After updating my SDK from 2.0.0 to 2.1.2 the I2C line just gives me the error of:
i2c_nrfx_twim: Error on I2C line occurred for message 0.
I have tried setting up a logic level measurement on it and it does not detect any i2c communication coming from the pins.
The setup:
I am using a NRF9160DK.
From the nrf9160dk_nrf9160_ns.overlay:
&i2c3 {
clock-frequency = < I2C_BITRATE_STANDARD >;
status = "okay";
pinctrl-0 = <&i2c3_default>;
pinctrl-1 = <&i2c3_sleep>;
&pinctrl {
i2c3_default: i2c3_default {
group1 {
psels = <NRF_PSEL(TWIM_SDA, 0, 30)>,
<NRF_PSEL(TWIM_SCL, 0, 31)>;
i2c3_sleep: i2c3_sleep {
group1 {
low-power-enable;
From the prj.conf:
# UART interface CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y # Use GPIO CONFIG_GPIO=y CONFIG_GPIO_NRFX=y CONFIG_NRFX_GPIOTE=y # USE I2C CONFIG_I2C=y CONFIG_I2C_NRFX=y # Pin control CONFIG_PINCTRL=y
The i2c setup:
#define CC_I2C_DEVICE DEVICE_DT_GET_OR_NULL(DT_NODELABEL(i2c3)) //!< The GPIO label.
//! Set up the device for the I2C master.
static const struct device* i2c_master = NULL;
//! Set up the received message buffer.
static uint8_t received_message[CC_I2C_RECEIVE_SIZE];
bool i2c_init_master(void) {
// Bind the I2C to device.
i2c_master = CC_I2C_DEVICE;
// Was the binding a failure?
if(0 == device_is_ready(i2c_master)) {
// Inform user of error.
LOG_ERR("error binding");
return false;
return true;
The i2c send and read:
void i2c_send_data(const uint16_t station_address, const uint8_t* data_to_device) {
// Set up the return code variable.
uint8_t return_code;
// Write to the I2C device.
return_code = i2c_write(i2c_master, data_to_device, strlen(data_to_device), station_address);
// Could the data be send?
if(CC_FUNCTION_SUCCESS != return_code) {
// Inform user.
LOG_ERR("Sent failure");
char* i2c_read_data(const uint16_t station_address, const uint32_t return_data_size) {
// Read from I2C device.
return_code = i2c_read(i2c_master, received_message, return_data_size, station_address);
// Could the instruction be sent and a instruction be received?
if(CC_FUNCTION_SUCCESS == return_code) {
// Return received message.
return received_message;
// There was an error in receiving data.
else {
// Inform user there was an error.
LOG_ERR("Unable to receive data, %i", return_code);
// Return with null.
return NULL;
Everything compiles and runs fine until 2.0.2. at 2.1.0. the error happens.
What have I tried?
- Using i2c1, i2c2 and i2c3.(i2c0 conflicts with uart0)
- Setting up i2c devices and using i2c_dt_spec_get and the sending and reading from i2c_read_dt.
- Creating a custom board, with dts, dtsi, yaml files.
- Turning other coms off.
- Replacing the new nrf9160dk_nrf9160.dts file folder with one from 2.0.2.
- Setting bias, pull-up in the overlay.
- Deleting the build folder.
- Using other pins for the sda & scl.
- Using 2 other nrf9160dk kits.
- Using 2 other gpio expanders to communicate with.
- I have tried to look at the device state, address, enable. They are all filled out and looks enabled.
