Hi team,
I am trying to work on SPI peripheral on the nordic development board nRF52840. How many SPI compatible ICs are present on the board. And how to identify them?
Thanks.
Hi team,
Thanks.
There is no devices on the nRF52840 DK that uses an SPI interface. The closest thing would be the external memory that uses QSPI, but not SPI.
You can check this directly in the DK Hardware files.
Karl
Karl
Thank You Karl.
No problem at all, I am happy to help! :)
Please do not hesitate to open another ticket if you should encounter any other issues or questions in the future.
Karl
Hello Karl,
I am using SDK 16.0 for nRF52840 development board. I have found an example code for SPI in D:\..nRF5 SDK v16.0\examples\peripheral\spi path.
However, like You have mentioned that the MCU is connected to external memory via SPI, which APIs can I use for reading and writing data to the external memory?
thanks.
yugeswar said:However, like You have mentioned that the MCU is connected to external memory via SPI
This is not quite accurate - I said that the MCU is connected to external memory through QSPI, which is not SPI.
If you would like to test the usage of the external memory mounted on the DK you can check out the QSPI example in the SDK.
Karl
Thanks for the reply Karl.
I agree that the external memory is connected to MCU through QSPI. But in the nRF52840_DK_User_Guide,
https://infocenter.nordicsemi.com/pdf/nRF52840_DK_User_Guide_v1.2.pdf , it is mentioned that both SPI and QSPI are connected to the external memory.
If it is so, and if we configure SPI with the external memory GPIO pins, which APIs can I use to read and write data?
Yugeswar
