Static code analyze tools for NRF Connect SDK
I'm doing reasearch in static code analyze tools for my projects. At link below I saw that since version ncs 2.1.0 there is possible to use "Sparse" tool to static code analyze but some configs are required... I can't find what kind of configs...
 nrf Connect 1.6.1 SDK : Static Code Analysis
 I also saw this:
https://docs.zephyrproject.org/3.1.0/develop/test/sparse.html
I've tried to build some example with "-- -DSPARSE=y".
west build -p always -b nrf52dk_nrf52832 samples/basic/blinky -- -DSPARSE=y
As a result I've got...
es2@es2-hpprobook450g1:~/ncs/zephyr$ west build -p always -b nrf52dk_nrf52832 samples/basic/blinky -- -DSPARSE=y
-- west build: making build dir /home/es2/ncs/zephyr/build pristine
-- Application: /home/es2/ncs/zephyr/samples/basic/blinky
-- Found Python3: /usr/bin/python3.10 (found suitable exact version "3.10.6") found components: Interpreter
-- Cache files will be written to: /home/es2/.cache//zephyr
-- Zephyr version: 3.1.99 (/home/es2/ncs/zephyr)
-- Board: nrf52dk_nrf52832
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.14.1 (/home/es2/zephyr-sdk-0.14.1)
-- Found dtc: /home/es2/zephyr-sdk-0.14.1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (/home/es2/zephyr-sdk-0.14.1)
-- Found BOARD.dts: /home/es2/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
-- Generated zephyr.dts: /home/es2/ncs/zephyr/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/es2/ncs/zephyr/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/es2/ncs/zephyr/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/es2/ncs/zephyr/build/zephyr/dts.cmake
Parsing /home/es2/ncs/zephyr/Kconfig
Loaded configuration '/home/es2/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
Merged configuration '/home/es2/ncs/zephyr/samples/basic/blinky/prj.conf'
Configuration saved to '/home/es2/ncs/zephyr/build/zephyr/.config'
Kconfig header saved to '/home/es2/ncs/zephyr/build/zephyr/include/generated/autoconf.h'
CMake Error at /home/es2/ncs/zephyr/cmake/compiler/gcc/target.cmake:17 (message):
  C compiler
  /home/es2/zephyr-sdk-0.14.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc not
  found - Please check your toolchain installation
  /home/es2/ncs/zephyr/cmake/modules/target_toolchain.cmake:63 (include)
  /home/es2/ncs/zephyr/cmake/modules/zephyr_default.cmake:121 (include)
  /home/es2/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /home/es2/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:4 (find_package)
FATAL ERROR: command exited with status 1: /usr/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/home/es2/ncs/zephyr/build -GNinja -DBOARD=nrf52dk_nrf52832 -DSPARSE=y -S/home/es2/ncs/zephyr/samples/basic/blinky
If this is still in progress or something, what kind of tool You recommend for static code analyzing...?
Kamil
  • The case is quite urgent, can I ask about some answer...?
  •   , please "cherry-pick" the commit linked to below as it was not included in SDK 2.1.0. This should fix the "toolchain not found" error you encountered.
    https://github.com/nrfconnect/sdk-zephyr/commit/3ebb18b882634be29955a52ea70cd59f634492c1
      , I was not able to reproduce this here. Below is from my terminal when I tried to build the blinky sample with sparse. Could you try to repeat these steps on your end to see if you get the same result? Notice I had to make a symlink for cgcc as cgcc is not included in the ARM toolchain.
