How to notify the advertising device by pc-ble-driver-py?
I try to advertise nrf52840 dongle on pc to build a connection with nrf5340 uart service. Although I try to modify the advertising program by advertising.py and heart_rate_collector.py, I still can't succeed in notifying the uart handle. Here is my code, which results in 'cccd not found'.
class HRCollector(BLEDriverObserver, BLEAdapterObserver):
    def __init__(self, adapter):
        super(HRCollector, self).__init__()
        self.adapter = adapter
        self.conn_q = Queue()
        self.adapter.observer_register(self)
        self.adapter.driver.observer_register(self)
        self.adapter.default_mtu = 250
        from pc_ble_driver_py.ble_driver import BLEUUIDBase
        self.nus_base = BLEUUIDBase([
            0x6e, 0x40, 0x00, 0x00, 0xb5, 0xa3, 0xf3, 0x93, 0xe0, 0xa9, 0xe5, 0x0e, 0x24, 0xdc, 0xca, 0x9e
    def open(self):
        self.adapter.driver.open()
        if config.__conn_ic_id__.upper() == "NRF51":
            self.adapter.driver.ble_enable(
                BLEEnableParams(
                    vs_uuid_count=1,
                    service_changed=0,
                    periph_conn_count=0,
                    central_conn_count=1,
                    central_sec_count=0,
        elif config.__conn_ic_id__.upper() == "NRF52":
            gatt_cfg = BLEConfigConnGatt()
            gatt_cfg.att_mtu = self.adapter.default_mtu
            gatt_cfg.tag = CFG_TAG
            self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
            self.adapter.driver.ble_enable()
            self.adapter.driver.ble_vs_uuid_add(self.nus_base)
    def connect_and_discover(self):
        scan_duration = 20
        adv_data = BLEAdvData(complete_local_name="nrf52840")
        # adv_data = BLEAdvData(complete_local_name="pc_ble_driver_py")
        self.adapter.driver.ble_gap_adv_data_set(adv_data)
        self.adapter.driver.ble_gap_adv_start()
        scan_duration = 60
        try:
            new_conn = self.conn_q.get(timeout=scan_duration)
            self.adapter.enable_notification(
                new_conn, BLEUUID(Uart_Tx_uuid), uart_tx_handle
            return new_conn
        except Empty:
            print(f"No heart rate collector advertising with name {TARGET_DEV_NAME} found.")
            return None
        return None
def main(selected_serial_port):
    print("Serial port used: {}".format(selected_serial_port))
    driver = BLEDriver(
        serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000, log_severity_level="info"
    observer = TimeoutObserver()
    driver.observer_register(observer)
    adapter = BLEAdapter(driver)
    collector = HRCollector(adapter)
    conn = collector.open()
    collector.connect_and_discover()
    observer.wait_for_timeout()
    collector.close()
I find that the db_conns has empty service. Is this way to notify advertising device's handle not correct? Thank you for your help!
    Just letting you know that I am looking into it, but I will have to get back to you.
    Elfving
  • Hi Elfving,
    Thank you for your attention. I am still struggling with this problem and try to solve it.
    zhaoyuan
  • Hello Zhaoyuan,
    I am not seeing any service discovery in your code. Maybe that is why its not getting any CCCDs.
    Elfving
  • Hi Elfving,
    It really helps. Thank you for your kindly help! By the way, I try to notify the uart over ble handle but get nothing, which however works in scaning way. Have you met this problem? I am not very familiar with BLE. I would be grateful if you could give me some advice. Here is the logs.
    zhaoyuan
    2022-12-14 23:41:24,604 [4704/LogThread] Successfully opened COM16. Baud rate: 1000000. Flow control: none. Parity: none.
    2022-12-14 23:41:24,604 [4704/LogThread] evt> severity(20) message(Successfully opened COM16. Baud rate: 1000000. Flow control: none. Parity: none.)
    2022-12-14 23:41:24,605 [18004/StatusThread] RpcAppStatus.resetPerformed: Target Reset performed
    2022-12-14 23:41:24,605 [18004/StatusThread] evt> status code(RpcAppStatus.resetPerformed) message(Target Reset performed)
    2022-12-14 23:41:25,850 [18004/StatusThread] RpcAppStatus.connectionActive: Connection active
    2022-12-14 23:41:25,850 [18004/StatusThread] evt> status code(RpcAppStatus.connectionActive) message(Connection active)
    New connection: 3
    2022-12-14 23:41:26,022 [19220/EventThread] Exception: MTU exchange reply failed. Common causes are: missing att_mtu setting in ble_cfg_set, different config tags used in ble_cfg_set and adv_start.
