.length;i++)m_nus_data.rcv_data[i] = p_evt->params.rx_data.p_data[i];
				m_nus_data.rcv_length = p_evt->params.rx_data.length;
//				NRF_LOG_HEXDUMP_INFO(m_nus_data.rcv_data, m_nus_data.rcv_length);
//        NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on UART.");
//        NRF_LOG_HEXDUMP_DEBUG(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
//        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
//            do
//                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
//                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
//                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
//                    APP_ERROR_CHECK(err_code);
//            } while (err_code == NRF_ERROR_BUSY);
//        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
//            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
						if (((data_array[index - 2] == '\r') && (data_array[index - 1] == '\n')) || (index>=200))
                if (index > 2)
										if(m_nus_data.trans_status == true)
												do
//														NRF_LOG_INFO("Ready to send...");
														err_code = ble_nus_debug_data_send(&m_nus, data_array, &length, m_conn_handle);
												} while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
						NRF_LOG_INFO("APP_UART_COMMUNICATION_ERROR...%d",p_event->data.error_communication);
//            APP_ERROR_HANDLER(p_event->data.error_communication);
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOW,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
void m_nus_transmit_data(uint8_t *pdata,uint16_t size)
				do
						err_code = ble_nus_data_send(&m_nus, pdata, &size, m_conn_handle);
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
		uart_init();
    // Start execution.
//    printf("\r\nUART started.\r\n");
    advertising_start();
		m_application_config();
		m_timer_init();
    // Enter main loop.
    for (;;)
				m_recieve_app_data();
        idle_state_handle();
  • Hi
    The errors reported in the error_communication field of the APP_UART_COMMUNICATION_ERROR event don't map to the same error codes as the rest of the SDK.
    Rather these error codes are simply copied out of the ERRORSRC register in the UARTE peripheral.
    A value of 1 corresponds to bit 0 of the ERRORSRC register, which indicates that the OVERRUN error occurred in the peripheral.
    If the UART lines get pulled low when the sensor module is reset it makes sense that you would get some kind of error on the nRF side, since the UART lines are supposed to be high when no communication is taking place.
    It is a bit uncommon to get the OVERRUN error though, usually you will see a FRAMING or a BREAK error when the RX line on the nRF side is pulled low for a long time.
    Best regards
    Torbjørn
  • Hi, ovrebekk
    Thanks for your reply.
    As my test go on, the value of p_event->data.error_communication will at  '4' '8' or '12', it seems like different type  error.
    And I closed the "APP_ERROR_HANDLER(p_event->data.error_communication)", my application will work normally. Could I do that way to solve this problem?
  • Hi
    4 means bit 2 is set, which corresponds to a framing error according to the register.
    8 is bit 3, which means a break error occurred.
    12 means that both a framing error and a break error occurred.
    A framing error can happen if you reset the sensor in the middle of a UART byte. A break error happens any time the RX line is pulled low for a long time.
    It is OK to just ignore these errors, and remove the call to APP_ERROR_HANDLER(..), but if you get these errors when you don't expect to get them then you might want to investigate what is going on. During normal UART communication you should not get these errors, but if you are resetting the sensor it makes sense that some errors could occur.
    Best regards
    Torbjørn
  • but if you are resetting the sensor it makes sense that some errors could occur.
    Except this situation. When the application transmitting data in BLE service, but the sensor also sending data will occur those errors? In my application, I creat a 1second timer to send  UART data recieved.
  • Hi
    No, it should work fine to send data over BLE and UART at the same time. Both the RADIO and the UARTE peripherals use DMA to allow them to read and write data to memory in parallel.
    Best regards
    Torbjørn
