Is an "Erase all" in the Programmer required when the memory map is changed?
I needed to rework the memory map, to change the size of the slots to accommodate for a larger foot print. In the programmer, is an "Erase & write" with the hex file sufficient to lay down the new memory map or do I need to do an "Erase all" prior to the "Erase & write"?
Not sure how to verify that the new memory map is in place. These are changes made in the *_partition_conf.dts and *_common.dts.
    "Erase all" would clear the written memory on the device.
    "Erase & write" clears the written memory and programs the files added to the File Memory Layout.
    "Erase & write" already includes "Erase all".
    I think you could use "Read" which reads and displays the written memory in the Device Memory Layout.
    Amanda H.
