minimum ESB latency
I have an application where I need a latency below 100µs between transmission and reception over the air of a 32 bits payload.
We are currently evaluating the ESB protocol, but I thing I'm reaching the limit...
I'm using:
- ISP1507-AL (embedding NRF52810) as a transceiver
- nrf52832 (on nRF52-DK) as a receiver
- The ESB example projects from nFR5 SDK V17.1.0 on Segger Embedded Studio V6.40
I have the following protocol configuration: (ESB_DPL, 2MBPS,  no_ack, 8bits CRC)
    nrf_esb_config_t nrf_esb_config         = NRF_ESB_DEFAULT_CONFIG;
    nrf_esb_config.payload_length           = 4; // 4 bytes
    nrf_esb_config.protocol                 = NRF_ESB_PROTOCOL_ESB_DPL;
    nrf_esb_config.bitrate                  = NRF_ESB_BITRATE_2MBPS;
    nrf_esb_config.crc                      = NRF_ESB_CRC_8BIT; // NRF_ESB_CRC_OFF
    nrf_esb_config.retransmit_delay         = 200;
    nrf_esb_config.retransmit_count         = 2;
    nrf_esb_config.event_handler            = nrf_esb_event_handler;
    nrf_esb_config.mode                     = NRF_ESB_MODE_PTX;
    nrf_esb_config.selective_auto_ack       = true;             // Must be set to true to handle packets witout ACK
I measure:
- 192.48 µs between NRF_RADIO register setup and RADIO_IRQHandler() call for end of transmission on the transmitter side
- 216,54 µs letency between NRF_RADIO register setup on TX side and NRF_ESB_EVENT_RX_RECEIVED on RX side.
If I take the old nRF24L01P specifications where ESB timings are available, I have the following:
Toa = (8 *(1+5+4+1) + 9 ) / 2Mbps = 48.5 µs
Tirq ~=10 µs
Tstdby = 130 µs
As I have no ack and no SPI
Tesb = Toa + Tstdby + Tirq = 188.5 µs which is close to the observed timings.
According to the thread below, the 130µs delay is needed for lecacy reasons on nRF51 and nRF24L series)
Minimize ESB latency on nRF52832
My questions are the followings:
1. Do my assumptions look correct to someone who has experience with ESB ?
2. As I will forever working with nRF52 devices, is there a way to get rid on this 130µs start-up delay ? I found nothing in the driver, but something might be hardware ready hidden somewhere ?
3. If it is not possible, can Nordik recommend any wireless protocol, that would allow me to achieve under 100µs latency for 32bits payload transmission overt the air ?
(even if it implies a full hardware redesign)
Thank you in advance for your inputs Slight smile
  • Hi
    First off I would recommend having a look at the nRF Connect SDK rather than the nRF5 SDK if you are starting out today with the nRF52. The nRF5 SDK is in maintenance mode only at this point, and new features are being added to the nRF Connect SDK only.
    It is true that the current implementation of the ESB library (in both SDK's) uses the 130us startup time. It is lucky timing though as I just recently had another customer with a similar request, whether or not there was any way to speed up the operation of the ESB library.
    The nRF52 devices introduced a faster startup time option which cuts the 130us delay down to only 40us, and I tried to enable this mode in the existing library to see if it would cause any issues. I only had limited time for testing, but it seems that with only 2 lines of code changed I was able to modify the library to use this faster startup time.
    I have included the library below. You will need to replace the original esb.c file in your SDK, which should be located in the following folder:
    \ncs\v2.1.2\nrf\subsys\esb
     * Copyright (c) 2018 Nordic Semiconductor ASA
    #include <errno.h>
    #include <zephyr/irq.h>
    #include <zephyr/sys/byteorder.h>
    #include <nrf.h>
    #include <esb.h>
    #ifdef DPPI_PRESENT
    #include <nrfx_dppi.h>
    #else
    #include <nrfx_ppi.h>
    #include <helpers/nrfx_gppi.h>
    #include <stddef.h>
    #include <string.h>
    #include <nrf_erratas.h>
    /* Constants */
    /* 2 Mb RX wait for acknowledgment time-out value.
     * Smallest reliable value: 160.
    #define RX_ACK_TIMEOUT_US_2MBPS 160
    /* 1 Mb RX wait for acknowledgment time-out value. */
    #define RX_ACK_TIMEOUT_US_1MBPS 300
    /* 250 Kb RX wait for acknowledgment time-out value. */
    #define RX_ACK_TIMEOUT_US_250KBPS 300
    /* 1 Mb RX wait for acknowledgment time-out (combined with BLE). */
    #define RX_ACK_TIMEOUT_US_1MBPS_BLE 300
    /* Minimum retransmit time */
    #define RETRANSMIT_DELAY_MIN 435
    /* Interrupt flags */
    /* Interrupt mask value for TX success. */
    #define INT_TX_SUCCESS_MSK 0x01
    /* Interrupt mask value for TX failure. */
    #define INT_TX_FAILED_MSK 0x02
    /* Interrupt mask value for RX_DR. */
    #define INT_RX_DATA_RECEIVED_MSK 0x04
    /* Mask value to signal updating BASE0 radio address. */
    #define ADDR_UPDATE_MASK_BASE0 (1 << 0)
    /* Mask value to signal updating BASE1 radio address. */
    #define ADDR_UPDATE_MASK_BASE1 (1 << 1)
    /* Mask value to signal updating radio prefixes. */
    #define ADDR_UPDATE_MASK_PREFIX (1 << 2)
     /* The maximum value for PID. */
    #define PID_MAX 3
    #define BIT_MASK_UINT_8(x) (0xFF >> (8 - (x)))
    #define RADIO_SHORTS_COMMON                                                    \
    	(RADIO_SHORTS_READY_START_Msk | RADIO_SHORTS_END_DISABLE_Msk |         \
    	 RADIO_SHORTS_ADDRESS_RSSISTART_Msk |                                  \
    	 RADIO_SHORTS_DISABLED_RSSISTOP_Msk)
    #ifdef CONFIG_ESB_SYS_TIMER0
    #define ESB_SYS_TIMER NRF_TIMER0
    #define ESB_SYS_TIMER_IRQn TIMER0_IRQn
    #ifdef CONFIG_ESB_SYS_TIMER1
    #define ESB_SYS_TIMER NRF_TIMER1
    #define ESB_SYS_TIMER_IRQn TIMER1_IRQn
    #ifdef CONFIG_ESB_SYS_TIMER2
    #define ESB_SYS_TIMER NRF_TIMER2
    #define ESB_SYS_TIMER_IRQn TIMER2_IRQn
    #ifdef CONFIG_ESB_SYS_TIMER3
    #define ESB_SYS_TIMER NRF_TIMER3
    #define ESB_SYS_TIMER_IRQn TIMER3_IRQn
    #ifdef CONFIG_ESB_SYS_TIMER4
    #define ESB_SYS_TIMER NRF_TIMER4
    #define ESB_SYS_TIMER_IRQn TIMER4_IRQn
    /* Internal Enhanced ShockBurst module state. */
    enum esb_state {
    	ESB_STATE_IDLE,		/* Idle. */
    	ESB_STATE_PTX_TX,       /* Transmitting without acknowledgment. */
    	ESB_STATE_PTX_TX_ACK,   /* Transmitting with acknowledgment. */
    	ESB_STATE_PTX_RX_ACK,   /* Transmitting with acknowledgment and
    				 * reception of payload with the
    				 * acknowledgment response.
