Bluetooth UART Service Crash when processing data in the main task
Hi there,
We have tried to implement the bluetooth uart service with the standard example project (ble_app_uart). Up to this point everything works well. But for a custom solution we need to make some adjustments.
For security reasons, the bluetooth must be able to be switched on and off via UART.
This causes problems. In some cases the bluetooth service seems to crash. It looks like these problems are caused by the string processing in the main process. When these are removed, everything works fine again. I know that Bluetooth LE has tight timing constraints so the code got stript  down to the bare minimum. We tried to use software timers but those made it worse. I hope this makes some sense with the code.
Best regards
Maikel
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "stdlib.h"
#include "stdio.h"
//#include "timer.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Field calibration tool"             														/**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN 														/**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
// UART Write function
static void uartPut(const char *dataRequest, const int size);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;               /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};
bool bluetoothEN;
typedef enum
    config,
    Bluetooth,
    idle,
} configState_t;
typedef enum
    gas1Req,
    gas2Req,
    canChannelReq,
    Exit
} requestType_t;
typedef struct
		char inhibitInfo[100];
    char Info[10][100];
		bool deviceNameSet;
    char deviceName[40];
    int index;
    bool dataRecieved[3];
    requestType_t requestIndex;
    bool dataRequested[3];
    requestType_t recievedIndex;
} deviceConfigInfo_t;
struct uartDevice_t
		configState_t uartOutputState;
    deviceConfigInfo_t deviceConfigInfo;
} uartDevice;
enum
	LED1 = 29,
	LED_RED = 29,
	LED2 = 28,
	LED_GREEN = 28,
struct LED_t
	bool led1ON;
	bool led2ON;
}LEDs;
typedef enum{
	request,
	waiting,
	responds,
}idleHandleState_t;
typedef struct {
	idleHandleState_t state;
	bool notIdle;
}idleHandler_t;
idleHandler_t idleHandlerS;
static int idleCounter = 0;
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
char *getElementAt(char *inpString, int pos)
    char *token = strtok(inpString, " ");
    int i = 0;
    while (token != NULL && i < 100)
        if (i == pos)
            return token;
        i++;
        token = strtok(NULL, " ");
    return NULL;
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
		if(uartDevice.deviceConfigInfo.deviceNameSet == true)
                                          (const uint8_t*)uartDevice.deviceConfigInfo.deviceName,//(const uint8_t *)uartDevice.deviceConfigInfo.deviceName,
                                          strlen(DEVICE_NAME));
                                          (const uint8_t*)DEVICE_NAME,//(const uint8_t *)uartDevice.deviceConfigInfo.deviceName,
    APP_ERROR_HANDLER(nrf_error);
static uint8_t dataDebugArr[30];
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
						idleCounter = 0;		//Reset idle counter because the device is still active
            uint32_t err_code;
            err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
        uint32_t err_code;
            do
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t err_code;
    ble_nus_init_t nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t data_array[100];
    static uint8_t index = 0;
    uint32_t err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
										// Bluetooth specific functionality
										switch (uartDevice.uartOutputState)
												case Bluetooth:
														do
														} while (err_code == NRF_ERROR_RESOURCES);
														index = 0;
												// Function for startup configuration
												case config:
														if (data_array[index - 1] == '\n')
																memcpy(&uartDevice.deviceConfigInfo.Info[uartDevice.deviceConfigInfo.index++], data_array, length);
																uartDevice.deviceConfigInfo.dataRecieved[uartDevice.deviceConfigInfo.recievedIndex] = true;
																index = 0;
												// Function to block UART from other ports
												case idle:
																if(idleHandlerS.state == waiting)
																				char active[10];
																				static unsigned int inhibitVal = 0;
																				static int valide = 0;
																				valide = sscanf((char*)data_array, "%*s %*u %*s %*u %*s %u", &inhibitVal);
																				if (valide == 1)
																						idleHandlerS.notIdle = (bool)inhibitVal;
																				idleHandlerS.state = responds;
																				// strcpy(idleHandlerS.responds, (char*)data_array);
																				// memcpy(&uartDevice.deviceConfigInfo.Info[uartDevice.deviceConfigInfo.index++], data_array, length);
																				// uartDevice.deviceConfigInfo.dataRecieved[uartDevice.deviceConfigInfo.recievedIndex] = true;
															index = 0;
				case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
		if(!bluetoothEN)
				bluetoothEN = true;
/**@brief Funtion for stoping advertising.
