NRF52840 DFU APP+BL+SD error,DFU request 4 failed with error: 0xB.
hello
1.NRF52840 Upgrade APP+BL+SD  from SD15.3 to SD17.1.
2.BL use pca10056_s140_ble_debug,APP use ble_app_buttonless_dfu.
3.Program batch file.
nrfutil settings generate --application nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex --family NRF52840 --application-version 0 --bootloader-version 0 --bl-settings-version 2 settings.hex
nrfjprog --eraseall -f NRF52
nrfjprog --program settings.hex --chiperase
nrfjprog --program bootloader_hex/bootloader_w_softdevice_nrf52840.hex
nrfjprog --program nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex -r
4.DFU packag batch file.
nrfutil pkg generate --hw-version 52 --sd-req 0xB6,0x0100 --application-version 1 --application nRF5_SDK_17.1.0_ddde560/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex --softdevice nRF5_SDK_17.1.0_ddde560/components/softdevice/s140/hex/s140_nrf52_7.2.0_softdevice.hex --bootloader nRF5_SDK_17.1.0_ddde560/examples/dfu/secure_bootloader/pca10056_s140_ble_debug/arm5_no_packs/_build/nrf52840_xxaa_s140.hex --bootloader-version 1 --sd-id 0x0100 --key-file priv.pem dfu_15.3-17.1.zip.
5.Android APP nRD Connect DFU.
6.The RTT print error.
<debug> nrf_dfu_validation: 08 01 10 34 1A 02 80 02|...4....
<debug> nrf_dfu_validation: 20 00 28 00 30 00 38 84| .(.0.8.
<debug> nrf_dfu_validation: A4 03 42 24 08 03 12 20|..B$...
<debug> nrf_dfu_validation: 60 14 FA A9 4A D5 1E CE|`...J...
<debug> nrf_dfu_validation: E9 16 D8 8F A7 DE FC 41|.......A
<debug> nrf_dfu_validation: 12 32 92 3F CE 95 32 B8|.2.?..2.
<debug> nrf_dfu_validation: 08 25 48 60 4E 22 65 CA|.%H`N"e.
<debug> nrf_dfu_validation: 48 00 52 04 08 01 12 00|H.R.....
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0xB
<warning> nrf_dfu_ble: DFU request 4 failed with error: 0xB.
  • This is the batch file that genrates the upgrade packege.
    nrfutil pkg generate --hw-version 52 --sd-req 0xB6 --application-version 2 --application nRF5_SDK_17.1.0_ddde560/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex --softdevice nRF5_SDK_17.1.0_ddde560/components/softdevice/s140/hex/s140_nrf52_7.2.0_softdevice.hex --bootloader nRF5_SDK_17.1.0_ddde560/examples/dfu/secure_bootloader/pca10056_s140_ble_debug/arm5_no_packs/_build/nrf52840_xxaa_s140.hex --bootloader-version 2 --sd-id 0x0100 --key-file priv.pem dfu_15.3-17.1.zip
  • Can you tripple check? Looking at the code, I am not able to see any other explanation for this. The error is printed from this snippet in the bootloader:
            else if (p_init->hw_version != NRF_DFU_HW_VERSION)
                NRF_LOG_WARNING("Faulty HW version.");
                ret_val = EXT_ERR( NRF_DFU_EXT_ERROR_HW_VERSION_FAILURE);
    Are you sure the bootloader that is running was built with NRF_DFU_HW_VERSION set to 52? Did you program it now, or could it be that it does not run the bootloader you think it does?
    And regarding the DFU image, could it have been a mixup? Can you check the zip file using "nrfutil pkg display <file>"?
  • 1.NRF_DFU_HW_VERSION default value is 52,unchanged.
    2.nrfutil pkg display as follows.