    	ESB_STATE_PRX,		/* Receiving packets without ACK. */
    	ESB_STATE_PRX_SEND_ACK, /* Transmitting ACK in RX mode. */
    /* Pipe info PID and CRC and acknowledgment payload. */
    struct pipe_info {
    	uint16_t crc;	  /* CRC of the last received packet.
    			   * Used to detect retransmits.
    	uint8_t pid;	  /* Packet ID of the last received packet
    	bool ack_payload; /* State of the transmission of ACK payloads. */
    /* Structure used by the PRX to organize ACK payloads for multiple pipes. */
    struct payload_wrap {
    	/* Pointer to the ACK payload. */
    	struct esb_payload  *p_payload;
    	/* Value used to determine if the current payload pointer is used. */
    	bool in_use;
    	/* Pointer to the next ACK payload queued on the same pipe. */
    	struct payload_wrap *p_next;
    /* First-in, first-out queue of payloads to be transmitted. */
    struct payload_tx_fifo {
    	 /* Payload queue */
    	struct esb_payload *payload[CONFIG_ESB_TX_FIFO_SIZE];
    	uint32_t back;	/* Back of the queue (last in). */
    	uint32_t front;	/* Front of queue (first out). */
    	uint32_t count;	/* Number of elements in the queue. */
    /* First-in, first-out queue of received payloads. */
    struct payload_rx_fifo {
    	 /* Payload queue */
    	struct esb_payload *payload[CONFIG_ESB_RX_FIFO_SIZE];
    /* Enhanced ShockBurst address.
     * Enhanced ShockBurst addresses consist of a base address and a prefix
     * that is unique for each pipe. See @ref esb_addressing in the ESB user
     * guide for more information.
    struct esb_address {
    	uint8_t base_addr_p0[4];	/* Base address for pipe 0, in big endian. */
    	uint8_t base_addr_p1[4];   /* Base address for pipe 1-7, in big endian. */
    	uint8_t pipe_prefixes[8];	/* Address prefix for pipe 0 to 7. */
    	uint8_t num_pipes;		/* Number of pipes available. */
    	uint8_t addr_length;	/* Length of the address plus the prefix. */
    	uint8_t rx_pipes_enabled;	/* Bitfield for enabled pipes. */
    	uint8_t rf_channel;        /* Channel to use (between 0 and 100). */
    static bool esb_initialized;
    static struct esb_config esb_cfg;
    static volatile enum esb_state esb_state = ESB_STATE_IDLE;
    /* Default address configuration for ESB.
     * Roughly equal to the nRF24Lxx defaults, except for the number of pipes,
     * because more pipes are supported.
    __ALIGN(4)
    static struct esb_address esb_addr = {
    	.base_addr_p0 = {0xE7, 0xE7, 0xE7, 0xE7},
    	.base_addr_p1 = {0xC2, 0xC2, 0xC2, 0xC2},
    	.pipe_prefixes = {0xE7, 0xC2, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8},
    	.addr_length = 5,
    	.num_pipes = CONFIG_ESB_PIPE_COUNT,
    	.rf_channel = 2,
    	.rx_pipes_enabled = 0xFF
    static esb_event_handler event_handler;
    static struct esb_payload *current_payload;
    /* FIFOs and buffers */
    static struct payload_tx_fifo tx_fifo;
    static struct payload_rx_fifo rx_fifo;
    static uint8_t tx_payload_buffer[CONFIG_ESB_MAX_PAYLOAD_LENGTH + 2];
    static uint8_t rx_payload_buffer[CONFIG_ESB_MAX_PAYLOAD_LENGTH + 2];
    /* Random access buffer variables for ACK payload handling */
    struct payload_wrap ack_pl_wrap[CONFIG_ESB_TX_FIFO_SIZE];
    struct payload_wrap *ack_pl_wrap_pipe[CONFIG_ESB_PIPE_COUNT];
    /* Run time variables */
    static uint8_t pids[CONFIG_ESB_PIPE_COUNT];
    static struct pipe_info rx_pipe_info[CONFIG_ESB_PIPE_COUNT];
    static volatile uint32_t interrupt_flags;
    static volatile uint32_t retransmits_remaining;
    static volatile uint32_t last_tx_attempts;
    static volatile uint32_t wait_for_ack_timeout_us;
    static uint32_t radio_shorts_common = RADIO_SHORTS_COMMON;
    /* PPI or DPPI instances */
    #ifdef DPPI_PRESENT
    typedef uint8_t ppi_channel_t;
    #else
    typedef nrf_ppi_channel_t ppi_channel_t;
    static ppi_channel_t ppi_ch_radio_ready_timer_start;
    static ppi_channel_t ppi_ch_radio_address_timer_stop;
    static ppi_channel_t ppi_ch_timer_compare0_radio_disable;
    static ppi_channel_t ppi_ch_timer_compare1_radio_txen;
    static uint32_t ppi_all_channels_mask;
    /* These function pointers are changed dynamically, depending on protocol
     * configuration and state. Note that they will be 0 initialized.
    static void (*on_radio_disabled)(void);
    static void (*on_radio_end)(void);
    static void (*update_rf_payload_format)(uint32_t payload_length);
    /*  The following functions are assigned to the function pointers above. */
    static void on_radio_disabled_tx_noack(void);
    static void on_radio_disabled_tx(void);
    static void on_radio_disabled_tx_wait_for_ack(void);
    static void on_radio_disabled_rx(void);
    static void on_radio_disabled_rx_ack(void);
    /*  Function to do bytewise bit-swap on an unsigned 32-bit value */
    static uint32_t bytewise_bit_swap(const uint8_t *input)
    #if __CORTEX_M == (0x04U)
    	uint32_t inp = (*(uint32_t *)input);
    	return sys_cpu_to_be32((uint32_t)__RBIT(inp));
    #else
    	uint32_t inp = sys_cpu_to_le32(*(uint32_t *)input);
    	inp = (inp & 0xF0F0F0F0) >> 4 | (inp & 0x0F0F0F0F) << 4;
    	inp = (inp & 0xCCCCCCCC) >> 2 | (inp & 0x33333333) << 2;
    	inp = (inp & 0xAAAAAAAA) >> 1 | (inp & 0x55555555) << 1;
    	return inp;
    /* Convert a base address from nRF24L format to nRF5 format */
    static uint32_t addr_conv(const uint8_t *addr)
    	return __REV(bytewise_bit_swap(addr));
    static inline void apply_errata143_workaround(void)
    	/* Workaround for Errata 143
    	 * Check if the most significant bytes of address 0 (including
    	 * prefix) match those of another address. It's recommended to
    	 * use a unique address 0 since this will avoid the 3dBm penalty
    	 * incurred from the workaround.
