SPI error: FATAL ERROR: command exited with status 1:
I'm trying to connect to SPI modem and I did tried tons of solutions, nothing worked or even passed the build stage.
can you guide me how I can at least see what's the error? the only error i get for all examples is similar to this.
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.2.0\opt\bin\cmake.EXE' --build 'c:\SecureGatewayGen3\khaled\espi\build'
Thank you
  • Hi Khaled,
    Can you check the complete log for what error you are getting?
    Meanwhile, can you try the following:
    Extract the attached zip file and place the folder spi_bitbang_jan5 in c:/ncs/myworkfile/
    spi_bitbang_jan5.rar
    And then after opening with the VS code, do the pristine build.
    Image below is showing the NCS and Toolchain version and the successful build.
    Naeem
  • [152/241] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    FAILED: zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_USER_CONFIG_FILE=\"nrf-config-user.h\" -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=1 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.2.0/zephyr/kernel/include -IC:/ncs/v2.2.0/zephyr/arch/arm/include -Itfm/install/interface/include -IC:/ncs/v2.2.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs/v2.2.0/zephyr/lib/libc/newlib/include -IC:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.2.0/nrf/include -IC:/ncs/v2.2.0/nrf/include/tfm -IC:/ncs/v2.2.0/nrf/tests/include -Itfm/generated/interface/include -IC:/ncs/v2.2.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.2.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.2.0/nrfxlib/nrf_modem/include -Imodules/nrfxlib/nrfxlib/nrf_security/src/include/generated -IC:/ncs/v2.2.0/nrfxlib/nrf_security/include -IC:/ncs/v2.2.0/nrfxlib/nrf_security/include/mbedtls -IC:/ncs/v2.2.0/mbedtls/include -IC:/ncs/v2.2.0/mbedtls/include/mbedtls -IC:/ncs/v2.2.0/mbedtls/include/psa -IC:/ncs/v2.2.0/mbedtls/library -IC:/ncs/v2.2.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -IC:/ncs/v2.2.0/nrfxlib/crypto/nrf_oberon/include -fno-strict-aliasing -Os -imacros C:/app/spi_bitbang_jan5/build_ns/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.2.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/app/spi_bitbang_jan5=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.2.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.2.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj -MF zephyr\CMakeFiles\zephyr.dir\soc\arm\nordic_nrf\validate_enabled_instances.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj -c C:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/validate_enabled_instances.c
    In file included from C:\ncs\v2.2.0\zephyr\include\zephyr\toolchain.h:50,
                     from C:\ncs\v2.2.0\zephyr\include\zephyr\kernel_includes.h:19,
                     from C:\ncs\v2.2.0\zephyr\include\zephyr\kernel.h:17,
                     from C:\ncs\v2.2.0\zephyr\soc\arm\nordic_nrf\validate_enabled_instances.c:7:
    C:\ncs\v2.2.0\zephyr\include\zephyr\toolchain\gcc.h:77:36: error: static assertion failed: "Only one of the following peripherals can be enabled: SPI0, SPIM0, SPIS0, TWI0, TWIM0, TWIS0, UARTE0. Check nodes with status \"okay\" in zephyr.dts."
