nRF9160 Reboots when Accessing UART2
I have a custom board with a GPS chip and trying to communicate via UART2 on a nRF9160 using NCS 2.1.2.
When I try to write to the UART, the board reboots with no error messages. This was working when I had it set to
UART0 but changing to UART2 started this issue. Any thoughts would be appreciated.
DTS:
&uart0 {
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
&uart2 {
	status = "okay";
	current-speed = <9600>;
   label = "UART_2";
	pinctrl-0 = <&uart2_default>;
	pinctrl-1 = <&uart2_sleep>;
prj.conf
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# UART
CONFIG_UART_LINE_CTRL=n
CONFIG_UART_2_ASYNC=n
CONFIG_UART_ASYNC_API=n
CONFIG_UART_2_NRF_HW_ASYNC=n
CONFIG_NRFX_UARTE2=y
Basic UART code:
void initUart() {
   uart = device_get_binding("UART_2");
	__ASSERT(uart, "Failed to get UART device");
	interrupt_driven(uart);
uint16_t writeUARTblock(const uint8_t *buf_block, uint16_t len) {
uint16_t written = 0;
   while (written < len) {
      if (k_fifo_is_empty(&tx_fifo)) {
	      struct tx_uart_data_t *fifo_buf = k_malloc(sizeof(struct tx_uart_data_t));
         if (len - written < UART_BUF_SIZE) {
            fifo_buf->len = len - written;
         } else
            fifo_buf->len = UART_BUF_SIZE;
         memcpy(fifo_buf->data, &buf_block[written], fifo_buf->len);
         written += fifo_buf->len;
	      k_fifo_put(&tx_fifo, fifo_buf);
	      uart_irq_tx_enable(uart);
         k_msleep(BUF_DELAY);
      } else
	return written;
Program output:
*** Booting Zephyr OS build v3.1.99-ncs1-1  ***
SerialTest has started
LEDs Enabled HIGH
[00:00:00.488,342] <inf> regulator_fixed: gps-hw-s onoff: 0
[00:00:00.494,689] <inf> regulator_fixed: gps-hw-r onoff: 0
[00:00:00.501,037] <inf> regulator_fixed: gps-pwr-en onoff: 0
[00:00:00.510,070] <inf> lis2dh: lis2dh@18: int1 on [email protected]
[00:00:00.517,059] <inf> lis2dh: lis2dh@18: int2 on [email protected]
[00:00:00.526,428] <inf> lis2dh: fs=2, odr=0x4 lp_en=0x0 scale=9576
LEDs Enabled HIGH
[00:00:00.488,677] <inf> regulator_fixed: gps-hw-s onoff: 0
[00:00:00.495,025] <inf> regulator_fixed: gps-hw-r onoff: 0
[00:00:00.501,373] <inf> regulator_fixed: gps-pwr-en onoff: 0
[00:00:00.510,437] <inf> lis2dh: lis2dh@18: int1 on [email protected]
[00:00:00.517,425] <inf> lis2dh: lis2dh@18: int2 on [email protected]
[00:00:00.526,824] <inf> lis2dh: fs=2, odr=0x4 lp_en=0x0 scale=9576
LEDs Enabled HIGH
  • Hi Paul,
    Håkon is Out of Office, so I will continue working on this case.
    Can you send the build/zephyr/zephyr.dts file from your project?
    Can you measure the voltage on the TX and RX lines when the board is powered?
    After you have initialized UART, but before writing and crashing.
    Sigurd Hellesvik
  • So I hooked up a GPS dev board to the nRF9160DK to replicate the issue. Plugging in the RX line (TX from GPS) will cause the reboot issue when sending serial data. Leaving it unplugged the board does not reboot. Voltage on the pin in 1.4 - 2.8V. On a scope, you see the serial data coming across.