    user@user-OptiPlex-7070:~/ncs/v2.2.0/zephyr/samples/basic/blinky$ ln -s /home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc /home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/cgcc
    user@user-OptiPlex-7070:~/ncs/v2.2.0/zephyr/samples/basic/blinky$ ls -la /home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/cgcc
    lrwxrwxrwx 1 user user 90 des.  14 14:02 /home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/cgcc -> /home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    user@user-OptiPlex-7070:~/ncs/v2.2.0/zephyr/samples/basic/blinky$ export $REAL_CC=/home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    bash: export: `=/home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc': not a valid identifier
    user@user-OptiPlex-7070:~/ncs/v2.2.0/zephyr/samples/basic/blinky$ export REAL_CC=/home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    user@user-OptiPlex-7070:~/ncs/v2.2.0/zephyr/samples/basic/blinky$ west build -b nrf52dk_nrf52832 -p -- -DSPARSE=y
    -- west build: making build dir /home/user/ncs/v2.2.0/zephyr/samples/basic/blinky/build pristine
    -- Application: /home/user/ncs/v2.2.0/zephyr/samples/basic/blinky
    -- Using NCS Toolchain 2.2.0 for building. (/home/user/ncs/toolchains/v2.2.0/cmake)
    -- Found Python3: /home/user/ncs/toolchains/v2.2.0/usr/local/bin/python3 (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: /home/user/.cache/zephyr
    -- Zephyr version: 3.2.99 (/home/user/ncs/v2.2.0/zephyr)
    -- Found host-tools: zephyr 0.15.1 (/home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (/home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: /home/user/ncs/toolchains/v2.2.0/usr/local/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/user/ncs/v2.2.0/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
    -- Generated zephyr.dts: /home/user/ncs/v2.2.0/zephyr/samples/basic/blinky/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/user/ncs/v2.2.0/zephyr/samples/basic/blinky/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /home/user/ncs/v2.2.0/zephyr/samples/basic/blinky/build/zephyr/dts.cmake
    Parsing /home/user/ncs/v2.2.0/zephyr/Kconfig
    Loaded configuration '/home/user/ncs/v2.2.0/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
    Merged configuration '/home/user/ncs/v2.2.0/zephyr/samples/basic/blinky/prj.conf'
    Configuration saved to '/home/user/ncs/v2.2.0/zephyr/samples/basic/blinky/build/zephyr/.config'
    Kconfig header saved to '/home/user/ncs/v2.2.0/zephyr/samples/basic/blinky/build/zephyr/include/generated/autoconf.h'
    -- Found sparse: /home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/cgcc
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: /home/user/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/cgcc
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/user/ncs/v2.2.0/zephyr/samples/basic/blinky/build
    [1/166] Preparing syscall dependency handling
    [2/166] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (/home/user/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
    [21/166] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    /home/user/ncs/v2.2.0/zephyr/lib/os/printk.c: In function 'vsnprintk':
    /home/user/ncs/v2.2.0/zephyr/lib/os/printk.c:255:19: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
      255 |         cbvprintf(str_out, &ctx, fmt, ap);
          |                   int (*)(int,  struct str_context *)
    In file included from ../../../../include/zephyr/logging/log_msg.h:11,
                     from ../../../../include/zephyr/logging/log_core.h:9,
                     from ../../../../include/zephyr/logging/log.h:11,
                     from /home/user/ncs/v2.2.0/zephyr/lib/os/printk.c:21:
    ../../../../include/zephyr/sys/cbprintf.h:715:27: note: expected 'cbprintf_cb' {aka 'int (*)(int,  void *)'} but argument is of type 'int (*)(int,  struct str_context *)'
      715 | int cbvprintf(cbprintf_cb out, void *ctx, const char *format, va_list ap)
    [99/166] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c: In function 'snprintf':
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c:45:23: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
       45 |         r = cbvprintf(sprintf_out, (void *) (&p), format, vargs);
          |                       int (*)(int,  struct emitter *)
    In file included from /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c:11:
    ../../../../include/zephyr/sys/cbprintf.h:715:27: note: expected 'cbprintf_cb' {aka 'int (*)(int,  void *)'} but argument is of type 'int (*)(int,  struct emitter *)'
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c: In function 'sprintf':
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c:63:23: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
       63 |         r = cbvprintf(sprintf_out, (void *) (&p), format, vargs);
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c: In function 'vsnprintf':
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c:84:23: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
       84 |         r = cbvprintf(sprintf_out, (void *) (&p), format, vargs);
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c: In function 'vsprintf':
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/sprintf.c:99:23: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
       99 |         r = cbvprintf(sprintf_out, (void *) (&p), format, vargs);
    [101/166] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c: In function 'fprintf':
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c:21:23: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
       21 |         r = cbvprintf(fputc, DESC(stream), format, vargs);
          |                       int (*)(int,  FILE *) {aka int (*)(int,  int *)}
    In file included from /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c:11:
    ../../../../include/zephyr/sys/cbprintf.h:715:27: note: expected 'cbprintf_cb' {aka 'int (*)(int,  void *)'} but argument is of type 'int (*)(int,  FILE *)' {aka 'int (*)(int,  int *)'}
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c: In function 'vfprintf':
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c:32:23: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
       32 |         r = cbvprintf(fputc, DESC(stream), format, vargs);
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c: In function 'printf':
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c:43:23: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
       43 |         r = cbvprintf(fputc, DESC(stdout), format, vargs);
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c: In function 'vprintf':
    /home/user/ncs/v2.2.0/zephyr/lib/libc/minimal/source/stdout/fprintf.c:53:23: warning: passing argument 1 of 'cbvprintf' from incompatible pointer type [-Wincompatible-pointer-types]
       53 |         r = cbvprintf(fputc, DESC(stdout), format, vargs);
    [156/166] Linking C executable zephyr/zephyr_pre0.elf
    [160/166] Linking C executable zephyr/zephyr_pre1.elf
    [166/166] Linking C executable zephyr/zephyr.elf
               FLASH:       19390 B       512 KB      3.70%
                 RAM:        5504 B        64 KB      8.40%
            IDT_LIST:          0 GB         2 KB      0.00%
  • It works now on my end, my system had some unrelated issues.
