Unable to enable the standard library in nRF Connect SDK 2.2.0
Hello, based on the Zephyr document C++ language support: the doc mentioned that Zephyr does not support templates, so pretty much 99% of the STL are NOT available. But in the paragraph, it says:
"Any application that makes use of the Standard Template Library (STL) components, such as std::string and std::vector, must enable the C++ standard library support."
The help document does not mention how to enable the standard library support, and I can not find any other useful instructions to enable the support from anywhere. I guess that is another help doc that does not help at all.
I tried to enable the STL based on the reference https://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LIB_CPLUSPLUS. I have the following prj.conf
CONFIG_CPLUSPLUS=y
CONFIG_REQUIRES_FULL_LIBC=y
CONFIG_LIB_CPLUSPLUS=y
When I rebuild the project, I have the following warning
Any suggestion for enabling the STL?
    You get the error because it is not allowed to set CONFIG_REQUIRES_FULL_LIBC=y (it is used internally). A typical set of configurations sensible for using STL is:
    CONFIG_CPLUSPLUS=y
    CONFIG_NEWLIB_LIBC=y
    I tested this on my end, taking the C++ Synchronization sample and adding #include <vector>, and this function that I call in the main loop (demonstrating some basic STL usage with vector):
    void stl_stuff(void)
    	std::vector<int> array;
    	array.reserve(20);
    	for(int i=0; i<5; ++i)
    		array.push_back(i);
    	printk("Array capacity: %u\n", array.capacity());
    	printk("Array size: %u\n", array.size());
    	for(const auto &element : array)
        		printk("Element value: %i\n", element);
    That worked as expected on my end.
