Missing uart interrupts when merging peripheral_uart and multiple_adv_sets samples
Setup:
  • nrf connect sdk version v2.1.2
  • board: nrf52840DK
  • Trying to send a beacons for half a second whenever I get some specific data on uart, and also send data over ble connection to the connected device.
Problem:
  • Inside uart callback function the event UART_RX_RDY: does not happen as often as it should (I assume it should happen for every received byte).
  • If I comment out all the beacon releated parts I still miss UART_RX_RDY events.
  • If I comment out all the beacon releated parts and change CONFIG_BT_EXT_ADV_MAX_ADV_SET from 2 to 1, I start getting all the UART_RX_RDY events.
  • If I comment out all the connectable advertisment releated parts, i.e disable ble connection  and only advertise a beacon whenever I get specific data on uart
some parts of uart callback relevant part (uart callback function is almost the same as in peripheral_uart sample):
	case UART_RX_RDY:
		LOG_DBG("UART_RX_RDY");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		if (disable_req) {
			return;
	if (
		(evt->data.rx.buf[buf->len - 1] == '\n') ||
		(evt->data.rx.buf[buf->len - 1] == '\r')
			disable_req = true;
			uart_rx_disable(uart);
	case UART_RX_BUF_RELEASED:
		LOG_DBG("UART_RX_BUF_RELEASED");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf->len > 0) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else {
			k_free(buf);
Thread taking care of forwarding the data to beacon or ble nus:
void ble_write_thread(void)
	/* Don't go any further until BLE is initialized */
	k_sem_take(&ble_init_ok, K_FOREVER);
	for (;;) {
		/* Wait indefinitely for data to be sent over bluetooth */
		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
						     K_FOREVER);
		int err = send_beacon();
		if (err)
			printk("failed to send beacon");
		if (bt_nus_send(NULL, buf->data, buf->len))
		    LOG_WRN("Failed to send data over BLE connection");
		    printf("Failed to send data over BLE connection");
		k_free(buf);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);
NOTE:
Even if I don't get the expected events for what ever reason, once the uart buffer fills up, UART_RX_BUF_REQUEST event happens and I can see all the data including the data for which UART_RX_RDY did not happen. So looks like the data actually gets to the uart buffer only repective event is not sent.
I was wondering it could be because of interrupt priorities, but I could not find documentation or any samples where interrupt priorities are modified, but I have tried the following in app.overlay without any changes in the outcome:
&uart1 {
	interrupts = <40 0>;