    	uint32_t base_address_mask =
    		esb_addr.addr_length == 5 ? 0xFFFF0000 : 0xFF000000;
    	/* Load the two addresses before comparing them to ensure
    	 * defined ordering of volatile accesses.
    	uint32_t addr0 = NRF_RADIO->BASE0 & base_address_mask;
    	uint32_t addr1 = NRF_RADIO->BASE1 & base_address_mask;
    	if (addr0 == addr1) {
    		uint32_t prefix0 = NRF_RADIO->PREFIX0 & 0x000000FF;
    		uint32_t prefix1 = (NRF_RADIO->PREFIX0 & 0x0000FF00) >> 8;
    		uint32_t prefix2 = (NRF_RADIO->PREFIX0 & 0x00FF0000) >> 16;
    		uint32_t prefix3 = (NRF_RADIO->PREFIX0 & 0xFF000000) >> 24;
    		uint32_t prefix4 = NRF_RADIO->PREFIX1 & 0x000000FF;
    		uint32_t prefix5 = (NRF_RADIO->PREFIX1 & 0x0000FF00) >> 8;
    		uint32_t prefix6 = (NRF_RADIO->PREFIX1 & 0x00FF0000) >> 16;
    		uint32_t prefix7 = (NRF_RADIO->PREFIX1 & 0xFF000000) >> 24;
    		if (prefix0 == prefix1 || prefix0 == prefix2 ||
    			prefix0 == prefix3 || prefix0 == prefix4 ||
    			prefix0 == prefix5 || prefix0 == prefix6 ||
    			prefix0 == prefix7) {
    			/* This will cause a 3dBm sensitivity loss,
    			 * avoid using such address combinations if possible.
    			*(volatile uint32_t *)0x40001774 =
    				((*(volatile uint32_t *)0x40001774) & 0xfffffffe) | 0x01000000;
    static void update_rf_payload_format_esb_dpl(uint32_t payload_length)
    #if (CONFIG_ESB_MAX_PAYLOAD_LENGTH <= 32)
    	/* Using 6 bits for length */
    	NRF_RADIO->PCNF0 = (0 << RADIO_PCNF0_S0LEN_Pos) |
    			   (6 << RADIO_PCNF0_LFLEN_Pos) |
    			   (3 << RADIO_PCNF0_S1LEN_Pos);
    #else
    	/* Using 8 bits for length */
    			   (8 << RADIO_PCNF0_LFLEN_Pos) |
    	NRF_RADIO->PCNF1 =
    		(RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
    		(RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos) |
    		((esb_addr.addr_length - 1) << RADIO_PCNF1_BALEN_Pos) |
    		(0 << RADIO_PCNF1_STATLEN_Pos) |
    		(CONFIG_ESB_MAX_PAYLOAD_LENGTH << RADIO_PCNF1_MAXLEN_Pos);
    static void update_rf_payload_format_esb(uint32_t payload_length)
    	NRF_RADIO->PCNF0 = (1 << RADIO_PCNF0_S0LEN_Pos) |
    			   (0 << RADIO_PCNF0_LFLEN_Pos) |
    			   (1 << RADIO_PCNF0_S1LEN_Pos);
    	NRF_RADIO->PCNF1 =
    		(payload_length << RADIO_PCNF1_STATLEN_Pos) |
    		(payload_length << RADIO_PCNF1_MAXLEN_Pos);
    static void update_radio_addresses(uint8_t update_mask)
    	if ((update_mask & ADDR_UPDATE_MASK_BASE0) != 0) {
    		NRF_RADIO->BASE0 = addr_conv(esb_addr.base_addr_p0);
    	if ((update_mask & ADDR_UPDATE_MASK_BASE1) != 0) {
    		NRF_RADIO->BASE1 = addr_conv(esb_addr.base_addr_p1);
    	if ((update_mask & ADDR_UPDATE_MASK_PREFIX) != 0) {
    		NRF_RADIO->PREFIX0 =
    			bytewise_bit_swap(&esb_addr.pipe_prefixes[0]);
    		NRF_RADIO->PREFIX1 =
    			bytewise_bit_swap(&esb_addr.pipe_prefixes[4]);
    	/* Workaround for Errata 143 */
    #if NRF52_ERRATA_143_ENABLE_WORKAROUND
    	if (nrf52_errata_143()) {
    		apply_errata143_workaround();
    static void update_radio_tx_power(void)
    	NRF_RADIO->TXPOWER = esb_cfg.tx_output_power
    			     << RADIO_TXPOWER_TXPOWER_Pos;
    static bool update_radio_bitrate(void)
    	NRF_RADIO->MODE = esb_cfg.bitrate << RADIO_MODE_MODE_Pos;
    	switch (esb_cfg.bitrate) {
    	case ESB_BITRATE_2MBPS:
    #if defined(CONFIG_SOC_SERIES_NRF52X) || defined(CONFIG_SOC_NRF5340_CPUNET)
    	case ESB_BITRATE_2MBPS_BLE:
    		wait_for_ack_timeout_us = RX_ACK_TIMEOUT_US_2MBPS;
    	case ESB_BITRATE_1MBPS:
    		wait_for_ack_timeout_us = RX_ACK_TIMEOUT_US_1MBPS;
    #ifdef CONFIG_SOC_SERIES_NRF51X
    	case ESB_BITRATE_250KBPS:
    		wait_for_ack_timeout_us = RX_ACK_TIMEOUT_US_250KBPS;
    #endif /* CONFIG_SOC_SERIES_NRF51X */
    	case ESB_BITRATE_1MBPS_BLE:
    		wait_for_ack_timeout_us = RX_ACK_TIMEOUT_US_1MBPS_BLE;
    		/* Should not be reached */
    		return false;
    	return true;
    static bool update_radio_protocol(void)
    	switch (esb_cfg.protocol) {
    	case ESB_PROTOCOL_ESB_DPL:
    		update_rf_payload_format = update_rf_payload_format_esb_dpl;
    	case ESB_PROTOCOL_ESB:
    		update_rf_payload_format = update_rf_payload_format_esb;
    		return false;
    	return true;
    static bool update_radio_crc(void)
    	switch (esb_cfg.crc) {
    	case ESB_CRC_16BIT:
    		NRF_RADIO->CRCINIT = 0xFFFFUL;  /* Initial value */
    		NRF_RADIO->CRCPOLY = 0x11021UL; /* CRC poly: x^16+x^12^x^5+1 */
    		NRF_RADIO->CRCCNF = ESB_CRC_16BIT << RADIO_CRCCNF_LEN_Pos;
    	case ESB_CRC_8BIT:
    		NRF_RADIO->CRCINIT = 0xFFUL;  /* Initial value */