       77 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
    C:\ncs\v2.2.0\zephyr\soc\arm\nordic_nrf\validate_enabled_instances.c:48:1: note: in expansion of macro 'BUILD_ASSERT'
       48 | BUILD_ASSERT(CHECK(0), MSG(0));
    [153/241] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/ncs/v2.2.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [154/241] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [155/241] Building C object modules/nrf/modules/tfm/zephyr/CMakeFiles/tfm_api_nrf.dir/__/tfm/boards/src/tfm_ioctl_ns_api.c.obj
    [156/241] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [157/241] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [158/241] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [159/241] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [160/241] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
    [161/241] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj
    [162/241] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/fault.c.obj
    [163/241] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
    [164/241] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    FAILED: zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    C:\ncs\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_USER_CONFIG_FILE=\"nrf-config-user.h\" -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=1 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -IC:/ncs/v2.2.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs/v2.2.0/zephyr/lib/libc/newlib/include -IC:/ncs/v2.2.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.2.0/nrf/include -IC:/ncs/v2.2.0/nrf/include/tfm -IC:/ncs/v2.2.0/nrf/tests/include -Itfm/generated/interface/include -IC:/ncs/v2.2.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.2.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.2.0/nrfxlib/nrf_modem/include -Itfm/install/interface/include -Imodules/nrfxlib/nrfxlib/nrf_security/src/include/generated -IC:/ncs/v2.2.0/nrfxlib/nrf_security/include -IC:/ncs/v2.2.0/nrfxlib/nrf_security/include/mbedtls -IC:/ncs/v2.2.0/mbedtls/include -IC:/ncs/v2.2.0/mbedtls/include/mbedtls -IC:/ncs/v2.2.0/mbedtls/include/psa -IC:/ncs/v2.2.0/mbedtls/library -IC:/ncs/v2.2.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -IC:/ncs/v2.2.0/nrfxlib/crypto/nrf_oberon/include -fno-strict-aliasing -Os -imacros C:/app/spi_bitbang_jan5/build_ns/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.2.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/app/spi_bitbang_jan5=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.2.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.2.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj -MF zephyr\drivers\spi\CMakeFiles\drivers__spi.dir\spi_nrfx_spim.c.obj.d -o zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj -c C:/ncs/v2.2.0/zephyr/drivers/spi/spi_nrfx_spim.c
                     from C:\ncs\v2.2.0\zephyr\include\zephyr\devicetree\zephyr.h:15,
                     from C:\ncs\v2.2.0\zephyr\include\zephyr\devicetree.h:3931,
                     from C:\ncs\v2.2.0\zephyr\include\zephyr\device.h:12,
                     from C:\ncs\v2.2.0\zephyr\include\zephyr\drivers\spi.h:24,
                     from C:\ncs\v2.2.0\zephyr\drivers\spi\spi_nrfx_spim.c:7:
    C:\ncs\v2.2.0\zephyr\include\zephyr\toolchain\gcc.h:77:36: error: static assertion failed: "/soc/peripheral@40000000/spi@8000 defined without required pin configuration"
    c:\ncs\v2.2.0\zephyr\soc\arm\nordic_nrf\common\soc_nrf_common.h:218:9: note: in expansion of macro 'BUILD_ASSERT'
      218 |         BUILD_ASSERT((IS_ENABLED(CONFIG_PINCTRL) &&                     \
    C:\ncs\v2.2.0\zephyr\drivers\spi\spi_nrfx_spim.c:557:9: note: in expansion of macro 'NRF_DT_CHECK_PIN_ASSIGNMENTS'
      557 |         NRF_DT_CHECK_PIN_ASSIGNMENTS(SPIM(idx), 1,                             \
    C:\ncs\v2.2.0\zephyr\drivers\spi\spi_nrfx_spim.c:619:1: note: in expansion of macro 'SPI_NRFX_SPIM_DEFINE'
      619 | SPI_NRFX_SPIM_DEFINE(0);
    C:\ncs\v2.2.0\zephyr\include\zephyr\toolchain\gcc.h:77:36: error: static assertion failed: "/soc/peripheral@40000000/spi@8000 has legacy *-pin properties defined although PINCTRL is enabled"
    c:\ncs\v2.2.0\zephyr\soc\arm\nordic_nrf\common\soc_nrf_common.h:229:9: note: in expansion of macro 'BUILD_ASSERT'
      229 |         BUILD_ASSERT(!IS_ENABLED(CONFIG_PINCTRL) ||                     \
    [165/241] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj
    [166/241] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [167/241] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [168/241] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [169/241] Building C object modules/nrf/lib/modem_antenna/CMakeFiles/..__nrf__lib__modem_antenna.dir/modem_antenna.c.obj
    [170/241] Linking C static library zephyr\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
    [171/241] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_platform_ipc_api.c.obj
    [172/241] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj
    [173/241] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [174/241] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [175/241] Linking C static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
    [176/241] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [177/241] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.2.0\opt\bin\cmake.EXE' --build 'c:\app\spi_bitbang_jan5\build_ns'
     *  The terminal process terminated with exit code: 1.