    /dts-v1/;
    	#address-cells = < 0x1 >;
    	#size-cells = < 0x1 >;
    	model = "Nordic nRF9160 DK NRF9160";
    	compatible = "nordic,nrf9160-dk-nrf9160";
    	chosen {
    		zephyr,flash-controller = &flash_controller;
    		zephyr,entropy = &cryptocell_sw;
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,flash = &flash0;
    		zephyr,sram = &sram0_ns;
    		zephyr,code-partition = &slot0_ns_partition;
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    		pwm-led0 = &pwm_led0;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    		bootloader-led0 = &led0;
    		mcuboot-button0 = &button0;
    		mcuboot-led0 = &led0;
    		watchdog0 = &wdt0;
    		gpsuart = &uart2;
    		gpspwr = &gps_pwr;
    		gpshwr = &gps_hw_r;
    		gpshws = &gps_hw_s;
    	soc {
    		compatible = "nordic,nRF9160-SICA", "nordic,nRF9160", "nordic,nRF91", "simple-bus";
    		interrupt-parent = < &nvic >;
    		ranges;
    		nvic: interrupt-controller@e000e100 {
    			compatible = "arm,v8m-nvic";
    			reg = < 0xe000e100 0xc00 >;
    			interrupt-controller;
    			#interrupt-cells = < 0x2 >;
    			arm,num-irq-priority-bits = < 0x3 >;
    			phandle = < 0x1 >;
    		systick: timer@e000e010 {
    			compatible = "arm,armv8m-systick";
    			reg = < 0xe000e010 0x10 >;
    			status = "disabled";
    		sram0: memory@20000000 {
    			compatible = "mmio-sram";
    			reg = < 0x20000000 0x40000 >;
    		peripheral@40000000 {
    			ranges = < 0x0 0x40000000 0x10000000 >;
    			flash_controller: flash-controller@39000 {
    				compatible = "nordic,nrf91-flash-controller";
    				reg = < 0x39000 0x1000 >;
    				partial-erase;
    				flash0: flash@0 {
    					compatible = "soc-nv-flash";
    					erase-block-size = < 0x1000 >;
    					write-block-size = < 0x4 >;
    					reg = < 0x0 0x100000 >;
    					partitions {
    						boot_partition: partition@0 {
    							label = "mcuboot";
    							reg = < 0x0 0x10000 >;
    						slot0_partition: partition@10000 {
    							label = "image-0";
    							reg = < 0x10000 0x40000 >;
    						slot0_ns_partition: partition@50000 {
    							label = "image-0-nonsecure";
    							reg = < 0x50000 0x30000 >;
    						slot1_partition: partition@80000 {
    							label = "image-1";
    							reg = < 0x80000 0x40000 >;
    						slot1_ns_partition: partition@c0000 {
    							label = "image-1-nonsecure";
    							reg = < 0xc0000 0x30000 >;
    						scratch_partition: partition@f0000 {
    							label = "image-scratch";
    							reg = < 0xf0000 0xa000 >;
    						storage_partition: partition@fa000 {
    							label = "storage";
    							reg = < 0xfa000 0x6000 >;
    			adc: adc@e000 {
    				compatible = "nordic,nrf-saadc";
    				reg = < 0xe000 0x1000 >;
    				interrupts = < 0xe 0x1 >;
    				status = "okay";
    				#io-channel-cells = < 0x1 >;
    				phandle = < 0x14 >;
    			dppic: dppic@17000 {
    				compatible = "nordic,nrf-dppic";
    				reg = < 0x17000 0x1000 >;
    				status = "okay";
    			egu0: egu@1b000 {
    				compatible = "nordic,nrf-egu";
    				reg = < 0x1b000 0x1000 >;
    				interrupts = < 0x1b 0x1 >;
    				status = "okay";
    			egu1: egu@1c000 {
    				reg = < 0x1c000 0x1000 >;
    				interrupts = < 0x1c 0x1 >;
    				status = "okay";
    			egu2: egu@1d000 {
    				reg = < 0x1d000 0x1000 >;
    				interrupts = < 0x1d 0x1 >;
    				status = "okay";
    			egu3: egu@1e000 {
    				reg = < 0x1e000 0x1000 >;
    				interrupts = < 0x1e 0x1 >;
    				status = "okay";
    			egu4: egu@1f000 {
