I am using light_switch_client and light_switch_server in nrf5 mesh sdk to send and recieve custom messages which i have added to its default structure.
Iam able to recieve the data and able to relay the message to next server node,
but the max distance of client to server is upto 50 mts approx. and the max distance of the relayed packet from one server node to another server node is way less than 10 mts,
I tried creating a new fresh packet in server whenever it recieves data from client and tried publishing it manually to the next server node, it also covers upto 50 mts,
1.Do i need to change some configuration for relay packets to increase the distance covered?
2.Is there a way to check the route of the relayed packet in the end node(other than ttl of the packet)?
Thanks.