    This is the full error when I tried to build your last file spi_bitbang_jan5.rar
  • The full terminal log is:
     *  Executing task: nRF Connect: Build [pristine]: spi_bitbang_jan5/build_ns (active)
    Building spi_bitbang_jan5
    west build --build-dir c:\app\spi_bitbang_jan5\build_ns c:\app\spi_bitbang_jan5 --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/nordic/myapps/spi_bitbang_22dec;c:/app/spi_bitbang_jan5" -DCONF_FILE:STRING="c:/app/spi_bitbang_jan5/prj.conf" -DDTC_OVERLAY_FILE:STRING="c:/app/spi_bitbang_jan5/nrf9160dk_nrf9160_ns.overlay"
    -- Application: C:/app/spi_bitbang_jan5
    -- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.2.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr)
    -- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
    -- Found host-tools: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.2.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
    -- Found devicetree overlay: c:/app/spi_bitbang_jan5/nrf9160dk_nrf9160_ns.overlay
    'sck-pin' is marked as deprecated in 'properties:' in C:/ncs/v2.2.0/zephyr/dts/bindings\spi\nordic,nrf-spim.yaml for node /soc/peripheral@40000000/spi@8000.
    'mosi-pin' is marked as deprecated in 'properties:' in C:/ncs/v2.2.0/zephyr/dts/bindings\spi\nordic,nrf-spim.yaml for node /soc/peripheral@40000000/spi@8000.
    'miso-pin' is marked as deprecated in 'properties:' in C:/ncs/v2.2.0/zephyr/dts/bindings\spi\nordic,nrf-spim.yaml for node /soc/peripheral@40000000/spi@8000.
    'label' is marked as deprecated in 'properties:' in C:/ncs/v2.2.0/zephyr/dts/bindings\spi\nordic,nrf-spim.yaml for node /soc/peripheral@40000000/spi@8000.
    -- Generated zephyr.dts: C:/app/spi_bitbang_jan5/build_ns/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/app/spi_bitbang_jan5/build_ns/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/app/spi_bitbang_jan5/build_ns/zephyr/dts.cmake
    Parsing C:/ncs/v2.2.0/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.2.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
    Merged configuration 'c:/app/spi_bitbang_jan5/prj.conf'
    Configuration saved to 'C:/app/spi_bitbang_jan5/build_ns/zephyr/.config'
    Kconfig header saved to 'C:/app/spi_bitbang_jan5/build_ns/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/app/spi_bitbang_jan5/build_ns
    [1/241] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [2/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/asn1parse.c.obj
    [3/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/asn1write.c.obj
    [4/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/bignum.c.obj
    [5/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/base64.c.obj
    [6/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/padlock.c.obj
    [7/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/platform.c.obj
    [8/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/nist_kw.c.obj
    [9/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/oid.c.obj
    [10/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/platform_util.c.obj
    [11/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/version.c.obj
    [12/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/constant_time.c.obj
    [13/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pem.c.obj
    [14/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkparse.c.obj
    [15/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/dhm.c.obj
    [16/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkwrite.c.obj
    [17/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkcs12.c.obj
    [18/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkcs5.c.obj
    [19/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pk.c.obj
    [20/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cipher_wrap.c.obj
    [21/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cipher.c.obj
    [22/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/md.c.obj
    [23/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pk_wrap.c.obj
    [24/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha256.c.obj
    [25/241] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [26/241] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
    [27/241] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [28/241] Generating include/generated/driver-validation.h
    [29/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha512.c.obj
    [30/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ripemd160.c.obj
    [31/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha1.c.obj
    [32/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/des.c.obj
    [33/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/md5.c.obj
    [34/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/aria.c.obj
    [35/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/aesni.c.obj
    [36/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/camellia.c.obj
    [37/241] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto_base.a
    [38/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ccm.c.obj
    [39/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/chachapoly.c.obj
    [40/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cmac.c.obj
    [41/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecdh.c.obj
    [42/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecdsa.c.obj
    [43/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecp.c.obj
    [44/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/gcm.c.obj
    [45/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecp_curves.c.obj
    [46/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/hkdf.c.obj
    [47/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/hmac_drbg.c.obj
    [48/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/entropy.c.obj
    [49/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ctr_drbg.c.obj
    [50/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/rsa_alt_helpers.c.obj
    [51/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
    [52/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
    [53/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
    [54/241] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/rsa.c.obj
    [55/241] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
    [56/241] Generating ../../tfm/CMakeCache.txt
    -- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/app/spi_bitbang_jan5/build_ns/tfm
    [57/241] Creating directories for 'tfm'
    [58/241] No download step for 'tfm'
    [59/241] No update step for 'tfm'
    [60/241] No patch step for 'tfm'
    [61/241] No configure step for 'tfm'
    [61/241] Performing build step for 'tfm'
    [1/2] Generating ../generated/secure_fw/spm/cmsis_func/tfm_spm_db_func.inc, ../generated/secure_fw/spm/cmsis_func/tfm_veneers.c, ../generated/interface/include/tfm_veneers.h, ../generated/tools/tfm_veneers_functions.txt, ../generated/secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc, ../generated/interface/include/psa_manifest/sid.h, ../generated/interface/include/psa_manifest/pid.h, ../generated/interface/include/config_impl.h, ../generated/tools/config_impl.cmake
    [1/2] Re-running CMake...
