I am using nrf5340 module with external hardware audio codec to test stereo audio output.
I use nrf5340 module as the headset to connect with Pixel 7 mobile phone,and refer to this post,I modify the code to below:
static void audio_headset_configure(void)
if (IS_ENABLED(CONFIG_SW_CODEC_LC3)) {
sw_codec_cfg.sw_codec = SW_CODEC_LC3;
} else {
ERR_CHK_MSG(-EINVAL, "No codec selected");
#if (CONFIG_STREAM_BIDIRECTIONAL)
sw_codec_cfg.encoder.enabled = true;
sw_codec_cfg.encoder.channel_mode = SW_CODEC_STEREO;
sw_codec_cfg.encoder.bitrate = CONFIG_LC3_BITRATE;
} else {
#endif /* (CONFIG_STREAM_BIDIRECTIONAL) */
sw_codec_cfg.decoder.channel_mode = SW_CODEC_STEREO;
sw_codec_cfg.decoder.enabled = true;
When playing audio,the noise is very serious.
Is there anything else that needs to be modified?
The nRF Connect SDK version I used is v2.2.0-rc1.
