I'm making a breakout board with nrf52832 qfaa. I used chip antenna (2450AT18B100E) and followed Nordic reference layout. I am getting around 60m range in an open environment (tested in a park).
Can you suggest any options in antennas (can be bigger than 2450AT18B100E or a pcb antenna) or any improvement in the existing circuit to increase the range upto 150m. I want to keep the pcb size as small as possible.
Note:
During range testing, the circuit is enclosed in 1.2mm thick small plastic box with a lipo battery on the bottom side of the pcb. Supply voltage VDD_nrf is 2.8V. This pcb only needs to send the battery voltage level to the bluetooth app (nrf Toolbox).
Pcb is 0.8mm thick FR4 board. Current board size is 20.5 x 21mm.
