Asset Tracker v2 SUPL Integration
This might sound like a silly question, but is there a way to use SUPL library with Asset Tracker v2 with LwM2M integration without having to trade off logging? SUPL library is quite massive and linking against it requires AT client library and logging to be disabled. Even trying to enable LOG_MINIMAL seems not to be sufficient:
[30/30] Linking C executable zephyr\zephyr.elf
Memory region         Used Size  Region Size  %age Used
           FLASH:       40410 B        48 KB     82.21%
             RAM:       28024 B     211736 B     13.24%
        IDT_LIST:          0 GB         2 KB      0.00%
[425/447] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe  -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf  && cmd.exe /C "cd /D C:\ncs\v2.2.0\nrf\applications\asset_tracker_v2\build\zephyr && C:\ncs\toolchains\v2.2.0\opt\bin\cmake.exe -E echo ""
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
c:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 35440 bytes
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.2.0\opt\bin\cmake.EXE' --build 'c:\ncs\v2.2.0\nrf\applications\asset_tracker_v2\build'
Kind Regards,
Iman
    That sounds a little weird, could you please point to where you found that information?
    Read that on "Location Services in a cloud-to-cloud setup" page. It says "You must have an nRF Cloud Pro or Enterprise plan."
    What I want to achieve at the end of the day is for my hardware on the field to only need to communicate to one entity on the cloud, using one protocol only. That would mean no need for SUPL client library, but that is, at least for now, far from being realised as I am still trying to make heads or tails of Google's SUPL client.
    The end-goal for me is to have a single LwM2M server that can reply to A-GPS or P-GPS requests by proxying it to either a SUPL service, or to an A-GPS cloud provider. This way the hardware in the field needs to only know about one server, one set of credentials, and one communication protocol (UDP in this case).
    Kind Regards,
    Iman
  • Hello Iman,
    Sorry for the late reply. I have forwarded the feedback to our cloud team, and I hope that they can provide some more information to you in regards to the nRF Cloud Location services with cloud-to-cloud.
    If you do want to get more information on this solution I think the best option is to directly contact your local RSM.
    Based on that, the cloud to cloud solution with nRF Cloud Location services sounds like the best solution especially to save flash on the device.
    Øyvind