    -- Configuring done
    -- Generating done
    [1/170] Generating liboberon_mbedcrypto__psa_3.0.12.a
    [2/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_strnlen.o
    [3/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memmove.o
    [4/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memset.o
    [5/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_partition_metadata_indicator.o
    [6/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/service_api.o
    [7/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcpy.o
    [8/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sfn_common_thread.o
    [9/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o
    [10/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o
    [11/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_main.o
    [12/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [13/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_cross.o
    [14/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call_pack.o
    [15/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    [16/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o
    [17/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    [18/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    [19/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    [20/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    [21/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    [22/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    [23/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    [24/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o
    [25/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    [26/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    [27/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [28/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [29/170] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [30/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto.o
    [31/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_client.o
    [32/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_aead.o
    [33/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_ecp.o
    [34/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/memory_buffer_alloc.o
    [35/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_cipher.o
    [36/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_storage.o
    [37/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_mac.o
    [38/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_slot_management.o
    [39/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_hash.o
    [40/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/psa_crypto_driver_wrappers.o
    [41/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_rsa.o
    [42/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkcs12.o
    [43/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkparse.o
    [44/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkcs5.o
    [45/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/random_ext.o
    [46/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkwrite.o
    [47/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pem.o
    [48/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cipher.o
    [49/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cipher_wrap.o
    [50/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha1.o
    [51/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/dhm.o
    [52/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/md.o
    [53/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pk.o
    [54/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pk_wrap.o
    [55/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ripemd160.o
    [56/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/aria.o
    [57/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha512.o
    [58/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/md5.o
    [59/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/aesni.o
    [60/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha256.o
    [61/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/des.o
    [62/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/chachapoly.o
    [63/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/camellia.o
    [64/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecdh.o
    [65/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cmac.o
    [66/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecdsa.o
    [67/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ccm.o
    [68/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/hkdf.o
    [69/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecp_curves.o
    [70/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecp.o
    [71/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/gcm.o
    [72/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/hmac_drbg.o
    [73/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/rsa.o
    [74/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes_oberon.o
    [75/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes.o
    [76/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/ecjpake_oberon.o
    [77/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/rsa_alt_helpers.o
    [78/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [79/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/bignum.o
    [80/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/asn1write.o
    [81/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/nist_kw.o
    [82/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/base64.o
    [83/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/asn1parse.o
    [84/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/oid.o
    [85/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/padlock.o
    [86/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/platform.o
    [87/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/version.o
    [88/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/constant_time.o
    [89/170] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/platform_util.o
    [90/170] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libmbedcrypto_base.a
    [91/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [92/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    [93/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    [94/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [95/170] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [96/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o
    [97/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [98/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o
    [99/170] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o
    [100/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o
    [101/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
    [102/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o
    [103/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o
    [104/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o
    [105/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_nvic.o
    [106/170] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.o
    [107/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o
    [108/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/tfm_interrupts.o
    [109/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o
    [110/170] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/target_cfg.o
    [111/170] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/attest_hal.o
    [112/170] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/tfm_hal_platform.o
    [113/170] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/dummy_otp.o
    [114/170] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o
    [115/170] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_s_api.o
    [116/170] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/dummy_provisioning.o
    [117/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_memory_symbols.o
    [118/170] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_platform.o
    [119/170] Building C object lib/fih/CMakeFiles/tfm_fih_implementation.dir/src/fih.o
    [120/170] Linking C static library lib\fih\libtfm_fih_implementation.a
    [121/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/tfm_psa_api_veneers.o
    [122/170] Building ASM object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/nrf9160/gcc/startup_nrf9160_s.o
    [123/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [124/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [125/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [126/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/idle_partition/load_info_idle_sp.o
    [127/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o
    [128/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [129/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/interface/src/tfm_psa_call_pack.o
    [130/170] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_cross.o
    [131/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch.o
    [132/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o
    [133/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_core_utils.o
    [134/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/utilities.o
    [135/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_ipc.o
    [136/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/backend_ipc.o
