Asset Tracker v2 SUPL Integration
This might sound like a silly question, but is there a way to use SUPL library with Asset Tracker v2 with LwM2M integration without having to trade off logging? SUPL library is quite massive and linking against it requires AT client library and logging to be disabled. Even trying to enable LOG_MINIMAL seems not to be sufficient:
[30/30] Linking C executable zephyr\zephyr.elf
Memory region         Used Size  Region Size  %age Used
           FLASH:       40410 B        48 KB     82.21%
             RAM:       28024 B     211736 B     13.24%
        IDT_LIST:          0 GB         2 KB      0.00%
[425/447] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe  -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf  && cmd.exe /C "cd /D C:\ncs\v2.2.0\nrf\applications\asset_tracker_v2\build\zephyr && C:\ncs\toolchains\v2.2.0\opt\bin\cmake.exe -E echo ""
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 35440 bytes
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.2.0\opt\bin\cmake.EXE' --build 'c:\ncs\v2.2.0\nrf\applications\asset_tracker_v2\build'
Kind Regards,
Iman