    		NRF_RADIO->CRCPOLY = 0x107UL; /* CRC poly: x^8+x^2^x^1+1 */
    		NRF_RADIO->CRCCNF = ESB_CRC_8BIT << RADIO_CRCCNF_LEN_Pos;
    	case ESB_CRC_OFF:
    		NRF_RADIO->CRCINIT = 0x00UL;
    		NRF_RADIO->CRCPOLY = 0x00UL;
    		NRF_RADIO->CRCCNF = ESB_CRC_OFF << RADIO_CRCCNF_LEN_Pos;
    		return false;
    	return true;
    static bool update_radio_parameters(void)
    	bool params_valid = true;
    	update_radio_tx_power();
    	params_valid &= update_radio_bitrate();
    	params_valid &= update_radio_protocol();
    	params_valid &= update_radio_crc();
    	update_rf_payload_format(esb_cfg.payload_length);
    	params_valid &=
    	    (esb_cfg.retransmit_delay >= RETRANSMIT_DELAY_MIN);
    	return params_valid;
    static void reset_fifos(void)
    	tx_fifo.back = 0;
    	tx_fifo.front = 0;
    	tx_fifo.count = 0;
    	rx_fifo.back = 0;
    	rx_fifo.front = 0;
    	rx_fifo.count = 0;
    static void initialize_fifos(void)
    	static struct esb_payload rx_payload[CONFIG_ESB_RX_FIFO_SIZE];
    	static struct esb_payload tx_payload[CONFIG_ESB_TX_FIFO_SIZE];
    	reset_fifos();
    	for (size_t i = 0; i < CONFIG_ESB_TX_FIFO_SIZE; i++) {
    		tx_fifo.payload[i] = &tx_payload[i];
    	for (size_t i = 0; i < CONFIG_ESB_RX_FIFO_SIZE; i++) {
    		rx_fifo.payload[i] = &rx_payload[i];
    		ack_pl_wrap[i].p_payload = &tx_payload[i];
    		ack_pl_wrap[i].in_use = false;
    		ack_pl_wrap[i].p_next = 0;
    	for (size_t i = 0; i < CONFIG_ESB_PIPE_COUNT; i++) {
    		ack_pl_wrap_pipe[i] = 0;
    static void tx_fifo_remove_last(void)
    	if (tx_fifo.count == 0) {
    		return;
    	uint32_t key = irq_lock();
    	tx_fifo.count--;
    	if (++tx_fifo.front >= CONFIG_ESB_TX_FIFO_SIZE) {
    		tx_fifo.front = 0;
    	irq_unlock(key);
    /*  Function to push the content of the rx_buffer to the RX FIFO.
     *  The module will point the register NRF_RADIO->PACKETPTR to a buffer for
     *  receiving packets. After receiving a packet the module will call this
     *  function to copy the received data to the RX FIFO.
     *  @param  pipe Pipe number to set for the packet.
     *  @param  pid  Packet ID.
     *  @retval true   Operation successful.
     *  @retval false  Operation failed.
    static bool rx_fifo_push_rfbuf(uint8_t pipe, uint8_t pid)
    	if (rx_fifo.count >= CONFIG_ESB_RX_FIFO_SIZE) {
    		return false;
    	if (esb_cfg.protocol == ESB_PROTOCOL_ESB_DPL) {
    		if (rx_payload_buffer[0] > CONFIG_ESB_MAX_PAYLOAD_LENGTH) {
    			return false;
    		rx_fifo.payload[rx_fifo.back]->length = rx_payload_buffer[0];
    	} else if (esb_cfg.mode == ESB_MODE_PTX) {
    		/* Received packet is an acknowledgment */
    		rx_fifo.payload[rx_fifo.back]->length = 0;
    	} else {
    		rx_fifo.payload[rx_fifo.back]->length = esb_cfg.payload_length;
    	memcpy(rx_fifo.payload[rx_fifo.back]->data, &rx_payload_buffer[2],
    	       rx_fifo.payload[rx_fifo.back]->length);
    	rx_fifo.payload[rx_fifo.back]->pipe = pipe;
    	rx_fifo.payload[rx_fifo.back]->rssi = NRF_RADIO->RSSISAMPLE;
    	rx_fifo.payload[rx_fifo.back]->pid = pid;
    	rx_fifo.payload[rx_fifo.back]->noack = !(rx_payload_buffer[1] & 0x01);
    	if (++rx_fifo.back >= CONFIG_ESB_RX_FIFO_SIZE) {
    		rx_fifo.back = 0;
    	rx_fifo.count++;
    	return true;
    static void sys_timer_init(void)
    	/* Configure the system timer with a 1 MHz base frequency */
    	ESB_SYS_TIMER->PRESCALER = 4;
    	ESB_SYS_TIMER->BITMODE = TIMER_BITMODE_BITMODE_16Bit;
    	ESB_SYS_TIMER->SHORTS = TIMER_SHORTS_COMPARE1_CLEAR_Msk |
    				TIMER_SHORTS_COMPARE1_STOP_Msk;
    static void ppi_init(void)
    #ifdef DPPI_PRESENT
    	nrfx_dppi_channel_alloc(&ppi_ch_radio_ready_timer_start);
    	nrfx_dppi_channel_alloc(&ppi_ch_radio_address_timer_stop);
    	nrfx_dppi_channel_alloc(&ppi_ch_timer_compare0_radio_disable);
    	nrfx_dppi_channel_alloc(&ppi_ch_timer_compare1_radio_txen);
    	NRF_RADIO->PUBLISH_READY          = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | ppi_ch_radio_ready_timer_start;
    	ESB_SYS_TIMER->SUBSCRIBE_START    = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | ppi_ch_radio_ready_timer_start;
    	NRF_RADIO->PUBLISH_ADDRESS        = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | ppi_ch_radio_address_timer_stop;
    	ESB_SYS_TIMER->SUBSCRIBE_SHUTDOWN = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | ppi_ch_radio_address_timer_stop;
    	ESB_SYS_TIMER->PUBLISH_COMPARE[0] = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | ppi_ch_timer_compare0_radio_disable;