static void advertising_stop()  //TODO: Test this function
		if(bluetoothEN)
				if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
				(void)sd_ble_gap_adv_stop(m_advertising.adv_handle);
				bluetoothEN = false;
				//NRF_RADIO->TASKS_DISABLE;
    for (uint32_t i = 0; i < size; i++)
        uint32_t err_code;
        err_code = app_uart_put(dataRequest[i]);
void configureBluetoothName()
		static char channel1_gas[50];
		static char channel2_gas[50];
		static char can_channel[50];
		static char inhibitChar[50];
		static unsigned int sensor_channel;
		static unsigned int channel_InhibitI;
		bool idleBool = false;
		uartDevice.uartOutputState = config;
    while (uartDevice.uartOutputState == config)
        // Request data if not allready requested
        if (!uartDevice.deviceConfigInfo.dataRequested[uartDevice.deviceConfigInfo.requestIndex])
            // Request data for channel 1 & channel 2
            switch (uartDevice.deviceConfigInfo.requestIndex)
            case gas1Req:
                uartPut("1", sizeof("1")); // Send deviceInfo 1
            case gas2Req:
                uartPut("2", sizeof("2")); // Send deviceInfo 2
            case canChannelReq:
								uartPut("?", sizeof("?"));
            uartDevice.deviceConfigInfo.dataRequested[uartDevice.deviceConfigInfo.requestIndex] = true;
        // Handle Responds after Request has been handled
        else if (uartDevice.deviceConfigInfo.dataRecieved[uartDevice.deviceConfigInfo.recievedIndex])
            if (uartDevice.deviceConfigInfo.recievedIndex == Exit)
								if(idleBool)
										uartDevice.uartOutputState = idle;
										uartPut("0", sizeof("0"));  // disable string output
										uartDevice.uartOutputState = Bluetooth;
								uartDevice.deviceConfigInfo.deviceNameSet = true;
                switch (uartDevice.deviceConfigInfo.recievedIndex)
                case gas1Req:
										sprintf(channel1_gas, "%s", getElementAt(uartDevice.deviceConfigInfo.Info[gas1Req], 6));
                case gas2Req:
                    sprintf(channel2_gas, "%s", getElementAt(uartDevice.deviceConfigInfo.Info[gas2Req], 6));
                case canChannelReq:
										// char* pString1 = getElementAt(uartDevice.deviceConfigInfo.Info[canChannelReq], 1);
										// char* pString2 = getElementAt(uartDevice.deviceConfigInfo.Info[canChannelReq], 5);
										// strcpy(can_channel, pString1);
										// strcpy(uartDevice.deviceConfigInfo.inhibitInfo, pString2);
										sscanf(uartDevice.deviceConfigInfo.Info[canChannelReq],"%*s %u %*s %*u %*s %u", &sensor_channel, &channel_InhibitI);
										if(channel_InhibitI == 0)
												idleBool = true;
            uartDevice.deviceConfigInfo.recievedIndex++;
            uartDevice.deviceConfigInfo.requestIndex++;
    sprintf(uartDevice.deviceConfigInfo.deviceName, "Sensor_%u_%s_%s", sensor_channel, channel1_gas, channel2_gas);
    printf("\nDevice name: %s\n", uartDevice.deviceConfigInfo.deviceName);
void led_init()
	nrf_gpio_cfg_output(LED_GREEN);
	nrf_gpio_cfg_output(LED_RED);
	nrf_gpio_pin_toggle(LED_GREEN);
	nrf_gpio_pin_toggle(LED_RED);
void timerHandler(void* p_context)
void idleHandler()
	if(!bluetoothEN)
		switch(idleHandlerS.state)
			case request:
				idleHandlerS.state = waiting;
			case waiting:
			case responds:
				if(idleHandlerS.notIdle == true)
				idleHandlerS.state = request;
        nrf_pwr_mgmt_run();
/**@brief Application main function.
    bool erase_bonds;
    // Initialize UART and generic periferals
		uartDevice.uartOutputState = Bluetooth;		//Only for test purpouses
		led_init();
    uart_init();
		power_management_init();
    configureBluetoothName();
		//timers_init();
		//log_init();
    //buttons_leds_init(&erase_bonds);
    // Initialize Bluetooth specific functions
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Enter main loop
    for (;;)
				static uint32_t var;
				static uint32_t varOld;
				const uint32_t deltaVar = 32768;
				var = NRF_RTC0->COUNTER;
				if((var-varOld) > deltaVar)
						varOld = var;
						idleCounter++;
						if(idleCounter > 3600)
								idleCounter = 0;
						if(uartDevice.uartOutputState == idle)
								advertising_stop();
								idleHandler();
				else if(uartDevice.uartOutputState == Bluetooth)
						advertising_start();
						idle_state_handle();
  • Good morning, I hope you had a nice weekend. Yes you are right about the HardFault handler. It does get reached and enters this mode. I have set the HARDFAULT_HANDLER_ENABLED to 1 and added hardfault_implementation.c. I added hardfault_handler_keil.c because I am using the keil compiler. I'm not quite sure about how to use the HardFault_handler function tough. Is it a replacement for the main function. Do I have to add it to some callback? My main.c file still looks the same as befor. The diffrence is that the exception no breaks at screenshot 2. I'm not sure how to progress from here. Thanks for the patience. Best regards Maikel
    As long as you added the two implementation files and enabled HARDFAULT_HANDLER_ENABLED in sdk_config.h that should be used (the default HardFault_Handler in the startup file is weak, so simply adding another will cause that to be used). There is no need to make any other changes in your project or code in order to use it. Is the hardfault handler from the library not reached now?