    				reg = < 0x1f000 0x1000 >;
    				interrupts = < 0x1f 0x1 >;
    				status = "okay";
    			egu5: egu@20000 {
    				reg = < 0x20000 0x1000 >;
    				interrupts = < 0x20 0x1 >;
    				status = "okay";
    			ipc: ipc@2a000 {
    				compatible = "nordic,nrf-ipc";
    				reg = < 0x2a000 0x1000 >;
    				interrupts = < 0x2a 0x1 >;
    				status = "okay";
    			i2s0: i2s@28000 {
    				compatible = "nordic,nrf-i2s";
    				#size-cells = < 0x0 >;
    				reg = < 0x28000 0x1000 >;
    				interrupts = < 0x28 0x1 >;
    			kmu: kmu@39000 {
    				compatible = "nordic,nrf-kmu";
    				interrupts = < 0x39 0x1 >;
    				status = "okay";
    			pdm0: pdm@26000 {
    				compatible = "nordic,nrf-pdm";
    				reg = < 0x26000 0x1000 >;
    				interrupts = < 0x26 0x1 >;
    			regulators: regulator@4000 {
    				compatible = "nordic,nrf-regulators";
    				reg = < 0x4000 0x1000 >;
    				status = "okay";
    			vmc: vmc@3a000 {
    				compatible = "nordic,nrf-vmc";
    				reg = < 0x3a000 0x1000 >;
    				status = "okay";
    			uart0: uart@8000 {
    				reg = < 0x8000 0x1000 >;
    				interrupts = < 0x8 0x1 >;
    				status = "okay";
    				current-speed = < 0x1c200 >;
    				pinctrl-0 = < &uart0_default >;
    				pinctrl-1 = < &uart0_sleep >;
    			uart1: arduino_serial: uart@9000 {
    				reg = < 0x9000 0x1000 >;
    				interrupts = < 0x9 0x1 >;
    				pinctrl-0 = < &uart1_default >;
    				pinctrl-1 = < &uart1_sleep >;
    			uart2: uart@a000 {
    				reg = < 0xa000 0x1000 >;
    				interrupts = < 0xa 0x1 >;
    				status = "okay";
    				pinctrl-0 = < &uart2_default >;
    				pinctrl-1 = < &uart2_sleep >;
    				current-speed = < 0x2580 >;
    			uart3: uart@b000 {
    				reg = < 0xb000 0x1000 >;
    				interrupts = < 0xb 0x1 >;
    			i2c0: i2c@8000 {
    				clock-frequency = < 0x186a0 >;
    			i2c1: i2c@9000 {
    				pinctrl-0 = < &i2c1_default >;
    				pinctrl-1 = < &i2c1_sleep >;
    			i2c2: arduino_i2c: i2c@a000 {
    				pinctrl-0 = < &i2c2_default >;
    				pinctrl-1 = < &i2c2_sleep >;
    			i2c3: i2c@b000 {
    			spi0: spi@8000 {
    				max-frequency = < 0x7a1200 >;
    			spi1: spi@9000 {
    			spi2: spi@a000 {
    			spi3: arduino_spi: spi@b000 {
    				status = "okay";
    				cs-gpios = < &arduino_header 0x10 0x1 >;
    				pinctrl-0 = < &spi3_default >;
    				pinctrl-1 = < &spi3_sleep >;
    			pwm0: pwm@21000 {
    				compatible = "nordic,nrf-pwm";
    				reg = < 0x21000 0x1000 >;
    				interrupts = < 0x21 0x1 >;
    				status = "okay";
    				#pwm-cells = < 0x3 >;
    				pinctrl-0 = < &pwm0_default >;
    				pinctrl-1 = < &pwm0_sleep >;
    				phandle = < 0x12 >;
    			pwm1: pwm@22000 {
    				reg = < 0x22000 0x1000 >;
    				interrupts = < 0x22 0x1 >;
    			pwm2: pwm@23000 {
    				reg = < 0x23000 0x1000 >;
    				interrupts = < 0x23 0x1 >;
    			pwm3: pwm@24000 {
    				reg = < 0x24000 0x1000 >;
    				interrupts = < 0x24 0x1 >;
    			gpio0: gpio@842500 {
    				compatible = "nordic,nrf-gpio";
    				gpio-controller;
    				reg = < 0x842500 0x300 >;
    				#gpio-cells = < 0x2 >;
    				status = "okay";
    				port = < 0x0 >;
    				phandle = < 0x11 >;
    			rtc0: rtc@14000 {
    				compatible = "nordic,nrf-rtc";
    				reg = < 0x14000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x14 0x1 >;
    				status = "okay";
    				clock-frequency = < 0x8000 >;
    				prescaler = < 0x1 >;
    			rtc1: rtc@15000 {
    				reg = < 0x15000 0x1000 >;
    				cc-num = < 0x4 >;