    	NRF_RADIO->SUBSCRIBE_DISABLE      = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | ppi_ch_timer_compare0_radio_disable;
    	ESB_SYS_TIMER->PUBLISH_COMPARE[1] = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | ppi_ch_timer_compare1_radio_txen;
    	NRF_RADIO->SUBSCRIBE_TXEN         = DPPIC_SUBSCRIBE_CHG_EN_EN_Msk | ppi_ch_timer_compare1_radio_txen;
    #else
    	nrfx_ppi_channel_alloc(&ppi_ch_radio_ready_timer_start);
    	nrfx_ppi_channel_alloc(&ppi_ch_radio_address_timer_stop);
    	nrfx_ppi_channel_alloc(&ppi_ch_timer_compare0_radio_disable);
    	nrfx_ppi_channel_alloc(&ppi_ch_timer_compare1_radio_txen);
    	nrfx_ppi_channel_assign(ppi_ch_radio_ready_timer_start,
    		(uint32_t)&NRF_RADIO->EVENTS_READY, (uint32_t)&ESB_SYS_TIMER->TASKS_START);
    	nrfx_ppi_channel_assign(ppi_ch_radio_address_timer_stop,
    		(uint32_t)&NRF_RADIO->EVENTS_ADDRESS, (uint32_t)&ESB_SYS_TIMER->TASKS_SHUTDOWN);
    	nrfx_ppi_channel_assign(ppi_ch_timer_compare0_radio_disable,
    		(uint32_t)&ESB_SYS_TIMER->EVENTS_COMPARE[0], (uint32_t)&NRF_RADIO->TASKS_DISABLE);
    	nrfx_ppi_channel_assign(ppi_ch_timer_compare1_radio_txen,
    		(uint32_t)&ESB_SYS_TIMER->EVENTS_COMPARE[1], (uint32_t)&NRF_RADIO->TASKS_TXEN);
    	ppi_all_channels_mask = (1 << ppi_ch_radio_ready_timer_start) | (1 << ppi_ch_radio_address_timer_stop) |
    							(1 << ppi_ch_timer_compare0_radio_disable) | (1 << ppi_ch_timer_compare1_radio_txen);
    static void start_tx_transaction(void)
    	bool ack;
    	last_tx_attempts = 1;
    	/* Prepare the payload */
    	current_payload = tx_fifo.payload[tx_fifo.front];
    		update_rf_payload_format(current_payload->length);
    		tx_payload_buffer[0] = current_payload->pid;
    		tx_payload_buffer[1] = 0;
    		memcpy(&tx_payload_buffer[2], current_payload->data,
    		NRF_RADIO->SHORTS = radio_shorts_common |
    				    RADIO_SHORTS_DISABLED_RXEN_Msk;
    		NRF_RADIO->INTENSET = RADIO_INTENSET_DISABLED_Msk |
    				      RADIO_INTENSET_READY_Msk;
    		/* Configure the retransmit counter */
    		retransmits_remaining = esb_cfg.retransmit_count;
    		on_radio_disabled = on_radio_disabled_tx;
    		esb_state = ESB_STATE_PTX_TX_ACK;
    		ack = !current_payload->noack || !esb_cfg.selective_auto_ack;
    		tx_payload_buffer[0] = current_payload->length;
    		tx_payload_buffer[1] = current_payload->pid << 1;
    		tx_payload_buffer[1] |= current_payload->noack ? 0x00 : 0x01;
    		/* Handling ack if noack is set to false or if
    		 * selective auto ack is turned off
    		if (ack) {
    		} else {
    			NRF_RADIO->SHORTS = radio_shorts_common;
    			NRF_RADIO->INTENSET = RADIO_INTENSET_DISABLED_Msk;
    			on_radio_disabled = on_radio_disabled_tx_noack;
    			esb_state = ESB_STATE_PTX_TX;
    	NRF_RADIO->TXADDRESS = current_payload->pipe;
    	NRF_RADIO->RXADDRESSES = 1 << current_payload->pipe;
    	NRF_RADIO->FREQUENCY = esb_addr.rf_channel;
    	NRF_RADIO->PACKETPTR = (uint32_t)tx_payload_buffer;
    	NVIC_ClearPendingIRQ(RADIO_IRQn);
    	irq_enable(RADIO_IRQn);
    	NRF_RADIO->EVENTS_ADDRESS = 0;
    	NRF_RADIO->EVENTS_PAYLOAD = 0;
    	NRF_RADIO->EVENTS_DISABLED = 0;
    	NRF_RADIO->TASKS_TXEN = 1;
    	interrupt_flags |= INT_TX_SUCCESS_MSK;
    	tx_fifo_remove_last();
    		NVIC_SetPendingIRQ(ESB_EVT_IRQ);
    	} else {
    		start_tx_transaction();
    	/* Remove the DISABLED -> RXEN shortcut, to make sure the radio stays
    	 * disabled after the RX window
    	/* Make sure the timer is started the next time the radio is ready,
    	 * and that it will disable the radio automatically if no packet is
    	 * received by the time defined in wait_for_ack_timeout_us
    	ESB_SYS_TIMER->CC[0] = wait_for_ack_timeout_us;
    	ESB_SYS_TIMER->CC[1] = esb_cfg.retransmit_delay - 40;
    	ESB_SYS_TIMER->TASKS_CLEAR = 1;
    	ESB_SYS_TIMER->EVENTS_COMPARE[0] = 0;
    	ESB_SYS_TIMER->EVENTS_COMPARE[1] = 0;
    	/* Remove */
    	ESB_SYS_TIMER->TASKS_START = 1;
    	nrfx_gppi_channels_enable(ppi_all_channels_mask);
    	nrfx_gppi_channels_disable(1 << ppi_ch_timer_compare1_radio_txen);
    	NRF_RADIO->EVENTS_END = 0;
    	if (esb_cfg.protocol == ESB_PROTOCOL_ESB) {
    		update_rf_payload_format(0);
    	NRF_RADIO->PACKETPTR = (uint32_t)rx_payload_buffer;
    	on_radio_disabled = on_radio_disabled_tx_wait_for_ack;
    	esb_state = ESB_STATE_PTX_RX_ACK;
    	/* This marks the completion of a TX_RX sequence (TX with ACK) */
    	/* Make sure the timer will not deactivate the radio if a packet is
    	 * received.