    That is good, as it should.
    The new hardfault handle use logging, so if you have logging enabled it should be enough to observe the log output to see info about the hard fault (if you don't have logging enabled, consider enabling it - it is often very usefull for debugging). If you are not able to get logging working you could set a breakpoint in the HardFault_c_handler() function and inspect it manually to find the info that would normally be printed in the log.
  • Ok, thanks for the info. I have enabled the Logging feature. I'm using the J-Link RTT. The NRF_LOG_INFO() macros are getting called in the regular functions. The hardFault handler function are not getting invoked however. I added a debug point at the start of the HardFault_c_handler() function. No responds.
    I was able to isolate a code segment that made the programm stop. Its the advertising_stop() function.
    1. Does the APP_ERROR_CHECK() function prevent a HardFault?
    2. Is something wrong with my advertising_stop() function?
    I'll post the function and the main file for completeness.
    best regards Maikel
  • /**@brief Funtion for stoping advertising.
    if(bluetoothEN)
    NRF_LOG_INFO("Advertising stop\n");
    uint32_t err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
    uint32_t err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
    if(err_code != NRF_SUCCESS)
    /** @file
    #include <stdint.h>
    #include <string.h>
    #include "ble_gap.h"
    #include "nrf.h"
    #include "stdlib.h"
    #include "stdio.h"
    #include "nrf_log_default_backends.h"s
    bool bluetoothEN;
    typedef enum
        config,
        Bluetooth,
        idle,
    } configState_t;
    typedef enum
        gas1Req,
        gas2Req,
        canChannelReq,
        Exit
    } requestType_t;
    typedef struct
        char Info[10][100];
    		bool deviceNameSet;
        int index;
    struct uartDevice_t
    } uartDevice;
    enum
    	LED1 = 29,
    	LED_RED = 29,
    	LED2 = 28,
    	LED_GREEN = 28,
    struct LED_t
    	bool led1ON;
    	bool led2ON;
    }LEDs;
    typedef enum{
    	request,
    	waiting,
    	responds,
    }idleHandleState_t;
    typedef struct {
    	bool notIdle;
    }idleHandler_t;
    static unsigned int idleCounter = 0;
        int i = 0;
            if (i == pos)
                return token;
            i++;
        return NULL;
        uint32_t                err_code;
                uint32_t err_code;
            uint32_t err_code;
                do
        uint32_t err_code;
        // Initialize NUS.
        uint32_t err_code;
        uint32_t err_code;
                sleep_mode_enter();
        uint32_t err_code;
            } break;
        uint32_t err_code;
        switch (event)
                sleep_mode_enter();
        uint32_t err_code;
                index++;
                    if (index > 1)
    												case Bluetooth:
    														do
    														index = 0;
    												case config:
    																index = 0;
    												case idle:
    																				if (valide == 1)
    															index = 0;
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
    		if(!bluetoothEN)
    						bluetoothEN = true;
    		if(bluetoothEN)
            uint32_t err_code;
                case gas1Req:
                case gas2Req:
                case canChannelReq:
    								if(idleBool)
                    case gas1Req:
                    case gas2Req:
                    case canChannelReq:
    												idleBool = true;
    void led_init()
    void idleHandler()
    	if(!bluetoothEN)
    			case request:
    			case waiting:
    			case responds:
            nrf_pwr_mgmt_run();
    		//uartDevice.uartOutputState = Bluetooth;		//Only for test purpouses
    		NRF_LOG_INFO("Main called");
    		led_init();
        uart_init();
    		timers_init();
    		log_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
    		for (;;)
    						varOld = var;
    						idleCounter++;
    						NRF_LOG_INFO("idleCounter incremented");
    						if(idleCounter > 10)
    								NRF_LOG_INFO("IdleCounter overflow");
    								idleCounter = 0;
    								advertising_stop();
    								idleHandler();
    						//idle_state_handle();
