Is it impossible to use the P0.00 port if I use app_timer.h?
Hello!
Using nrf_gpio.h enables P0.00 port control, but using app_timer.h together makes port control impossible.
I don't know if the code I wrote is the problem or not....
#define ON_OFF_DETECT 1
#define HOLD_DETECT 0
#define LED1 11
#define PRESS_BTN_TICKS APP_TIMER_TICKS(100) // 100 ms tick
uint32_t tick = 0;
APP_TIMER_DEF(m_app_timer_id);
static void lfclk_config(void)
   ret_code_t err_code = nrf_drv_clock_init();
static void app_timer_handler(void * p_context)
   tick++;
static void timer_init(void)
   ret_code_t err_code; err_code = app_timer_init();
   err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, app_timer_handler);
   nrf_gpio_cfg_input(ON_OFF_DETECT,NRF_GPIO_PIN_PULLUP);
   nrf_gpio_cfg_output(LED1); nrf_gpio_cfg_output(HOLD_DETECT);
   nrf_gpio_pin_set(LED1);
   lfclk_config();
   timer_init();
   while( 1 )
      if( tick == 0 )
         if( nrf_gpio_pin_read(ON_OFF_DETECT) == 0)
            tick = 1;
            uint32_t err_code = app_timer_start(m_app_timer_id, PRESS_BTN_TICKS, NULL);
      if( tick >= 30 ) // >= 3 sec ?
         nrf_gpio_pin_write(HOLD_DETECT,1);
         nrf_gpio_pin_set(HOLD_DETECT);
         ret_code_t err_code; err_code = app_timer_stop(m_app_timer_id);
         APP_ERROR_CHECK(err_code); break;
Thank you.
