Stop scanning and start advertising
I am developing application on  NRF52840 with Zepyr  2.1.2 SDK, and I found two problems when using the example scan_adv, as follows:
  • Executing bt_le_scan_start in the main function can receive data smoothly, but using function scan_start() can not receive data, the same problem also occurs in bt_le_adv_start().
  • Executing bt_le_scan_stop() still cannot stop scanning.
My codeis as below:
#include <zephyr/types.h>
#include <stddef.h>
#include <zephyr/sys/util.h>
#include <zephyr/toolchain.h>
#include <zephyr/bluetooth/hci.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/gpio.h>
struct bt_le_scan_param scan_param = {
		.type       = BT_HCI_LE_SCAN_PASSIVE,
		.options    = BT_LE_SCAN_OPT_NONE,
		.interval   = BT_GAP_SCAN_FAST_INTERVAL,
		.window     = 0x0010,
const struct device *dev;
int state = 1, adv_state;
int8_t rssi_data [8][8] = {0};
static uint8_t mfg_data[] = { 0xff, 0xff, 0x01 };
static const struct bt_data ad[] = {
	BT_DATA(BT_DATA_MANUFACTURER_DATA, mfg_data, 3),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME,DEVICE_NAME_LEN)
void scan_cb(const bt_addr_le_t *addr, int8_t rssi, uint8_t adv_type,
	   struct net_buf_simple *buf)
void adv_start(uint8_t mfg){
	mfg_data[2] = mfg;
	int err = bt_le_adv_start(BT_LE_ADV_NCONN, ad, ARRAY_SIZE(ad), NULL, 0);
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	k_sleep(K_MSEC(400));
static void adv_stop(){
	int err = bt_le_adv_stop();
	if (err) {
		printk("Advertising failed to stop (err %d)\n", err);
		return;
void scan_start(){
	int err = bt_le_scan_start(&scan_param, scan_cb);
		if (err) {
			printk("Starting scanning failed (err %d)\n", err);
			return;
static void scan_stop(){
	int err = bt_le_scan_stop();
	if (err) {
		printk("Stop scanning failed (err %d)\n", err);
		return;
void main(void)
	int err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	scan_start();
	/*  if not use scan_start()
	if (err) {
		return;
	k_sleep(K_MSEC(800));
	//scan_stop();
	if (err) {
		return;
	while(1);
Thanks.
    I see from your code snippet that you call bt_le_adv_stop() at the end. Is that a typo? If you want to stop scanning, you will have to use bt_le_scan_stop()/scan_stop().
    Vidar
    Thank you for your reply, I changed it to bt_le_scan_stop but still have the same problem, is there any way to stop scanning?
    In addition, using function scan_start() still cannot receive data.
    my program is as follows:
    #include <stddef.h>
    #include <device.h>
    		.window     = 0x0010,
    	mfg_data[2] = mfg;
    	if (err) {
    		return;
    	if (err) {
    		return;
    void scan_start(){
    		if (err) {
    			return;
    	if (err) {
    		return;
    void main(void)
    	if (err) {
    		return;
    	scan_start();
    	if (err) {
    		return;
    	//scan_stop();
    	if (err) {
    		return;
    	while(1);
    Please explain how you determine that it does not stop. Is it because bt_le_scan_stop() returns with an error?
    Does scan_start() report any errors?
    Can you post the updated code please? The snippet you posted will not build because the 'err' variable being defined twice in main()
    I use J-Link RTT Viewer V7.58b as a debugging tool. After the bt_le_scan_stop() function is executed, the scan_cb() function continues to work without error
    No error occurs, but scan_cb() function does not send any message
    #include <stddef.h>
    #include <device.h>
    		.window     = 0x0010,
    	printk("scan_cb start\n");
    	char data_str[129];
    	bin2hex(buf->data, buf->len, data_str, sizeof(data_str));
    	printk("data_str is : %s\n", data_str);
    	mfg_data[2] = mfg;
    	if (err) {
    		return;
    	if (err) {
    		return;
    void scan_start(){
    		if (err) {
    			return;
    	if (err) {
    		return;
    void main(void)
    	if (err) {
    		return;
    	scan_start();
    	if (err) {
    		return;
    	//scan_stop();
    	if (err) {
    		return;
    	while(1);
  • This is what when I run the code you posted now:
    So, it appears to be working as expected?
    Here is the hex file I built with your code if you want to try the same on your board:
    2248.zephyr.hex