    	nrfx_gppi_channels_disable(ppi_all_channels_mask);
    	/* If the radio has received a packet and the CRC status is OK */
    	if (NRF_RADIO->EVENTS_END && NRF_RADIO->CRCSTATUS != 0) {
    		ESB_SYS_TIMER->TASKS_SHUTDOWN = 1;
    		last_tx_attempts = esb_cfg.retransmit_count -
    				   retransmits_remaining + 1;
    		if (esb_cfg.protocol != ESB_PROTOCOL_ESB &&
    		    rx_payload_buffer[0] > 0) {
    			if (rx_fifo_push_rfbuf((uint8_t)NRF_RADIO->TXADDRESS,
    					       rx_payload_buffer[1] >> 1)) {
    				interrupt_flags |=
    					INT_RX_DATA_RECEIVED_MSK;
    		if ((tx_fifo.count == 0) ||
    		    (esb_cfg.tx_mode == ESB_TXMODE_MANUAL)) {
    		} else {
    	} else {
    		if (retransmits_remaining-- == 0) {
    			/* All retransmits are expended, and the TX operation is
    			 * suspended
    			last_tx_attempts = esb_cfg.retransmit_count + 1;
    			interrupt_flags |= INT_TX_FAILED_MSK;
    		} else {
    			/* There are still more retransmits left, TX mode should
    			 * be entered again as soon as the system timer reaches
    			 * CC[1].
    			nrfx_gppi_channels_enable(1 << ppi_ch_timer_compare1_radio_txen);
    			if (ESB_SYS_TIMER->EVENTS_COMPARE[1]) {
    static void clear_events_restart_rx(void)
    	NRF_RADIO->TASKS_DISABLE = 1;
    	while (NRF_RADIO->EVENTS_DISABLED == 0) {
    		/* wait for register to settle */
    			    RADIO_SHORTS_DISABLED_TXEN_Msk;
    	NRF_RADIO->TASKS_RXEN = 1;
    static void on_radio_disabled_rx_dpl(bool retransmit_payload,
    				     struct pipe_info *pipe_info)
    	uint32_t pipe = NRF_RADIO->RXMATCH;
    	if (tx_fifo.count > 0 && ack_pl_wrap_pipe[pipe] != 0) {
    		current_payload = ack_pl_wrap_pipe[pipe]->p_payload;
    		/* Pipe stays in ACK with payload until TX FIFO is empty */
    		/* Do not report TX success on first ack payload or retransmit */
    		if (pipe_info->ack_payload == true && !retransmit_payload) {
    			ack_pl_wrap_pipe[pipe]->in_use = false;
    			ack_pl_wrap_pipe[pipe] = ack_pl_wrap_pipe[pipe]->p_next;
    			tx_fifo.count--;
    			} else {
    				current_payload = 0;
    			/* ACK payloads also require TX_DS */
    			/* (page 40 of the 'nRF24LE1_Product_Specification_rev1_6.pdf') */
    		if (current_payload != 0) {
    			pipe_info->ack_payload = true;
    		} else {
    			pipe_info->ack_payload = false;
    			tx_payload_buffer[0] = 0;
    	} else {
    	tx_payload_buffer[1] = rx_payload_buffer[1];
    	bool retransmit_payload = false;
    	bool send_rx_event = true;
    	struct pipe_info *pipe_info;
    	if (NRF_RADIO->CRCSTATUS == 0) {
    		clear_events_restart_rx();
    		return;
    		return;
    	pipe_info = &rx_pipe_info[NRF_RADIO->RXMATCH];
    	if (NRF_RADIO->RXCRC == pipe_info->crc &&
    	    (rx_payload_buffer[1] >> 1) == pipe_info->pid) {
    		retransmit_payload = true;
    		send_rx_event = false;
    	pipe_info->pid = rx_payload_buffer[1] >> 1;
    	pipe_info->crc = NRF_RADIO->RXCRC;
    	/* Check if an ack should be sent */
    	if ((esb_cfg.selective_auto_ack == false) ||
    	    ((rx_payload_buffer[1] & 0x01) == 1)) {
    			on_radio_disabled_rx_dpl(retransmit_payload, pipe_info);
    			tx_payload_buffer[0] = rx_payload_buffer[0];
    		esb_state = ESB_STATE_PRX_SEND_ACK;
    		NRF_RADIO->TXADDRESS = NRF_RADIO->RXMATCH;
    		on_radio_disabled = on_radio_disabled_rx_ack;
    	} else {
    	if (send_rx_event) {
    		/* Push the new packet to the RX buffer and trigger a received
    		 * event if the operation was
    		 * successful.
    		if (rx_fifo_push_rfbuf(NRF_RADIO->RXMATCH, pipe_info->pid)) {
    			interrupt_flags |= INT_RX_DATA_RECEIVED_MSK;
    	on_radio_disabled = on_radio_disabled_rx;
    	esb_state = ESB_STATE_PRX;
    /* Retrieve interrupt flags and reset them.
     * @param[out] interrupts	Interrupt flags.
    static void get_and_clear_irqs(uint32_t *interrupts)
    	__ASSERT_NO_MSG(interrupts != NULL);
    	*interrupts = interrupt_flags;
    	interrupt_flags = 0;
    	irq_unlock(key);
    static void radio_irq_handler(void)
    	if (NRF_RADIO->EVENTS_READY &&
    	    (NRF_RADIO->INTENSET & RADIO_INTENSET_READY_Msk)) {
    		NRF_RADIO->EVENTS_READY = 0;
    		ESB_SYS_TIMER->TASKS_START;
    	    (NRF_RADIO->INTENSET & RADIO_INTENSET_END_Msk)) {
    		/* Call the correct on_radio_end function, depending on the
    		 * current protocol state.