    PS F:\DFU\DFU_BLE-17.1> nrfutil pkg display dfu_15.3-17.1.zip
    DFU Package: <dfu_15.3-17.1.zip>:
    |- Image count: 2
    |- Image #0:
       |- Type: sd_bl
       |- Image file: sd_bl.bin
       |- Init packet file: sd_bl.dat
          |- op_code: INIT
          |- signature_type: ECDSA_P256_SHA256
          |- signature (little-endian): b'd9a8e3299fa1635bae74cc8433f06876c3f51a8d495ae60aec834620120ef8f1d6974ff5a11ab3b8e24ef2ddefa6298b32986319ab3cc194fa46b6b9e5cb8d28'
          |- fw_version: 0x00000002 (2)
          |- hw_version 0x00000034 (52)
          |- sd_req: 0x100, 0xB6
          |- type: SOFTDEVICE_BOOTLOADER
          |- sd_size: 153140
          |- bl_size: 54452
          |- app_size: 0
          |- hash_type: SHA256
          |- hash (little-endian): b'0a7f3e043cddef1e568a9eb01a623a24191306ce61a53e1606330e2205a39985'
          |- boot_validation_type: ['VALIDATE_GENERATED_CRC', 'VALIDATE_GENERATED_CRC']
          |- boot_validation_signature (little-endian): [b'', b'']
          |- is_debug: False
    |- Image #1:
       |- Type: application
       |- Image file: nrf52840_xxaa.bin
       |- Init packet file: nrf52840_xxaa.dat
          |- op_code: INIT
          |- signature (little-endian): b'870749823a8acbea22de7aaf6f7f5d03f41ab8d3e5a97d3b5279bbc65fa682796c4443b1821ad0f7f87f9d5b626a6a093983cf2e09dc979acf8e653ca51a57b7'
          |- sd_req: 0x100
          |- type: APPLICATION
          |- sd_size: 0
          |- bl_size: 0
          |- app_size: 53764
          |- hash_type: SHA256
          |- hash (little-endian): b'd96f871639b078031f3b65ba7dd65667c9027e48a1c14fe383c7418665a228eb'
          |- boot_validation_type: ['VALIDATE_GENERATED_CRC']
          |- boot_validation_signature (little-endian): [b'']
          |- is_debug: False
  • Hm, that is most peculiar. Perhaps you can modify the bootloader and log a bit more. First of all, start with components/libraries/bootloader/dfu/nrf_dfu_ver_validation.c and the section I posted in my previous reply. Then print both p_init->hw_version and NRF_DFU_HW_VERSION separately to see which value they have there. Clearly they are not the same in this check, so it would be good to know which of them have a different value, and what that is. Then we can continue from there.
  • 1.Now there are other errors,as follows.
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    <debug> app: timer_stop (0x200057D4)
    <debug> app: timer_activate (0x200057D4)
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_ble: Buffer 0x20006D5C acquired, len 141 (244)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    <debug> nrf_dfu_ble: Freeing buffer 0x20006D5C
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_validation: PB: Init packet data len: 64
    <info> nrf_dfu_validation: Signature required. Checking signature.
    <info> nrf_dfu_validation: Calculating hash (len: 64)
    <info> nrf_dfu_validation: Verify signature
    <info> nrf_dfu_validation: Image verified
    <warning> nrf_dfu_ver_validation: SD req not met.
    <warning> nrf_dfu_validation: Prevalidation failed.
    <debug> nrf_dfu_validation: Init command:
    <debug> nrf_dfu_validation:  08 04 10 34 1A 02 80 02|...4....
    <debug> nrf_dfu_validation:  D9 6F 87 16 39 B0 78 03|.o..9.x.
    <debug> nrf_dfu_validation:  1F 3B 65 BA 7D D6 56 67|.;e.}.Vg
    <debug> nrf_dfu_validation:  C9 02 7E 48 A1 C1 4F E3|..~H..O.
    <debug> nrf_dfu_validation:  83 C7 41 86 65 A2 28 EB|..A.e.(.
    <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
    <debug> nrf_dfu_ble: max_conn_interval: 6
    <debug> nrf_dfu_ble: min_conn_interval: 6
    <debug> nrf_dfu_ble: slave_latency: 0
    <debug> nrf_dfu_ble: conn_sup_timeout: 500
    <debug> nrf_dfu_ble: max_conn_interval: 12
    <debug> nrf_dfu_ble: min_conn_interval: 12
    <debug> nrf_dfu_ble: conn_sup_timeout: 600
    <debug> app: timer_fire (0x200057D4)
    <info> app: Inactivity timeout.
    <debug> app: Resetting bootloader.
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <info> app: Inside main15.12
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <debug> app: App is valid
    <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
    <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
    2.Test program code and generate upprade package batch file ,what do you think is the problem?
    mergehex-bl_sd:
    mergehex --merge nRF5_SDK_15.3.0_59ac345/examples/dfu/secure_bootloader/pca10056_ble_debug/arm5_no_packs/_build/nrf52840_xxaa_s140.hex nRF5_SDK_15.3.0_59ac345/components/softdevice/s140/hex/s140_nrf52_6.1.1_softdevice.hex --output bootloader_hex/bootloader_w_softdevice_nrf52840.hex
    program_bl_sd15.3_app_settings:
    generate_bl_sd15.3-17.1_app-pkg:
    nrfutil pkg generate --hw-version 52 --sd-req 0xB6,0x0100 --application-version 4 --application nRF5_SDK_17.1.0_ddde560/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex --softdevice nRF5_SDK_17.1.0_ddde560/components/softdevice/s140/hex/s140_nrf52_7.2.0_softdevice.hex --bootloader nRF5_SDK_17.1.0_ddde560/examples/dfu/secure_bootloader/pca10056_s140_ble_debug/arm5_no_packs/_build/nrf52840_xxaa_s140.hex --bootloader-version 3 --sd-id 0x0100 --key-file priv.pem dfu_15.3-17.1.zip
    3.Now there are no print  "Faulty HW version." error.
