Hello, I am trying to make VLF~LF sinusoidal frequency (10kHz ~ 50kHz) with NRF 52832.
My approach was making a square wave first, then putting the signal into the analog rectifier circuit.
First, I tried to make a square wave by using timer delay like the following,
while (1) { bsp_board_led_invert(3); nrf_delay_ms(2); }
and I thought it worked pretty well,
But since I request the NRF for another task, the signal has distorted like above in the middle of the signal.
Since I tried to make AM modulation/demodulation circuit with this wave, this was a huge problem for me.
I googled and found out I should approach with a timer interrupt.
So, I changed my code to the below.
int main(void) { bool erase_bonds = false; log_init(); timers_init(); ble_stack_init(); gap_params_init(); gatt_init(); advertising_init(); conn_params_init(); peer_manager_init(); application_timers_start(); services_init(); sensor_simulator_init(); advertising_start(erase_bonds); csense_initialize(); NRF_GPIO->DIRSET = 0x01 << 23; timerInit(50); while (1) { // bsp_board_led_invert(3); // nrf_delay_ms(2); if (NRF_LOG_PROCESS() == false) { power_manage(); NRF_LOG_FLUSH(); __WFI(); } } } void timerInit(uint16_t period_us) // function for timer init { NRF_TIMER4->TASKS_STOP = 1; // stop the timer NRF_TIMER4->TASKS_CLEAR = 1; // clear NRF_TIMER4->MODE = TIMER_MODE_MODE_Timer; // set as timer mode NRF_TIMER4->BITMODE = TIMER_BITMODE_BITMODE_32Bit; // timer counter as 32bit NRF_TIMER4->PRESCALER = 1; //prescaler as 1 NRF_TIMER4->CC[0] = (float)8000000 * ((float)period_us / 1000000.0f); NRF_TIMER4->INTENSET = 65536; // timer intrupt active NRF_TIMER4->SHORTS = 0x01; // short cut register activate NVIC_EnableIRQ(TIMER4_IRQn); // timer interupt function activate NRF_TIMER4->TASKS_START = 1; }
However, there were 2 problems.
One is I cannot adjust the period of the signal or duty cycle.
Even if I can adjust slightly for the pulse width, I cannot change the period of the signal.
And another problem is the resolution looks really bad even though the signal was not a high frequency.
I was able to see the fall time of the pulse.
Is there any way for me so I can make a clear sinusoidal (or square) wave by using NRF52832?
What could be the problem with my code?