    [137/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/psa_api.o
    [138/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o
    [139/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/main.o
    [140/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_cross_call.o
    [141/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_pools.o
    [142/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/interrupt.o
    [143/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o
    [144/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/thread.o
    [145/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o
    [146/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_core_svcalls_ipc.o
    [147/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [148/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [149/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [150/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/idle_partition.o
    [151/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz.o
    [152/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/interface/src/tfm_psa_call_pack.o
    [153/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/psa_interface_cross.o
    [154/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [155/170] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/load_info_idle_sp.o
    [156/170] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcmp.o
    [157/170] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_cross.o
    [158/170] Building C object platform/CMakeFiles/platform_s.dir/__/interface/src/tfm_psa_call_pack.o
    [159/170] Linking C static library platform\libplatform_s.a
    [160/170] Linking C static library secure_fw\partitions\platform\libtfm_psa_rot_partition_platform.a
    [161/170] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedcrypto.a
    [162/170] Linking C static library secure_fw\partitions\crypto\libtfm_psa_rot_partition_crypto.a
    [163/170] Linking C static library secure_fw\partitions\lib\sprt\libtfm_sprt.a
    [164/170] Linking C static library secure_fw\spm\libtfm_spm.a
    [165/170] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld
    [166/170] Linking C executable bin\tfm_s.axf
    [167/170] Generating ../bin/tfm_s.hex
    [168/170] Generating ../bin/tfm_s.elf
    [169/170] Linking C static library secure_fw\libtfm_s_veneers.a
    [170/170] Generating ../bin/tfm_s.bin
    [63/241] Generating zephyr/tfm_secure.hex
    [64/241] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [65/241] Completed 'tfm'
    [66/241] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [67/241] Generating include/generated/offsets.h
    [68/241] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [69/241] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [70/241] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [71/241] Generating linker_zephyr_pre1.cmd
    [72/241] Generating linker_zephyr_pre0.cmd
    [73/241] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [74/241] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [75/241] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [76/241] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [77/241] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [78/241] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [79/241] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [80/241] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [81/241] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [82/241] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [83/241] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [84/241] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [85/241] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [86/241] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [87/241] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [88/241] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [89/241] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [90/241] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [91/241] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [92/241] Building C object CMakeFiles/app.dir/src/main.c.obj
    [93/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [94/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [95/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [96/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [97/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [98/241] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [99/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [100/241] Linking C static library zephyr\arch\common\libisr_tables.a
    [101/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [102/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [103/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [104/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [105/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [106/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [107/241] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [108/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [109/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [110/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [111/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [112/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [113/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [114/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [115/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [116/241] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [117/241] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    [118/241] Linking C static library app\libapp.a
    [119/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [120/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [121/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [122/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [123/241] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [124/241] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [125/241] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [126/241] Linking C static library zephyr\arch\common\libarch__common.a
    [127/241] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [128/241] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_secure.c.obj
    [129/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [130/241] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [131/241] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [132/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj
    [133/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
    [134/241] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [135/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [136/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [137/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [138/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [139/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_uart.c.obj
    [140/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [141/241] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [142/241] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [143/241] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [144/241] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [145/241] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [146/241] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [147/241] Building C object zephyr/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
    [148/241] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [149/241] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [150/241] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [151/241] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_bitbang.c.obj
    [152/241] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [154/241] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [157/241] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [159/241] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
    [160/241] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj
    [161/241] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/fault.c.obj
    [162/241] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
    [163/241] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [164/241] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [165/241] Building C object modules/nrf/lib/modem_antenna/CMakeFiles/..__nrf__lib__modem_antenna.dir/modem_antenna.c.obj
    [166/241] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [167/241] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj
    [168/241] Linking C static library zephyr\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
    [169/241] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [170/241] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [171/241] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj
    [172/241] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [173/241] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [174/241] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [175/241] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_platform_ipc_api.c.obj
    [176/241] Linking C static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
    [177/241] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [178/241] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [179/241] Linking C static library zephyr\drivers\console\libdrivers__console.a
