Send long packets for Android using low MTU sizes
In a ble_app_uart example I have problems to send long packets if the Android smartphone only accepts MTU sizes of 20 bytes. I'm using the nRF5_SDK_17.1.0, the S132 over the SES IDE and the nR52-DK board.
The application adjusts the MTU size to the value negotiated by the smartphone and it's set to 20 bytes. However, when I send longer packets the smartphone only receives a part. It looks like the device only send one packet and doesn't manages automatically the division of the full packet for sendidn it in different subpackets.
How could I setup the Softdevice so it could automatically manages this sending of a long packet in subpackets? Excuse me if there is other similar case about this, but I have not been able to find it.
Thank you in advance.
Joel
    You can see how the ble_app_uart example handles this here:
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
    if the phone does only support 20 bytes MTU, then
    m_ble_nus_max_data_len is 20, and the data you try to send will be split into chunks, where each chunk is max 20 bytes.
  • Hi Sigurd,
    Thank you for your reply.
    i also see that in the gatt_evt_handler() the management of the MTU size should also update the m_ble_nus_max_data_len value. But it doesn't look to work:
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    I understand this piece of code should work, isn't it?
    Joel
    Default value of m_ble_nus_max_data_len is 20. If there is an MTU update, the m_ble_nus_max_data_len will be updated in gatt_evt_handler() to reflect the new MTU value.
    I have tested this using the Android nRF Connect app. I have the m_ble_nus_max_data_len  variable set to 20 in the nRF SDK. In nRFConnect Android app I do the next sequence:
    - I connect to the Nordic UART Service of the Dk board program.
    - I open the tab of this service. In the tab, I select Connect.
    - I select the "Nordic UART Service" and the app presents the RX Characteristics values and the TX Characteristics values.
    - I push the icon in the "Tx Characteristics". I understand that this will enable the reception of notifications.
    - I push the icon in the "Rx Characteristics". It opens a window to write a command to my FW. I send it.
    - The DK sends an answer that should be greater than 20 bytes. However, I can only receive 20 bytes and I the app doesn't receive more packets of 20 bytes.
    How could enable the automatic sending of the rest of the packet from the DK to the nRFConnect app?
    Joel