    2022-12-14 23:41:26,023 [19220/EventThread] <FrameSummary file D:\zhaoyuan_data\dsp\brain_usb\pc-ble-driver-py-master\pc_ble_driver_py\ble_driver.py, line 3001 in ble_event_handler_sync>
    2022-12-14 23:41:26,023 [19220/EventThread] <FrameSummary file D:\zhaoyuan_data\dsp\brain_usb\pc-ble-driver-py-master\pc_ble_driver_py\ble_adapter.py, line 800 in on_gatts_evt_exchange_mtu_request>
    2022-12-14 23:41:26,024 [19220/EventThread] evt> on_gattc_evt_prim_srvc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Service uuid(0x1801) start handle(1) end handle(8)
     Service uuid(0x1800) start handle(9) end handle(13)
    2022-12-14 23:41:26,037 [19220/EventThread] evt> on_gattc_evt_prim_srvc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Service uuid(0x0001) start handle(14) end handle(19)
    2022-12-14 23:41:26,051 [19220/EventThread] evt> on_gattc_evt_prim_srvc_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(3)
    2022-12-14 23:41:26,066 [19220/EventThread] evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Characteristic uuid(0x2A05) properties(BLECharProperties(broadcast=0, read=0, write_wo_resp=0, write=0, notify=0, indicate=1, auth_signed_wr=0)) declaration handle(2) value handle(3)
     Characteristic uuid(0x2B29) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=1, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(5) value handle(6)
    2022-12-14 23:41:26,127 [19220/EventThread] evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Characteristic uuid(0x2B2A) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(7) value handle(8)
    2022-12-14 23:41:26,142 [19220/EventThread] evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(3)
    2022-12-14 23:41:26,156 [19220/EventThread] evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Descriptor uuid(0x2A05) handle(3)
     Descriptor uuid(0x2902 (Standard.cccd)) handle(4)
    2022-12-14 23:41:26,217 [19220/EventThread] evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Descriptor uuid(0x2B29) handle(6)
    2022-12-14 23:41:26,277 [19220/EventThread] evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Descriptor uuid(0x2B2A) handle(8)
    2022-12-14 23:41:26,292 [19220/EventThread] evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Characteristic uuid(0x2A00) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(10) value handle(11)
     Characteristic uuid(0x2A01) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(12) value handle(13)
    2022-12-14 23:41:26,306 [19220/EventThread] evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(3)
    2022-12-14 23:41:26,367 [19220/EventThread] evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Descriptor uuid(0x2A00) handle(11)
    2022-12-14 23:41:26,427 [19220/EventThread] evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Descriptor uuid(0x2A01) handle(13)
    2022-12-14 23:41:26,441 [19220/EventThread] evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Characteristic uuid(0x0003) properties(BLECharProperties(broadcast=0, read=0, write_wo_resp=0, write=0, notify=1, indicate=0, auth_signed_wr=0)) declaration handle(15) value handle(16)
    2022-12-14 23:41:26,456 [19220/EventThread] evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Characteristic uuid(0x0002) properties(BLECharProperties(broadcast=0, read=0, write_wo_resp=1, write=1, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(18) value handle(19)
    2022-12-14 23:41:26,516 [19220/EventThread] evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(3)
    2022-12-14 23:41:26,576 [19220/EventThread] evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Descriptor uuid(0x0003) handle(16)
    2022-12-14 23:41:26,591 [19220/EventThread] evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Descriptor uuid(0x2902 (Standard.cccd)) handle(17)
    2022-12-14 23:41:26,606 [19220/EventThread] evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(3)
     Descriptor uuid(0x0002) handle(19)
    2022-12-14 23:41:26,666 [19220/EventThread] evt> on_gattc_evt_write_rsp conn(3)
     error_handle(0)
     attr_handle(17)
     write_op(BLEGattWriteOperation.write_req)
     offset(0)
     data([])
    2022-12-14 23:41:36,675 [4704/LogThread] serial port COM16 closed.
    2022-12-14 23:41:36,675 [4704/LogThread] evt> severity(20) message(serial port COM16 closed.)
    2022-12-14 23:41:36,675 [16984/MainThread] close result 0
    2022-12-14 23:41:36,675 [16984/MainThread] Stopping workers
    2022-12-14 23:41:37,681 [16984/MainThread] Workers stopped
    Process finished with exit code 0
    No, I haven't personally.
    In that case I would recommend you to rather work on something a bit newer and easier than pc-ble-driver. The lack of documentation can make it really difficult to work with.
    What are you trying to achieve? Maybe the NUS sample has all the features you need?
    Elfving
