Asset Tracker V2 - Crashes trying to read non-existent config
ncs2.1.0
I have one unit, that somehow works, and when I loaded the code into any other blank devices it crashes.
The kernel panic provides hardly any info, but I'm pretty sure it is related to reading the config from storage and there is nothing there.
At settings_load_subtree, everything pauses for a couple of seconds, and then crashes.
data_module.c
static int setup(void)
	int err;
	err = settings_subsys_init();
	if (err) {
		LOG_ERR("settings_subsys_init, error: %d", err);
		return err;
    /* on a blank device this disappears and causes a panic*/
	err = settings_load_subtree(DEVICE_SETTINGS_KEY);
	if (err) {
		LOG_ERR("settings_load_subtree, error: %d", err);
		return err;
	/* Wait up to 1 seconds for the settings API to load the device configuration stored
	 * to flash, if any.
	if (k_sem_take(&config_load_sem, K_SECONDS(1)) != 0) {
		LOG_DBG("Failed retrieveing the device configuration from flash in time");
	err = cloud_codec_init(&current_cfg, cloud_codec_event_handler);
	if (err) {
		LOG_ERR("cloud_codec_init, error: %d", err);
		return err;
	date_time_register_handler(date_time_event_handler);
	return 0;
[00:00:03.447,814] <dbg> modem_module: state_set: State transition STATE_DISCONNECTED --> STATE_CONNECTING
ASSERTION FAIL [handler != ((void *)0)] @ WEST_TOPDIR/zephyr/kernel/work.c:666
[00:00:03.765,930] <err> os: r0/a1:  0x00000004  r1/a2:  0x0000029a  r2/a3:  0x00000001
[00:00:03.765,960] <err> os: r3/a4:  0x00037485 r12/ip:  0x00000000 r14/lr:  0x0004ee0f
[00:00:03.765,960] <err> os:  xpsr:  0x41000000
[00:00:03.765,991] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
[00:00:03.766,021] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
[00:00:03.766,052] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
[00:00:03.766,052] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
[00:00:03.766,082] <err> os: fpscr:  0x00000000
[00:00:03.766,082] <err> os: Faulting instruction address (r15/pc): 0x00055204
[00:00:03.766,113] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
[00:00:03.766,143] <err> os: Current thread: 0x200134a0 (sysworkq)
[00:04:08.808,868] <err> fatal_error: Resetting system
for completeness - here's the faulting instruction address.
arm-zephyr-eabi-addr2line.exe -e build_opito_nrf9160\zephyr\zephyr.elf 0x00055204
C:/ncs/v2.1.0/zephyr/lib/os/assert.c:44
Any ideas?
Thanks
Marshall
  • I've messed around so much, I don't know if the same addresses are still in the same places, hopefully it's something to work with.
    arm-zephyr-eabi-addr2line.exe -e build_opito_nrf9160\zephyr\zephyr.elf 0x00037485
    C:/ncs/v2.1.0/zephyr/drivers/clock_control/clock_control_nrf.c:749
    arm-zephyr-eabi-addr2line.exe -e build_opito_nrf9160\zephyr\zephyr.elf 0x0004ee0f
    C:/ncs/v2.1.0/zephyr/kernel/sem.c:99
    Regards
    Marshall
  • Are you still seeing the ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0?
    If you are still seeing the error, are you seeing the same numbers at r3/a4 and r14/lr ?
  • ASSERTION FAIL [handler != ((void *)0)] @ WEST_TOPDIR/zephyr/kernel/work.c:666
    [00:00:00.861,419] <err> os: r0/a1:  0x00000004  r1/a2:  0x0000029a  r2/a3:  0x00000001
    [00:00:00.861,450] <err> os: r3/a4:  0x000376b1 r12/ip:  0x00000000 r14/lr:  0x0004f03b
    [00:00:00.861,480] <err> os:  xpsr:  0x41000000
    [00:00:00.861,480] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    [00:00:00.861,511] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    [00:00:00.861,541] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    [00:00:00.861,541] <err> os: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
    [00:00:00.861,572] <err> os: fpscr:  0x00000000
    [00:00:00.861,572] <err> os: Faulting instruction address (r15/pc): 0x00055430
    [00:00:00.861,602] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
    [00:00:00.861,633] <err> os: Current thread: 0x20013000 (sysworkq)
    [00:00:00.989,868] <err> fatal_error: Resetting system
    opito:~$ ý
    arm-zephyr-eabi-addr2line.exe -e build_opito_nrf9160\zephyr\zephyr.elf 376b1
    C:/ncs/v2.1.0/zephyr/drivers/console/uart_console.c:88
    PS C:\opito\zephyr\opito_base_oct22> arm-zephyr-eabi-addr2line.exe -e build_opito_nrf9160\zephyr\zephyr.elf 4f03b
    C:/ncs/v2.1.0/zephyr/kernel/work.c:667 (discriminator 3)
    PS C:\opito\zephyr\opito_base_oct22> arm-zephyr-eabi-addr2line.exe -e build_opito_nrf9160\zephyr\zephyr.elf 55430
  • whew - I found it.
    I loaded up ncs 2.2.0 and started porting my changes across, When I got to the indication LED. it faulted.
    I have a ws2812 LED, and am using PWM to drive it, I created a new module, that had subscribed to events, and shifted my init code into this module. this also included the init for the LED.
    So the AT2 was attempting to drive the LED, before it had been assigned any memory.
    It was weird that it was only crashing at the settings module, and if it could read the settings, it would work fine.
    I guess it was indeed a timing issue, if the unit booted fast enough, the LED would be init'd in the new module and all was well, if it took that teeny bit longer to search for settings it would crash.
    Thanks for the help! really appreciate it.
    Now to consider if I carry on porting my changes across to v2.2.0! :)
    Regards
    Marshall
  • Marshall, that is good news! Happy to hear you found the root cause :)
    No problem. Any time! Slight smile
    Øyvind
