I can't get/set gpio value.
Hi Nordic.
I am developing with nRF52832DK and SDK 17.1.0
And it's connected with my Qualcomm board.
I want check GPIO input interrupt and output settings.
But I can't read the signal from the outside into the input properly.
Also, even if the setting to output to high, it is not measured by the multimeter.
This is my codes.
#define ADC_INT_PIN 3
#define BLE_INT_OUT_PIN 10
static void gpios_init(void)
    ret_code_t err_code = 0;
    nrf_gpio_cfg_output(BLE_INT_OUT_PIN);
    nrf_gpio_pin_set(BLE_INT_OUT_PIN);
    nrf_gpio_cfg_input(ADC_INT_PIN, NRF_GPIO_PIN_PULLUP);
    m_backup_battery_mode = nrf_gpio_pin_input_get(ADC_INT_PIN);
    NRF_LOG_INFO("adc interrupt pin is %d", m_backup_battery_mode);
    nrf_drv_gpiote_in_config_t in_config = {
        .sense = NRF_GPIOTE_POLARITY_TOGGLE,
        .pull = NRF_GPIO_PIN_PULLUP,
        .is_watcher = false,
        .hi_accuracy = true,
        .skip_gpio_setup = false
    err_code = nrf_drv_gpiote_in_init(ADC_INT_PIN, &in_config, adc_interrupt_handler);
I'm setting output high BLE_INT_OUT_PIN gpio by using nrf_gpio_cfg_output and nrf_gpio_pin_set.
But multimeter is not detect voltage.
And I'm setting input and get value ADC_INT_PIN gpio by using nrf_gpio_cfg_input and nrf_gpio_pin_input_get.
But this value always low (0).
Please advise me.
Thanks.