    				interrupts = < 0x15 0x1 >;
    				status = "okay";
    			clock: clock@5000 {
    				compatible = "nordic,nrf-clock";
    				reg = < 0x5000 0x1000 >;
    				interrupts = < 0x5 0x1 >;
    				status = "okay";
    			power: power@5000 {
    				compatible = "nordic,nrf-power";
    				status = "okay";
    			wdt: wdt0: watchdog@18000 {
    				compatible = "nordic,nrf-wdt";
    				reg = < 0x18000 0x1000 >;
    				interrupts = < 0x18 0x1 >;
    				status = "okay";
    			timer0: timer@f000 {
    				compatible = "nordic,nrf-timer";
    				status = "okay";
    				reg = < 0xf000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0xf 0x1 >;
    				prescaler = < 0x0 >;
    			timer1: timer@10000 {
    				status = "okay";
    				reg = < 0x10000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x10 0x1 >;
    			timer2: timer@11000 {
    				status = "okay";
    				reg = < 0x11000 0x1000 >;
    				cc-num = < 0x6 >;
    				interrupts = < 0x11 0x1 >;
    		gpiote: gpiote@40031000 {
    			compatible = "nordic,nrf-gpiote";
    			reg = < 0x40031000 0x1000 >;
    			interrupts = < 0x31 0x5 >;
    			status = "okay";
    	pinctrl: pin-controller {
    		compatible = "nordic,nrf-pinctrl";
    		uart0_default: uart0_default {
    			phandle = < 0x2 >;
    			group1 {
    				psels = < 0x1d >, < 0x2001b >;
    			group2 {
    				psels = < 0x1001c >, < 0x3001a >;
    				bias-pull-up;
    		uart0_sleep: uart0_sleep {
    			phandle = < 0x3 >;
    			group1 {
    				psels = < 0x1d >, < 0x1001c >, < 0x2001b >, < 0x3001a >;
    				low-power-enable;
    		uart1_default: uart1_default {
    			phandle = < 0x4 >;
    			group1 {
    				psels = < 0x1 >, < 0x2000e >;
    			group2 {
    				psels = < 0x10000 >, < 0x3000f >;
    				bias-pull-up;
    		uart1_sleep: uart1_sleep {
    			phandle = < 0x5 >;
    			group1 {
    				psels = < 0x1 >, < 0x10000 >, < 0x2000e >, < 0x3000f >;
    				low-power-enable;
    		uart2_default: uart2_default {
    			phandle = < 0x6 >;
    			group1 {
    				psels = < 0x18 >, < 0x10017 >;
    		uart2_sleep: uart2_sleep {
    			phandle = < 0x7 >;
    			group1 {
    				low-power-enable;
    		i2c2_default: i2c2_default {
    			phandle = < 0xa >;
    			group1 {
    				psels = < 0xc001e >, < 0xb001f >;
    		i2c2_sleep: i2c2_sleep {
    			phandle = < 0xb >;
    			group1 {
    				low-power-enable;
    		pwm0_default: pwm0_default {
    			phandle = < 0xf >;
    			group1 {
    				psels = < 0x160002 >;
    		pwm0_sleep: pwm0_sleep {
    			phandle = < 0x10 >;
    			group1 {
    				low-power-enable;
    		spi3_default: spi3_default {
    			phandle = < 0xd >;
    			group1 {
    				psels = < 0x4000d >, < 0x6000c >, < 0x5000b >;
    		spi3_sleep: spi3_sleep {
    			phandle = < 0xe >;
    			group1 {
    				low-power-enable;
    		i2c1_default: i2c1_default {
    			phandle = < 0x8 >;
    			group1 {
    				psels = < 0xc0018 >, < 0xb0019 >;
    		i2c1_sleep: i2c1_sleep {
    			phandle = < 0x9 >;
    			group1 {
    				low-power-enable;
    	rng_hci: entropy_bt_hci {
    		compatible = "zephyr,bt-hci-entropy";
    		status = "okay";
    	cpus {
    		cpu@0 {
    			device_type = "cpu";
    			compatible = "arm,cortex-m33f";
    			reg = < 0x0 >;
    			mpu: mpu@e000ed90 {
    				compatible = "arm,armv8m-mpu";
    				reg = < 0xe000ed90 0x40 >;
    				arm,num-mpu-regions = < 0x10 >;
    	cryptocell_sw: cryptocell-sw {
    		compatible = "nordic,nrf-cc310-sw";
    		label = "CRYPTOCELL_SW";
    		status = "okay";
