Dear Nordic team,
We are using the nRF connect SDK version 2.1.2. Our prototype uses the nrf52840dk board and the KScan application template. However, when directly trying to build the project it first raises a warning:
CMake Warning at C:/NordicSemi/v2.1.2/zephyr/CMakeLists.txt:831 (message): No SOURCES given to Zephyr library: drivers__kscan Excluding target from build.
And then later fails with the following errors:
[48/173] Building C object CMakeFiles/app.dir/src/main.c.obj
FAILED: CMakeFiles/app.dir/src/main.c.obj
C:\NordicSemi\toolchains\v2.1.2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/NordicSemi/v2.1.2/zephyr/include/zephyr -IC:/NordicSemi/v2.1.2/zephyr/include -Izephyr/include/generated -IC:/NordicSemi/v2.1.2/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/NordicSemi/v2.1.2/zephyr/soc/arm/nordic_nrf/common/. -IC:/NordicSemi/v2.1.2/nrf/include -IC:/NordicSemi/v2.1.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/NordicSemi/v2.1.2/modules/hal/nordic/nrfx -IC:/NordicSemi/v2.1.2/modules/hal/nordic/nrfx/drivers/include -IC:/NordicSemi/v2.1.2/modules/hal/nordic/nrfx/mdk -IC:/NordicSemi/v2.1.2/zephyr/modules/hal_nordic/nrfx/. -IC:/NordicSemi/v2.1.2/modules/debug/segger/SEGGER -IC:/NordicSemi/v2.1.2/modules/debug/segger/Config -IC:/NordicSemi/v2.1.2/zephyr/modules/segger/. -isystem C:/NordicSemi/v2.1.2/zephyr/lib/libc/minimal/include -isystem c:/nordicsemi/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/include -isystem c:/nordicsemi/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/include-fixed -isystem C:/NordicSemi/v2.1.2/nrfxlib/crypto/nrf_cc310_platform/include -Os -imacros C:/MS/Keyboard/Applications/kscan/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/NordicSemi/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/NordicSemi/v2.1.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/MS/Keyboard/Applications/kscan=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/NordicSemi/v2.1.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/NordicSemi/v2.1.2=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
In file included from C:\NordicSemi\v2.1.2\zephyr\include\zephyr\toolchain\gcc.h:88,
from C:\NordicSemi\v2.1.2\zephyr\include\zephyr\toolchain.h:50,
from C:\NordicSemi\v2.1.2\zephyr\include\zephyr\kernel_includes.h:19,
from C:\NordicSemi\v2.1.2\zephyr\include\zephyr\kernel.h:17,
from C:\NordicSemi\v2.1.2\zephyr\include\zephyr\zephyr.h:18,
from c:\MS\Keyboard\Applications\kscan\src\main.c:7:
C:\NordicSemi\v2.1.2\zephyr\include\zephyr\device.h:96:39: error: '__device_dts_ord_DT_N_ALIAS_kscan0_ORD' undeclared here (not in a function)
96 | #define DEVICE_NAME_GET(name) _CONCAT(__device_, name)
C:\NordicSemi\v2.1.2\zephyr\include\zephyr\toolchain\common.h:132:26: note: in definition of macro '_DO_CONCAT'
132 | #define _DO_CONCAT(x, y) x ## y
C:\NordicSemi\v2.1.2\zephyr\include\zephyr\device.h:96:31: note: in expansion of macro '_CONCAT'
C:\NordicSemi\v2.1.2\zephyr\include\zephyr\device.h:276:37: note: in expansion of macro 'DEVICE_NAME_GET'
276 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_NAME(node_id))
C:\NordicSemi\v2.1.2\zephyr\include\zephyr\device.h:296:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
296 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
c:\MS\Keyboard\Applications\kscan\src\main.c:20:34: note: in expansion of macro 'DEVICE_DT_GET'
20 | const struct device *kscan_dev = DEVICE_DT_GET(KSCAN_NODE);
[49/173] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
[50/173] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
[51/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[52/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[53/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[54/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[55/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[56/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[57/173] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
FATAL ERROR: command exited with status 1: 'c:\NordicSemi\toolchains\v2.1.2\opt\bin\cmake.EXE' --build 'c:\MS\Keyboard\Applications\kscan\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
It seems that the KScan library does not get included successfully in the project. Is there anything we still need to configure at this point in order to build this application?
Thank you in advance!
