nrf52840 low power pwm in nRF Connect SDK
There is a low power pwm in nRF5 SDK. I can not find it in the nRF Connect SDK. Any suggestion how to achieve the same using nRF Connect SDK?
  •   thank you very much for taking the time and checking it on your end.
    Can you double check that the overlay files are used?
    The app.overlay is used - without it I get a build break as the pwm_led1 is undefined.
    If they are, then you should see that CONFIG_PWM_NRF5_SW=y in build/zephyr/.config
    I see CONFIG_PWM_NRF5_SW=y in build/zephyr/.config:
    As you can see I have set CONFIG_PWM_LOG_LEVEL_DBG=y to mimic your settings. I still see the same "error":
    At this point I will assume this is a minor issue related to VS Code and how it does the on the fly parsing. I will try to update to nRF Connect SDK 2.2.0 during the weekend and let you know if it changes something.
    BTW - is there a way to add an offset between PWM cannel 0 and PWM channel 1? I have seen some discussions how to do in the legacy nRF5 SDK, but I do not know how to do it in Zephyr using nRF Connect SDK.
    Yes, that seems likely (although it is a bit strange that I don't see the same on my end).
    There is no direct support for that. It might be possible to achieve it somehow, but I am not able to suggest anything specific.
  • I will try to update to nRF Connect SDK 2.2.0 during the weekend and let you know if it changes something.
    Just FYI. I have updated the nRF Conncet SDK to version 2.2.0. I have created the project again and I do not see this strange "error" anymore.
