nRF Sniffer for 802.15.4 doesn't appear on Wireshark interface
I am struggling to see nRF Sniffer for 802.15.4 as an interface in the Wireshark interface list under the startup welcome screen. I am using nRF62840-Dongle and flashed it by utilizing the nrf802154_sniffer_dongle.hex available under the GitHub nRF-Sniffer-for-802.15.4 repository. I didn't find a specific binary for nRF62840-Dongle device there.
  • Since I flashed the nRF62840-Dongle device using a mismatched binary nrf802154_sniffer_dongle.hex, is it the main cause of the issue? If so, where do I get the correct binary for the nRF62840-Dongle device?
I have Python 3 installation with Homebrew including Pip 3. I have listed the relevant installation path in the following:
  • which pythonpython not found
  • which pip/usr/local/bin/pip
  • which python3/usr/local/bin/python3
  • which pip3: /usr/local/bin/pip3
I installed pyserial using pip3 install pyserial. I copied the nrf802154_sniffer.py file under the ~/.config/wireshark/extcap location which is a Personal Extcap path.
When running the python3 nrf802154_sniffer.py --extcap-interfaces command, it outputs the following valid confirmation:
extcap {version=0.7.2}{help=https://github.com/NordicSemiconductor/nRF-Sniffer-for-802.15.4}{display=nRF Sniffer for 802.15.4}
interface {value=/dev/cu.usbmodemF1BD057D01BB1}{display=nRF Sniffer for 802.15.4}
control {number=6}{type=button}{role=logger}{display=Log}{tooltip=Show capture log}
So, what am I missing? Why nRF Sniffer for 802.15.4 interface isn't appearing on the Wireshark Custom Interface list?
  • fir wireshark -D interfaces
    Nordic dongle doesnt get listed here
    I created user instead of root and added to dialout, But no luck
    From Installing Wireshark on Ubuntu Linux:
    Did you also rememver to log out and in again
    Can you do "ls -l" from  the extcap folder?
  • Yes in fact i restarted the machine and used in root config
    this is at usr login
    What is expected in this location? Can you share some file or screen shot of what is expected here? So i will know
    This is x86 based machine using FC25 OS.
    On Another note, i tried same steps on ubuntu machine - just to check
    I dont see any file in extcap directory here also and when i force open the tshark, i get below message
    tshark: The capture session could not be initiated on interface '/dev/ttyACM0' (No such device exists).
    Please check that you have the proper interface or pipe specified.
    0 packets captured
    Thanks
    I specified "ls -l" because I also need to see permissions on the files. The screenshots is not enough.
    However, I see that root is the owner of the user files, so that may interfere.
    Disregard files other than "nrf802154_sniffer.py".
    You must manually move files into extcap directory.
    If you get the same issue on Ubuntu, I guess you are missing some steps.
    Please make sure to follow every step explained in the nRF Sniffer for 802.15.4 guide.
    Can you show me the output of these commands?
    ls /dev/ttyACM*
    groups
  • Yes i copied the python file manually in extcap directory and executed. No other files is added here.
    wcduser@wcduser-Latitude-7480:/usr/share/wireshark/extcap$ ls -l /dev/ttyACM*
    crw-rw-rw- 1 root dialout 166, 0 Sep 20 14:43 /dev/ttyACM0
    wcduser adm dialout cdrom sudo dip plugdev lpadmin lxd
    This ubuntu machine.
    As i am using the user login and not root, the wireshark exists in this path /usr/share/wireshark/extcap
    Where is the extcap file expected to be available?
