Static code analyze tools for NRF Connect SDK
I'm doing reasearch in static code analyze tools for my projects. At link below I saw that since version ncs 2.1.0 there is possible to use "Sparse" tool to static code analyze but some configs are required... I can't find what kind of configs...
 nrf Connect 1.6.1 SDK : Static Code Analysis
 I also saw this:
https://docs.zephyrproject.org/3.1.0/develop/test/sparse.html
I've tried to build some example with "-- -DSPARSE=y".
west build -p always -b nrf52dk_nrf52832 samples/basic/blinky -- -DSPARSE=y
As a result I've got...
es2@es2-hpprobook450g1:~/ncs/zephyr$ west build -p always -b nrf52dk_nrf52832 samples/basic/blinky -- -DSPARSE=y
-- west build: making build dir /home/es2/ncs/zephyr/build pristine
-- Application: /home/es2/ncs/zephyr/samples/basic/blinky
-- Found Python3: /usr/bin/python3.10 (found suitable exact version "3.10.6") found components: Interpreter
-- Cache files will be written to: /home/es2/.cache//zephyr
-- Zephyr version: 3.1.99 (/home/es2/ncs/zephyr)
-- Board: nrf52dk_nrf52832
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.14.1 (/home/es2/zephyr-sdk-0.14.1)
-- Found dtc: /home/es2/zephyr-sdk-0.14.1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (/home/es2/zephyr-sdk-0.14.1)
-- Found BOARD.dts: /home/es2/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
-- Generated zephyr.dts: /home/es2/ncs/zephyr/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/es2/ncs/zephyr/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/es2/ncs/zephyr/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/es2/ncs/zephyr/build/zephyr/dts.cmake
Parsing /home/es2/ncs/zephyr/Kconfig
Loaded configuration '/home/es2/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
Merged configuration '/home/es2/ncs/zephyr/samples/basic/blinky/prj.conf'
Configuration saved to '/home/es2/ncs/zephyr/build/zephyr/.config'
Kconfig header saved to '/home/es2/ncs/zephyr/build/zephyr/include/generated/autoconf.h'
CMake Error at /home/es2/ncs/zephyr/cmake/compiler/gcc/target.cmake:17 (message):
  C compiler
  /home/es2/zephyr-sdk-0.14.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc not
  found - Please check your toolchain installation
  /home/es2/ncs/zephyr/cmake/modules/target_toolchain.cmake:63 (include)
  /home/es2/ncs/zephyr/cmake/modules/zephyr_default.cmake:121 (include)
  /home/es2/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /home/es2/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:4 (find_package)
FATAL ERROR: command exited with status 1: /usr/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/home/es2/ncs/zephyr/build -GNinja -DBOARD=nrf52dk_nrf52832 -DSPARSE=y -S/home/es2/ncs/zephyr/samples/basic/blinky
If this is still in progress or something, what kind of tool You recommend for static code analyzing...?
Kamil
  • I think that there is still some problem. I've installed clear ubuntu 22.04 installation using podman.
    And below are all actions that I've proceeded. Result is still the same... Files that are modified in commit that You mention are with proper content... as I compared...