    		if (on_radio_end) {
    			on_radio_end();
    	if (NRF_RADIO->EVENTS_DISABLED &&
    	    (NRF_RADIO->INTENSET & RADIO_INTENSET_DISABLED_Msk)) {
    		/* Call the correct on_radio_disable function, depending on the
    		if (on_radio_disabled) {
    			on_radio_disabled();
    static void esb_evt_irq_handler(void)
    	uint32_t interrupts;
    	struct esb_evt event;
    	event.tx_attempts = last_tx_attempts;
    	get_and_clear_irqs(&interrupts);
    	if (event_handler != NULL) {
    		if (interrupts & INT_TX_SUCCESS_MSK) {
    			event.evt_id = ESB_EVENT_TX_SUCCESS;
    			event_handler(&event);
    		if (interrupts & INT_TX_FAILED_MSK) {
    			event.evt_id = ESB_EVENT_TX_FAILED;
    		if (interrupts & INT_RX_DATA_RECEIVED_MSK) {
    			event.evt_id = ESB_EVENT_RX_RECEIVED;
    ISR_DIRECT_DECLARE(RADIO_IRQHandler)
    	radio_irq_handler();
    	ISR_DIRECT_PM();
    	return 1;
    ISR_DIRECT_DECLARE(ESB_EVT_IRQHandler)
    	esb_evt_irq_handler();
    	ISR_DIRECT_PM();
    	return 1;
    ISR_DIRECT_DECLARE(ESB_SYS_TIMER_IRQHandler)
    	ISR_DIRECT_PM();
    	return 1;
    int esb_init(const struct esb_config *config)
    	if (config == NULL) {
    		return -EINVAL;
    	if (esb_initialized) {
    		esb_disable();
    	event_handler = config->event_handler;
    	memcpy(&esb_cfg, config, sizeof(esb_cfg));
    	memset(rx_pipe_info, 0, sizeof(rx_pipe_info));
    	memset(pids, 0, sizeof(pids));
    	update_radio_parameters();
    	/* Configure radio address registers according to ESB default values */
    	NRF_RADIO->BASE0 = 0xE7E7E7E7;
    	NRF_RADIO->BASE1 = 0x43434343;
    	NRF_RADIO->PREFIX0 = 0x23C343E7;
    	NRF_RADIO->PREFIX1 = 0x13E363A3;
    	initialize_fifos();
    	sys_timer_init();
    	ppi_init();
    	NRF_RADIO->MODECNF0 = (NRF_RADIO->MODECNF0 & ~RADIO_MODECNF0_RU_Pos) | RADIO_MODECNF0_RU_Fast << RADIO_MODECNF0_RU_Pos;
    	IRQ_DIRECT_CONNECT(RADIO_IRQn, CONFIG_ESB_RADIO_IRQ_PRIORITY,
    			   RADIO_IRQHandler, 0);
    	IRQ_DIRECT_CONNECT(ESB_EVT_IRQ, CONFIG_ESB_EVENT_IRQ_PRIORITY,
    			   ESB_EVT_IRQHandler, 0);
    	IRQ_DIRECT_CONNECT(ESB_SYS_TIMER_IRQn, CONFIG_ESB_EVENT_IRQ_PRIORITY,
    			   ESB_SYS_TIMER_IRQHandler, 0);
    	irq_enable(ESB_EVT_IRQ);
    	irq_enable(ESB_SYS_TIMER_IRQn);
    	esb_initialized = true;
    #ifdef CONFIG_SOC_NRF52832
    	if ((NRF_FICR->INFO.VARIANT & 0x0000FF00) == 0x00004500) {
    		/* Check if the device is an nRF52832 Rev. 2. */
    		/* Workaround for nRF52832 rev 2 errata 182 */
    		*(volatile uint32_t *)0x4000173C |= (1 << 10);
    	return 0;
    int esb_suspend(void)
    	if (esb_state != ESB_STATE_IDLE) {
    		return -EBUSY;
    	/*  Clear PPI */
    	return 0;
    void esb_disable(void)
    	/*  Clear PPI */
    	esb_initialized = false;
    	reset_fifos();
    	/*  Disable the interrupts used by ESB */
    	irq_disable(RADIO_IRQn);
    	irq_disable(ESB_SYS_TIMER_IRQn);
    	irq_disable(ESB_EVT_IRQ);
    	NRF_RADIO->SHORTS =
    	    RADIO_SHORTS_READY_START_Enabled << RADIO_SHORTS_READY_START_Pos |
    	    RADIO_SHORTS_END_DISABLE_Enabled << RADIO_SHORTS_END_DISABLE_Pos;
    bool esb_is_idle(void)
    	return (esb_state == ESB_STATE_IDLE);
    static struct payload_wrap *find_free_payload_cont(void)
    	for (int i = 0; i < CONFIG_ESB_TX_FIFO_SIZE; i++) {
    		if (!ack_pl_wrap[i].in_use)
    			return &ack_pl_wrap[i];
    	return 0;
    int esb_write_payload(const struct esb_payload *payload)
    	if (!esb_initialized) {
    		return -EACCES;
    	if (payload == NULL) {
    		return -EINVAL;
    	if (payload->length == 0 ||
    	    payload->length > CONFIG_ESB_MAX_PAYLOAD_LENGTH ||
    	    (esb_cfg.protocol == ESB_PROTOCOL_ESB &&
    	     payload->length > esb_cfg.payload_length)) {
    		return -EMSGSIZE;
    	if (tx_fifo.count >= CONFIG_ESB_TX_FIFO_SIZE) {
    		return -ENOMEM;
    	if (payload->pipe >= CONFIG_ESB_PIPE_COUNT) {
    		return -EINVAL;
    		memcpy(tx_fifo.payload[tx_fifo.back], payload,
    			sizeof(struct esb_payload));
    		pids[payload->pipe] = (pids[payload->pipe] + 1) % (PID_MAX + 1);
    		tx_fifo.payload[tx_fifo.back]->pid = pids[payload->pipe];
    		if (++tx_fifo.back >= CONFIG_ESB_TX_FIFO_SIZE) {
    			tx_fifo.back = 0;
    		tx_fifo.count++;
    	} else {
    		struct payload_wrap *new_ack_payload = find_free_payload_cont();
    		if (new_ack_payload != 0) {
    			new_ack_payload->in_use = true;
    			new_ack_payload->p_next = 0;
    			memcpy(new_ack_payload->p_payload, payload, sizeof(struct esb_payload));
    			new_ack_payload->p_payload->pid = pids[payload->pipe];
    			if (ack_pl_wrap_pipe[payload->pipe] == 0) {
    				ack_pl_wrap_pipe[payload->pipe] = new_ack_payload;
    			} else {
    				struct payload_wrap *pl = ack_pl_wrap_pipe[payload->pipe];
    				while (pl->p_next != 0) {
    					pl = (struct payload_wrap *)pl->p_next;
    				pl->p_next = (struct payload_wrap *)new_ack_payload;
    			tx_fifo.count++;
    	irq_unlock(key);
    	if (esb_cfg.mode == ESB_MODE_PTX &&
    	    esb_cfg.tx_mode == ESB_TXMODE_AUTO &&
    	    esb_state == ESB_STATE_IDLE) {
    	return 0;
    int esb_read_rx_payload(struct esb_payload *payload)
    		return -EACCES;
    		return -EINVAL;
    	if (rx_fifo.count == 0) {
    		return -ENODATA;
    	payload->length = rx_fifo.payload[rx_fifo.front]->length;
    	payload->pipe = rx_fifo.payload[rx_fifo.front]->pipe;
    	payload->rssi = rx_fifo.payload[rx_fifo.front]->rssi;
    	payload->pid = rx_fifo.payload[rx_fifo.front]->pid;
    	payload->noack = rx_fifo.payload[rx_fifo.front]->noack;
    	memcpy(payload->data, rx_fifo.payload[rx_fifo.front]->data,
    	       payload->length);
    	if (++rx_fifo.front >= CONFIG_ESB_RX_FIFO_SIZE) {
    		rx_fifo.front = 0;
