nRF52833 send analog data using saadc to nrf connect app
I am attempting to modify the peripheral_uart example for nRF52833 to send analog data from CH[3] of the saadc to the nrf connect app.
I have enabled the saadc in my sdk_config.h found here \nRF5_SDK_17.1.0_ddde560\config\nrf52833\config\:
#ifndef NRFX_SAADC_ENABLED
#define NRFX_SAADC_ENABLED 1
#ifndef SAADC_ENABLED
#define SAADC_ENABLED 1
And I have added the following code to my main loop in the example program:
void main(void)
// For reading analog pin 2 / channel 3
	volatile int16_t result = 0;
	volatile float precise_result = 0;
	// Start HFCLK from crystal oscillator, this will give the SAADC higher accuracy
	while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
	// Configure SAADC singled-ended channel, Internal reference (0.6V) and 1/6 gain.
	// Read analog from IN_MCU -- AIN2/P0.04 - 10 -- AIN2 is channel 3, page 373: https://infocenter.nordicsemi.com/pdf/nRF52833_OPS_v0.7.pdf
	NRF_SAADC->CH[3].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_6 << SAADC_CH_CONFIG_GAIN_Pos) |
							  (SAADC_CH_CONFIG_MODE_SE << SAADC_CH_CONFIG_MODE_Pos) |
							  (SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
							  (SAADC_CH_CONFIG_RESN_Bypass << SAADC_CH_CONFIG_RESN_Pos) |
							  (SAADC_CH_CONFIG_RESP_Bypass << SAADC_CH_CONFIG_RESP_Pos) |
							  (SAADC_CH_CONFIG_TACQ_3us << SAADC_CH_CONFIG_TACQ_Pos);
	// Configure the SAADC channel with VDD as positive input, no negative input(single ended).
	NRF_SAADC->CH[3].PSELP = SAADC_CH_PSELP_PSELP_VDD << SAADC_CH_PSELP_PSELP_Pos;
	NRF_SAADC->CH[3].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
	// Configure the SAADC resolution.
	NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_14bit << SAADC_RESOLUTION_VAL_Pos;
	// Configure result to be put in RAM at the location of "result" variable.
	NRF_SAADC->RESULT.MAXCNT = 1;
	NRF_SAADC->RESULT.PTR = (uint32_t)&result;
	// No automatic sampling, will trigger with TASKS_SAMPLE.
	NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
	// Enable SAADC (would capture analog pins if they were used in CH[0].PSELP)
	NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
	// Calibrate the SAADC (only needs to be done once in a while)
	NRF_SAADC->TASKS_CALIBRATEOFFSET = 1;
	while (NRF_SAADC->EVENTS_CALIBRATEDONE == 0)
	NRF_SAADC->EVENTS_CALIBRATEDONE = 0;
	while (NRF_SAADC->STATUS == (SAADC_STATUS_STATUS_Busy << SAADC_STATUS_STATUS_Pos))
	// Start the SAADC and wait for the started event.
	NRF_SAADC->TASKS_START = 1;
	while (NRF_SAADC->EVENTS_STARTED == 0)
	NRF_SAADC->EVENTS_STARTED = 0;
	// Do a SAADC sample, will put the result in the configured RAM buffer.
	NRF_SAADC->TASKS_SAMPLE = 1;
	while (NRF_SAADC->EVENTS_END == 0)
	NRF_SAADC->EVENTS_END = 0;
	// Convert the result to voltage
	// Result = [V(p) - V(n)] * GAIN/REFERENCE * 2^(RESOLUTION)
	// Result = (VDD - 0) * ((1/6) / 0.6) * 2^14
	// VDD = Result / 4551.1
	precise_result = (float)result / 4551.1f;
	precise_result; // to get rid of set but not used warning
	// Stop the SAADC, since it's not used anymore.
	NRF_SAADC->TASKS_STOP = 1;
	while (NRF_SAADC->EVENTS_STOPPED == 0)
	NRF_SAADC->EVENTS_STOPPED = 0;
	uint8_t therm_data[20];
	sprintf((char *)therm_data, "%f", precise_result);
	// Send measurement to nRF Toolbox app
	int err = 0;
	err = bt_nus_send(NULL, therm_data, sizeof(therm_data));
	if (err)
		LOG_ERR("Failed to send thermistor data (err: %d)", err);
		return;
I can still see uart data tx and rx, but I do not see any of the analog data I am trying to read and send using bt_nus_send() - am I missing a characteristic or something else? From the documentation it appears that using this function I should be able to send any data: developer.nordicsemi.com/.../nus.html
I aim to just send analog data to one of the nrf apps and would appreciate any resources or pointers in the right direction.
Edit: forgot to add a link