    Sparse works with ncs v2.2.0 out of the box, no need to cherry-pick the specified commit.
  • Thanks for confirming that it worked. But when you say it worked out of the box, do you mean that you did not have to make a symlink for cgcc either?
  • This was the only command that I've had to run (no symlink):
    export REAL_CC=/home/aleksa/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    A bit off-topic:
    I use manual installation instructions for the NCS since the toolchain manager didn't use to work for Linux. However, I was unable to set build up manually for v2.2.0, without getting the tools from the toolchain manager.
    Now I'm a bit confused with all the tools since I have both the zephyr v0.15.1 toolchain and the NCS toolchain. Not sure how all of it works together.
    This is my output when I run the same build command as yours:
    aleksa@aleksa:~/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world$ west build -b nrf52dk_nrf52832 -p -- -DSPARSE=y
    -- Application: /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world
    -- Using NCS Toolchain 2.2.0 for building. (/home/aleksa/ncs/toolchains/v2.2.0/cmake)
    -- Found Python3: /home/aleksa/ncs/toolchains/v2.2.0/usr/local/bin/python3 (found suitable exact version "3.8.10") found components: Interpreter
    -- Cache files will be written to: /home/aleksa/.cache/zephyr
    -- Zephyr version: 3.2.99 (/home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr)
    -- Found host-tools: zephyr 0.15.1 (/home/aleksa/zephyr-sdk-0.15.1)
    -- Found toolchain: zephyr 0.15.1 (/home/aleksa/zephyr-sdk-0.15.1)
    -- Found Dtc: /home/aleksa/ncs/toolchains/v2.2.0/usr/local/bin/dtc (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
    -- Generated zephyr.dts: /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world/build/zephyr/dts.cmake
    Parsing /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/Kconfig
    Loaded configuration '/home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
    Merged configuration '/home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world/prj.conf'
    Configuration saved to '/home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world/build/zephyr/.config'
    Kconfig header saved to '/home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world/build/zephyr/include/generated/autoconf.h'
    -- Found sparse: /usr/bin/cgcc
    -- Found assembler: /usr/bin/cgcc
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/samples/hello_world/build
    -- Zephyr version: 3.2.99 (/home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr), build: v3.2.99-ncs1
    [8/166] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:78:9: warning: '__INT_FAST8_TYPE__' has implicit type
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:78:33: error: Expected ; at end of declaration
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:78:33: error: got int_fast8_t
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:79:33: error: Expected ; at end of declaration
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:79:33: error: got int_fast16_t
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:83:33: error: Expected ; at end of declaration
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:83:33: error: got int_least8_t
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:84:33: error: Expected ; at end of declaration
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:84:33: error: got int_least16_t
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:94:33: error: Expected ; at end of declaration
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:94:33: error: got uint_fast8_t
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:95:33: error: Expected ; at end of declaration
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:95:33: error: got uint_fast16_t
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:99:33: error: Expected ; at end of declaration
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:99:33: error: got uint_least8_t
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:100:33: error: Expected ; at end of declaration
    /home/aleksa/Desktop/01_POSAO/02_PENNY/04_NCS_V211/mg105-nrf9160-root/lib/nordic/ncs/zephyr/lib/libc/minimal/include/stdint.h:100:33: error: got uint_least16_t