    	rx_fifo.count--;
    	irq_unlock(key);
    	return 0;
    int esb_start_tx(void)
    		return -EBUSY;
    		return -ENODATA;
    	return 0;
    int esb_start_rx(void)
    		return -EBUSY;
    	NRF_RADIO->INTENCLR = 0xFFFFFFFF;
    	NRF_RADIO->RXADDRESSES = esb_addr.rx_pipes_enabled;
    	return 0;
    int esb_stop_rx(void)
    	if (esb_state != ESB_STATE_PRX && esb_state != ESB_STATE_PRX_SEND_ACK) {
    		return -EINVAL;
    	NRF_RADIO->SHORTS = 0;
    	on_radio_disabled = NULL;
    	return 0;
    int esb_flush_tx(void)
    		return -EACCES;
    	tx_fifo.count = 0;
    	tx_fifo.back = 0;
    	tx_fifo.front = 0;
    	irq_unlock(key);
    	return 0;
    int esb_pop_tx(void)
    		return -EACCES;
    		return -ENODATA;
    		tx_fifo.back = 0;
    	tx_fifo.count--;
    	irq_unlock(key);
    	return 0;
    int esb_flush_rx(void)
    		return -EACCES;
    	rx_fifo.count = 0;
    	rx_fifo.back = 0;
    	rx_fifo.front = 0;
    	irq_unlock(key);
    	return 0;
    int esb_set_address_length(uint8_t length)
    		return -EBUSY;
    	if (!(length > 2 && length < 6)) {
    		return -EINVAL;
    	esb_addr.addr_length = length;
    	return 0;
    int esb_set_base_address_0(const uint8_t *addr)
    		return -EBUSY;
    	if (addr == NULL) {
    		return -EINVAL;
    	memcpy(esb_addr.base_addr_p0, addr, sizeof(esb_addr.base_addr_p0));
    	update_radio_addresses(ADDR_UPDATE_MASK_BASE0);
    	return 0;
    int esb_set_base_address_1(const uint8_t *addr)
    		return -EBUSY;
    	if (addr == NULL) {
    		return -EINVAL;
    	memcpy(esb_addr.base_addr_p1, addr, sizeof(esb_addr.base_addr_p1));
    	update_radio_addresses(ADDR_UPDATE_MASK_BASE1);
    	return 0;
    int esb_set_prefixes(const uint8_t *prefixes, uint8_t num_pipes)
    		return -EBUSY;
    	if (prefixes == NULL) {
    		return -EINVAL;
    	if (!(num_pipes <= CONFIG_ESB_PIPE_COUNT)) {
    		return -EINVAL;
    	memcpy(esb_addr.pipe_prefixes, prefixes, num_pipes);
    	esb_addr.num_pipes = num_pipes;
    	esb_addr.rx_pipes_enabled = BIT_MASK_UINT_8(num_pipes);
    	update_radio_addresses(ADDR_UPDATE_MASK_PREFIX);
    	return 0;
    int esb_update_prefix(uint8_t pipe, uint8_t prefix)
    		return -EBUSY;
    	if (pipe >= CONFIG_ESB_PIPE_COUNT) {
    		return -EINVAL;
    	esb_addr.pipe_prefixes[pipe] = prefix;
    	return 0;
    int esb_enable_pipes(uint8_t enable_mask)
    		return -EBUSY;
    	if ((enable_mask | BIT_MASK_UINT_8(CONFIG_ESB_PIPE_COUNT)) !=
    	    BIT_MASK_UINT_8(CONFIG_ESB_PIPE_COUNT)) {
    		return -EINVAL;
    	esb_addr.rx_pipes_enabled = enable_mask;
    	return 0;
    int esb_set_rf_channel(uint32_t channel)
    		return -EBUSY;
    	if (channel > 100) {
    		return -EINVAL;
    	esb_addr.rf_channel = channel;
    	return 0;
    int esb_get_rf_channel(uint32_t *channel)
    	if (channel == NULL) {
    		return -EINVAL;
    	*channel = esb_addr.rf_channel;
    	return 0;
    int esb_set_tx_power(enum esb_tx_power tx_output_power)
    		return -EBUSY;
    	if (esb_cfg.tx_output_power != tx_output_power) {
    		esb_cfg.tx_output_power = tx_output_power;
    	return 0;
    int esb_set_retransmit_delay(uint16_t delay)
    		return -EBUSY;
    	if (delay < RETRANSMIT_DELAY_MIN) {
    		return -EINVAL;
    	esb_cfg.retransmit_delay = delay;
    	return 0;
    int esb_set_retransmit_count(uint16_t count)
    		return -EBUSY;
    	esb_cfg.retransmit_count = count;
    	return 0;
    int esb_set_bitrate(enum esb_bitrate bitrate)
    		return -EBUSY;
    	esb_cfg.bitrate = bitrate;
    	return update_radio_bitrate() ? 0 : -EINVAL;
    int esb_reuse_pid(uint8_t pipe)
    		return -EBUSY;
    	if (!(pipe < CONFIG_ESB_PIPE_COUNT)) {
    		return -EINVAL;
    	pids[pipe] = (pids[pipe] + PID_MAX) % (PID_MAX + 1);
    	return 0;
    Whether or not the total time from uploading the payload to getting the sent interrupt is less than 100us I don't know since I haven't tested this particular use case. I am expecting you should get close, as long as you make sure to disable the ACK feature.
    Best regards
    Torbjørn
  • Hello Torbjørn,
    Thank you for your answer.
    I will look into moving to nRF Connect SDK.
    Do you know for how long nRF5 SDK will be maintained ?
    By applying your modifications to the driver, i am able to go as low as  ΔT = 129.92 µs
    I only have 1 final question: why is this startup delay needed ?
    From my remains of wireless network classes I would guess it's a delay needed for wireless synchronization between emitter and receiver ?
    Is there any way I could transmit continuously, so that I would never need to re-sync ?
    Thank you for your support !
    Laurent
  • Hi Laurent
    It takes some time to start the various analog components of the radio, such as the power amplifier, local oscillators etc. It is not a delay per se, it is simply the time it takes for the radio to go from idle mode to transmit or receive mode (the technical term is TX or RX rampup).
    Synchronization of the TX and RX happens when the transmitter starts to send the preamble, after the TX rampup is complete.
    The radio in the nRF52 does support staying in TX mode continuously, so if you don't care about achieving low current consumption this is an option, yes.
    Unfortunately this would require considerably more change to the ESB library if you want to support it, since the state machine of the library is based around the flow between idle and TX/RX modes.
    Best regards
    Torbjørn
  • Dear Torbjørn,
    Thanks a lot for your answer, I will look into modifying the state machine of the driver to transmit continuously.
    Have a nice day !
    Laurent
  • You welcome. The best of luck with your project Slight smile
