DFU failing with nRF Secure Immutable Bootloader(NSIB) as the first stage bootloader
We are using the nRF Secure Immutable Bootloader(NSIB) as the first stage bootloader along with MCUboot as the second stage bootloader in our nrf5340 project. We have observed that the BLE (SMP based) DFU fails when we add the immutable bootloader to the project. The firmware get's downloaded to the device, but after reset it doesn't boot into the new application and gets stuck somewhere. There are no logs that get printed to indicate any issue. I am using the 'nRF Connect' mobile application in Android for our testing. The SDK is  NCSv2.1.0.
I have made the bare minimum changes needed to reproduce this in the example projects(machine learning and matter lock) provided by Nordic. I have added the CONFIG_SECURE_BOOT=y in the prj.conf of both examples and made sure to use the same memory partitions in both the the projects(pm_static.yml). Below are the zip files of the two projects:
1. Machine learning
  machine_learning.zip
2. Matter lock:
lock.zip
Please try performing the DFU from the first project to the second project or vice-a-versa on nrf5340DK board. It is failing for us.
This same upgrade works fine if we don't use the first stage immutable bootloader(NSIB) in the project.
Please help us in resolving this issue.
Also, I would like to know how we could upgrade the MCUboot image. Which is the binary that needs to be used? Is it the 'signed_by_b0_s0_image.bin'? Can we use the 'nRF Connect' mobile application itself for updating the MCUboot image?
Devanshu Agarwal
    Yes that's right. You can either use our nRF connect mobile Application or our Dedicated DFU application for doing the update. Take a look at this guide created by my colleague where you can see,  how to do the same via our nRF connect Application.
    I am looking into your main issue, I need some more time to check this.
    Kind Regards,
    Abhijith
    Is there any update on this? When I looked at my first response,  it's confusing because I haven't commented anything on binary image you need to transfer and I have included that part of your question.
    The binary file you need to update depends on your active MCUboot(which boot up the application). If s0 is the active mcuboot you need to update the image with s1 and vice versa. For eg: if s0 is active you need to update s1 with image signed_by_mcuboot_and_b0_s1_image_update.bin, the binary file you are pointing is not the one need to be transferred.
    Kind Regards,
    Abhijith
    I haven't got the chance to test the MCUboot upgrade. Thank you for sharing the exact binary file for the s1 slot. I will try it in few days.
    Can you please help me with my main issue? We have an upcoming release and it would be great if we could get the DFU with the two-stage bootloader working before that.
    Devanshu Agarwal
    Really sorry. I was not able to reproduce the issue you are saying.
    I tried the files you shared and I was not able to build the Matter_lock sample that you shared and I cannot see a signed image from mcuboot in case of the machine learning sample.
    If you enable both B0 and Mcuboot, the available images will be as shown below:
    And Minimum configuration you need to include for enabling both B0 and MCUboot are:
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_MCUMGR=y
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    CONFIG_MCUMGR_SMP_BT=y
    CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    CONFIG_BUILD_S1_VARIANT=y
    I am attaching a sample project where two stage bootloaders have been enabled. You can keep this as a  reference and I have disabled the configuration for Key in this file.
    1614.peripheral_hr_smp_b0.zip
    Kind Regards,
    Abhijith
    I have included the build folder in my attached zip files. You can use my binaries to test it.
    Steps to reproduce:
    1. Flash the merged_domains.hex from either of the project in nRF5340 DK.
    2. Use the dfu_application.zip file from the other project in the nRF Connect mobile application for performing DFU.
    Please let me know if you need additional details.
    Devanshu Agarwal