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = < &gpio0 0x2 0x0 >;
    			label = "Green LED 1";
    		led1: led_1 {
    			gpios = < &gpio0 0x3 0x0 >;
    			label = "Green LED 2";
    		led2: led_2 {
    			gpios = < &gpio0 0x4 0x0 >;
    			label = "Green LED 3";
    		led3: led_3 {
    			gpios = < &gpio0 0x5 0x0 >;
    			label = "Green LED 4";
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led_0 {
    			pwms = < &pwm0 0x0 0x1312d00 0x0 >;
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = < &gpio0 0x6 0x11 >;
    			label = "Push button 1";
    		button1: button_1 {
    			gpios = < &gpio0 0x7 0x11 >;
    			label = "Push button 2";
    		button2: button_2 {
    			gpios = < &gpio0 0x8 0x11 >;
    			label = "Switch 1";
    		button3: button_3 {
    			gpios = < &gpio0 0x9 0x11 >;
    			label = "Switch 2";
    		fix_status: fix_status {
    			gpios = < &gpio0 0xf 0x0 >;
    			label = "Fix Status";
    	interface_to_nrf52840: gpio-interface {
    		compatible = "nordic,nrf9160dk-nrf52840-interface";
    		gpio-map-mask = < 0xf 0x0 >;
    		gpio-map-pass-thru = < 0x0 0xffffffff >;
    		gpio-map = < 0x0 0x0 &gpio0 0x11 0x0 >, < 0x1 0x0 &gpio0 0x12 0x0 >, < 0x2 0x0 &gpio0 0x13 0x0 >, < 0x3 0x0 &gpio0 0x15 0x0 >, < 0x4 0x0 &gpio0 0x16 0x0 >, < 0x5 0x0 &gpio0 0x17 0x0 >;
    		phandle = < 0x13 >;
    	nrf52840_reset: gpio-reset {
    		compatible = "nordic,nrf9160dk-nrf52840-reset";
    		gpios = < &interface_to_nrf52840 0x5 0x0 >;
    	arduino_header: connector {
    		compatible = "arduino-header-r3";
    		gpio-map-mask = < 0xffffffff 0xffffffc0 >;
    		gpio-map-pass-thru = < 0x0 0x3f >;
    		gpio-map = < 0x0 0x0 &gpio0 0xe 0x0 >, < 0x1 0x0 &gpio0 0xf 0x0 >, < 0x2 0x0 &gpio0 0x10 0x0 >, < 0x3 0x0 &gpio0 0x11 0x0 >, < 0x4 0x0 &gpio0 0x12 0x0 >, < 0x5 0x0 &gpio0 0x13 0x0 >, < 0x6 0x0 &gpio0 0x0 0x0 >, < 0x7 0x0 &gpio0 0x1 0x0 >, < 0x8 0x0 &gpio0 0x2 0x0 >, < 0x9 0x0 &gpio0 0x3 0x0 >, < 0xa 0x0 &gpio0 0x4 0x0 >, < 0xb 0x0 &gpio0 0x5 0x0 >, < 0xc 0x0 &gpio0 0x6 0x0 >, < 0xd 0x0 &gpio0 0x7 0x0 >, < 0xe 0x0 &gpio0 0x8 0x0 >, < 0xf 0x0 &gpio0 0x9 0x0 >, < 0x10 0x0 &gpio0 0xa 0x0 >, < 0x11 0x0 &gpio0 0xb 0x0 >, < 0x12 0x0 &gpio0 0xc 0x0 >, < 0x13 0x0 &gpio0 0xd 0x0 >, < 0x14 0x0 &gpio0 0x1e 0x0 >, < 0x15 0x0 &gpio0 0x1f 0x0 >;
    		phandle = < 0xc >;
    	arduino_adc: analog-connector {
    		compatible = "arduino,uno-adc";
    		io-channel-map = < 0x0 &adc 0x1 >, < 0x1 &adc 0x2 >, < 0x2 &adc 0x3 >, < 0x3 &adc 0x4 >, < 0x4 &adc 0x5 >, < 0x5 &adc 0x6 >;
    	reserved-memory {
    		ranges;
    		sram0_s: image_s@20000000 {
    			reg = < 0x20000000 0x16000 >;
    		sram0_modem: image_modem@20016000 {
    			reg = < 0x20016000 0xa000 >;
    		sram0_ns: image_ns@20020000 {
    			reg = < 0x20020000 0x20000 >;
    	gpiocustom {
    		gps_pwr: gps-pwr-en {
    			label = "Enable GPS Power";
    			gpios = < &gpio0 0xe 0x1 >;
    		gps_hw_r: gps-hw-r {
    			label = "GPS Hardware Reset";
    			gpios = < &gpio0 0xc 0x1 >;
    		gps_hw_s: gps-hw-s {
    			label = "GPS Hardware Standby";
    			gpios = < &gpio0 0x16 0x1 >;
    	vbatt {
    		compatible = "voltage-divider";
    		io-channels = < &adc 0x1f >;
    		output-ohms = < 0x186a0 >;
    		full-ohms = < 0x30d40 >;
    		power-gpios = < &gpio0 0xa 0x0 >;
    I do not find anything off from this either hmm.
    Can you try the Zephyr UART Driver Sample and see if you still get the same error?
    Sigurd Hellesvik
  • Thank you for that example. There appears to be something going on with our UART code.