    apt-get update
    apt install --no-install-recommends git cmake ninja-build gperf ccache dfu-util device-tree-compiler wget python3-dev python3-pip python3-setuptools python3-tk python3-wheel xz-utils file make gcc gcc-multilib g++-multilib libsdl2-dev libmagic1
    mkdir ${HOME}/gn && cd ${HOME}/gn
    wget -O gn.zip https://chrome-infra-packages.appspot.com/dl/gn/gn/linux-amd64/+/latest
    apt-get install unzip
    unzip gn.zip
    rm gn.zip
    echo 'export PATH=${HOME}/gn:"$PATH"' >> ${HOME}/.bashrc
    source ${HOME}/.bashrc
    pip3 install --user west
    echo 'export PATH=~/.local/bin:"$PATH"' >> ~/.bashrc
    source ~/.bashrc
    mkdir ncs
    cd ncs/
    west init -m https://github.com/nrfconnect/sdk-nrf --mr main
    west update
    west zephyr-export
    pip3 install --user -r zephyr/scripts/requirements.txt
    pip3 install --user -r nrf/scripts/requirements.txt
    pip3 install --user -r bootloader/mcuboot/scripts/requirements.txt
    cd ~
    wget https://github.com/zephyrproject-rtos/sdk-ng/releases/download/v0.15.1/zephyr-sdk-0.15.1_linux-x86_64.tar.gz
    wget -O - https://github.com/zephyrproject-rtos/sdk-ng/releases/download/v0.15.1/sha256.sum | shasum --check --ignore-missing
    tar xvf zephyr-sdk-0.15.1_linux-x86_64.tar.gz
    cd zephyr-sdk-0.15.1
    ./setup.sh
    cd ../ncs/
    source zephyr/zephyr-env.sh
    ln -s ~/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc ~/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/cgcc
    ls -la ~/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/cgcc
    export REAL_CC=~/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    cd zephyr/
    cd samples/basic/blinky
    west build -b nrf52dk_nrf52832 -p -- -DSPARSE=y
    root@ca30ef32b4ea:~/ncs/zephyr/samples/basic/blinky# ls -la ~/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/cgcc
    lrwxrwxrwx 1 root root 63 Dec 15 12:29 /root/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/cgcc -> /root/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    There is output of build request
    root@ca30ef32b4ea:~/ncs/zephyr/samples/basic/blinky# west build -b nrf52dk_nrf52832 -p -- -DSPARSE=y
    -- west build: making build dir /root/ncs/zephyr/samples/basic/blinky/build pristine
    -- Application: /root/ncs/zephyr/samples/basic/blinky
    -- Cache files will be written to: /root/.cache/zephyr
    -- Zephyr version: 3.2.99 (/root/ncs/zephyr)
    -- Found host-tools: zephyr 0.15.1 (/root/zephyr-sdk-0.15.1)
    -- Found toolchain: zephyr 0.15.1 (/root/zephyr-sdk-0.15.1)
    -- Found Dtc: /root/zephyr-sdk-0.15.1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /root/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
    -- Generated zephyr.dts: /root/ncs/zephyr/samples/basic/blinky/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /root/ncs/zephyr/samples/basic/blinky/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /root/ncs/zephyr/samples/basic/blinky/build/zephyr/dts.cmake
    Parsing /root/ncs/zephyr/Kconfig
    Loaded configuration '/root/ncs/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
    Merged configuration '/root/ncs/zephyr/samples/basic/blinky/prj.conf'
    Configuration saved to '/root/ncs/zephyr/samples/basic/blinky/build/zephyr/.config'
    Kconfig header saved to '/root/ncs/zephyr/samples/basic/blinky/build/zephyr/include/generated/autoconf.h'
    CMake Error at /root/ncs/zephyr/cmake/compiler/gcc/target.cmake:10 (find_program):
      Could not find CMAKE_C_COMPILER using the following names: cgcc
      /root/ncs/zephyr/cmake/modules/FindTargetTools.cmake:102 (include)
      /root/ncs/zephyr/cmake/modules/kernel.cmake:25 (find_package)
      /root/ncs/zephyr/cmake/modules/zephyr_default.cmake:117 (include)
      /root/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /root/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    FATAL ERROR: command exited with status 1: /usr/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/root/ncs/zephyr/samples/basic/blinky/build -GNinja -DBOARD=nrf52dk_nrf52832 -DSPARSE=y -S/root/ncs/zephyr/samples/basic/blinky
     Any suggestions?
  •   , did you make the symlink as I suggested?
      , our SDK toolchain includes the zephyr SDK in addition to other dependencies such as python, git and west. The easiest way to use this toolchain is to open the terminal via the toolchain manager app. This will update your env. variable with the paths defined in /ncs/toolchains/v2.2.0/environment.json
    Edit: I see now that you created the symlink. Can you echo REAL_CC to confirm it's set correctly?
    Edit 2: Please use the 2.2.0 release.
  • root@ca30ef32b4ea:~/ncs/nrf# cat VERSION
    2.2.0
    root@ca30ef32b4ea:~/ncs# echo $REAL_CC
  • Please specify the full path when you set REAL_CC
  • Did not know that env variables were defined there. Awesome, thanks a lot!
