NRF52840 DFU APP+BL+SD error,DFU request 4 failed with error: 0xB.
hello
1.NRF52840 Upgrade APP+BL+SD  from SD15.3 to SD17.1.
2.BL use pca10056_s140_ble_debug,APP use ble_app_buttonless_dfu.
3.Program batch file.
nrfutil settings generate --application nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex --family NRF52840 --application-version 0 --bootloader-version 0 --bl-settings-version 2 settings.hex
nrfjprog --eraseall -f NRF52
nrfjprog --program settings.hex --chiperase
nrfjprog --program bootloader_hex/bootloader_w_softdevice_nrf52840.hex
nrfjprog --program nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex -r
4.DFU packag batch file.
nrfutil pkg generate --hw-version 52 --sd-req 0xB6,0x0100 --application-version 1 --application nRF5_SDK_17.1.0_ddde560/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex --softdevice nRF5_SDK_17.1.0_ddde560/components/softdevice/s140/hex/s140_nrf52_7.2.0_softdevice.hex --bootloader nRF5_SDK_17.1.0_ddde560/examples/dfu/secure_bootloader/pca10056_s140_ble_debug/arm5_no_packs/_build/nrf52840_xxaa_s140.hex --bootloader-version 1 --sd-id 0x0100 --key-file priv.pem dfu_15.3-17.1.zip.
5.Android APP nRD Connect DFU.
6.The RTT print error.
<debug> nrf_dfu_validation: 08 01 10 34 1A 02 80 02|...4....
<debug> nrf_dfu_validation: 20 00 28 00 30 00 38 84| .(.0.8.
<debug> nrf_dfu_validation: A4 03 42 24 08 03 12 20|..B$...
<debug> nrf_dfu_validation: 60 14 FA A9 4A D5 1E CE|`...J...
<debug> nrf_dfu_validation: E9 16 D8 8F A7 DE FC 41|.......A
<debug> nrf_dfu_validation: 12 32 92 3F CE 95 32 B8|.2.?..2.
<debug> nrf_dfu_validation: 08 25 48 60 4E 22 65 CA|.%H`N"e.
<debug> nrf_dfu_validation: 48 00 52 04 08 01 12 00|H.R.....
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0xB
<warning> nrf_dfu_ble: DFU request 4 failed with error: 0xB.
  • 1.After changing the file, I finally saw that nrf Connect started to perform the upgrade, but only performed the upgrade once and then stopped. The upgrade should be performed twice, once for BL+SD and once for APP. The APP is not executed.
    nrfutil pkg generate --hw-version 52 --sd-req 0xB6 --application-version 2 --application nRF5_SDK_17.1.0_ddde560/examples/ble_peripheral/ble_app_buttonless_dfu/pca10056/s140/arm5_no_packs/_build/nrf52840_xxaa.hex --softdevice nRF5_SDK_17.1.0_ddde560/components/softdevice/s140/hex/s140_nrf52_7.2.0_softdevice.hex --bootloader nRF5_SDK_17.1.0_ddde560/examples/dfu/secure_bootloader/pca10056_s140_ble_debug/arm5_no_packs/_build/nrf52840_xxaa_s140.hex --bootloader-version 2 --sd-id 0xB6,0x0100 --key-file priv.pem dfu_15.3-17.1.zip
    I changed from --sd-id 0x0100 to --sd-id 0xB6,0x0100.
    2.Do not perform APP upgrade now,RTT print content。
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_ble: Shutting down BLE transport.
    <debug> nrf_dfu_ble: Disconnecting.
    <debug> nrf_dfu_ble: BLE transport shut down.
    <debug> app: Resetting bootloader.
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <info> app: Inside main15.1
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    <debug> app: Enter nrf_bootloader_fw_activate
    <debug> app: Valid App
    <debug> app: Enter nrf_dfu_app_continue
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00026000, len=8 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00026000, pending 0
    <debug> app: Copying 0x33000 to 0x26000, size: 0x8000
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00026000, src=0x00033000, len=32768 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00026000, pending 0
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FF000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20007D90, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FF000, pending 0
    <debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x000FE000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x20008110, len=896 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002E000, len=6 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002E000, pending 0
    <debug> app: Copying 0x3B000 to 0x2E000, size: 0x5204
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002E000, src=0x0003B000, len=20996 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002E000, pending 0
    <debug> app: Setting app as valid
    E000.
    <info> app: No firmware to activate.
    <debug> app: App is valid
    <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
    <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
  • Is there a problem with packaging batch files? I refer to the batch file written by this ticket. DFU package
  • Here you see from the log that prevalidation failed because "SD req not met". In other words, the right SoftDevice ID is not provided with --sd-req.
    But I don't understand why you suddenly got this issue? What have you changed in the meantime? It can be easy to loose track of IDs, but who knows. As this is strange I would suggest the same as in my lats post if you have problems with the IDs, but then print the IDs instead (that checking is a bit more complex, but you could log things in sd_req_ok()). It is odd that you get these issues though.
    Have you made any changes to the bootloader? If so, which? Or something that could corrupt the init packet or similar?
  • I have not modified the content in the bootloader project file, and now it can be upgraded, but it can only be upgraded once, and it should be upgraded twice under normal circumstances.
    Thank you very much today, I have to get off work, and the time in the East Eighth District is already very late.
  • Thank you very much for your patient answer.My test program was changed by myself but I didn't realize it.Now decomprerssing th new project file,and test again that the upgrade is successful.
    Christmas is coming,Merry Christmas to you,Thanks again!
