SAADC voltage calculation formula.
I'm using the SAADC voltage conversion formula from the Nordic example as follows: 10 bits are used in the example.
By the way I want to change ADC resolution to 12bit or 14bit.
So, as shown in the figure, I calculated using 4096 for 12 bit and 16384 for 14 bit.
However, the voltage is not correct.
I can change the setting to 12bit or 14bit as above in sdk_config.h.
What are the respective calculation formulas when the resolution is 12bit and 14bit?
Best Regards,
SunBae Yim.
